- This topic has 54 replies, 38 voices, and was last updated 9 years, 2 months ago by
Anonymous.
May 19, 2014 at 10:29 am #21473
PaulBox
Hi, sorry if this is a really stupid question, but I’m currently thinking about buying some new wheels for my road bike and can’t find the answer elsewhere.
I’m considering a set of Pro Lite Bracciano A42’s because they are supposedly strong (I’m a big lump), have the upside of being aero and look quite nice. Obviously not a sexy as their carbon equivalents, but due to being heavy I don’t want to risk getting carbon wheels at this point.
What’s putting me off is that I keep seeing references to aero section wheels not being good on climbs and in windy conditions. The windy conditions bit is self explanatory, but I can’t see why they would be detrimental to climbing. Being a big lump I certainly don’t need any other hindrances on climbs…
Thanks in advance for help/advice, Paul.
The only way to settle this
The only way to settle this is to put some sort of cycling robots that can hold set wattage and body positions on different bikes and then see the true differences. Too many variables when humans are doing it.
part_robot
Does this interia lark even
Does this inertia lark even have a real effect? Intuitively it doesn’t feel like it; I can quickly spin up my wheels to a considerable speed (and stop them even quicker) by just lightly using my hands. Pretty sure I can’t accelerate my body similarly with so little force. Seems absurd that a 300g difference between an aero and shallow section wheelset will make any noticeable difference. I probably pee out >300g of water on long distance toilet breaks yet I’m pretty sure I’m not faster up the hills at the end. I’d like to see the science proving me wrong.
matthewn5 wrote:
matthewn5 wrote:I don’t want to get personal, just to put it all in perspective regarding marginal gains. At 6′ 4″ (193.04cm) you have a BMI of 28.2, which is in the ‘overweight’ range: http://www.nhlbi.nih.gov/guidelines/obesity/BMI/bmi-m.htm The maximum BMI in the ‘healthy range’ is 25, so your maximum healthy weight would be 93kg. To become competitive you probably need a BMI of about 22.7 (the average BMI of nine cycle racing champions including Merckx, Altig and Gimondi, see http://www.etape.org.uk/BMI1.htm) which means a weight of 84.5kg… So just enjoy riding your bike! Don’t worry about your weight, or your bike’s weight, unless you want to race.BMI
Bullshit MisInformation
wycombewheeler
Simon E wrote:
Simon E wrote:Another point: when comparing wheelsets you don’t know where the weight has been saved. If it’s from the hub it is of very little value in helping you go uphill; but if it’s off the rim then it is likely weaker, with a thinner brake track. You may end up having to replace them much sooner than you might expect.Keith Bontrager’s now famous aphorism applies: Strong, light, cheap. Pick two.
disagree going uphill it’s just about all up weight.
saving weight on the rim is only beneficial for accelerating, I dont normally find myself acelerating uphill.
each ‘micro acceleration’ will be accompanied by an equivalent micro deceleration between thr downstrokes. No net benefit when climbing from lower rotational mass. There may even be a benefit from angular momentum storing energy like a flywheel. (heavier rims but identical overall bike weight) but this would be tiny for the sorts of weights we are talking about.Welsh boy
vorsprung]
Simon E</strong></p> <p>[quote=vorsprung wrote:[quote=Simon E]… then wheels do have micro accelerations all the time.How does wheel “micro accelerations” affect the overall speed of climbing? The amount of energy to increase the rotational speed of a wheel is negligible, my 3 year old daughter can accelerate a wheel significantly with her one finger, you should hold a couple of different wheels and give it a try yourself and see if you can feel the difference in energy required to accelerate different weight wheels.
Mungecrundle
Deep section aero wheels make
Deep section aero wheels make your bike look good. But lighter wheels offer better bragging opportunities. For most of us this is where the discussion ends.
srchar
I have two sets of Campagnolo
I have two sets of Campagnolo wheels that I use regularly – Zondas (which are not aero) and Bora One 50s (which are aero and also shod with tubulars).
The Boras are absolutely faster on the flats – I go faster for the same effort. I do not notice any difference on the climbs and it has to be howling an absolute gale before sidewinds become an issue.
Braking is better on the Zondas, but it’s not like the Boras are awful – I’ve done plenty of Alpine and Dolomite descents on the Boras with no issues.
joeegg
When I purchased a new
When I purchased a new wheelset I actually bought a set a little bit heavier. The first ride out confirmed they felt far stronger and rigid than the originals. For me,the pedalling when climbing seemed far more efficient.
I know there are facts and figures showing that weight makes virtually no difference to climbing but I’d rather ride my 1500g wheelset than the 2000g one here in the North Pennines.
Richb1
Even though it’s a 2 year old
Even though it’s a 2 year old thread, made for interesting reading, some clearly for deep sections, some for lighter rims, others extolling the virtues of proper training, surely the idea is to combine the best training that you can manage with the best wheels for the type of riding that you do? I’m no expert and don’t profess to be but I research products by reading many reviews, on the product itself, more about quality and durability than claims regarding performance, because if you don’t look after yourself and keep your diet and training to their optimum, then it doesn’t matter what you buy, you are always going to be fighting a losing battle when looking for improvement.
chaloum
I’ll throw my 2 cents in.
I’ll throw my 2 cents in. There is no perfect all round wheel but a good quality aluminium rim with a reasonable profile might come close. Deep rims have a greater inertia but once powered up, maintain their speed better, which makes hill climbs a little inefficient as you constantly loading and unloading power.
side winds are only an issue with 60+ cm rims. If you using a 40cm it’s not that much of an issue under most circumstances.
as said before a light set of aluminium wheels would be good for climbing but if you on rolling terrain then a 40cm rim would be a good choice.
also as said, loose weight, get a power meter, a better helmet albeit there is no benefit when climbing, work on your flexibility and position change your cassette to a better hill climbing ratio. You can improve your climbing with little or no money.
PaulBox
drmatthewhardy wrote:I don’t
drmatthewhardy wrote:I don’t want to get personal, just to put it all in perspective regarding marginal gains. At 6′ 4″ (193.04cm) you have a BMI of 28.2, which is in the ‘overweight’ rangeThat just demonstrates how crap those charts are, when I was 105kg I had a 6 pack and was in top shape. I’m never going to look like a pro cyclist as my body shape just isn’t right. Right now I’m unfortunately more than overweight… 😕
drmatthewhardy wrote:To become competitive you probably need a BMI of about 22.7I’m not worried about being competitive, I just didn’t want to buy wheels that were going to add to my struggles up hills.
drmatthewhardy wrote:So just enjoy riding your bike! Don’t worry about your weight, or your bike’s weight, unless you want to race.Amen!
Ghedebrav
bashthebox wrote:Remember
bashthebox wrote:Remember half the reason pro teams ride all the bling is so the sponsors can advertise and sell the bling. If it made much difference, they’d all be on very similar tech all the time (see aero helmets for sprint finishes).Just half? 👿
ch
If you say they are strong,
If you say they are strong, and you are heavy, then I think you have the most important point covered already. Bent spokes and out-of-true wheels spoil rides.Another issue when you buy wheels is the whether the new true wheel is lemon or a peach. On a peach the new true wheel’s spokes will have pretty even tension between themselves, but on a lemon the tension among spokes may vary by x2 just to keep the wheel true.
So if you buy the last wheel of type A on sale, be careful of the relative spoke tension required to make the wheel true.
If you are willing to accept a relatively heavier with higher spoke count but high quality robustness, consider a wheel-builder with whom you can get verbal confirmation that max spoke tension ration will be <= 4:3
Colin Peyresourde
Back to the original
Back to the original question: there are two issues at play on a wheel when ascending on a bike. One is the rotational forces of the wheel. A moving wheel can help generate momentum, but it your stroke rate is slow and wheel moving slowly and unsteadily you’re going to have to work hard to generate momentum and so the likelihood is that it will slow you.The other is the ‘aero’ effect. Basically at lower speeds the benefits of aerodynamics are much reduced. There’s very little point in slip streaming anyone at less than 12 mph. So basically the benefits of deep section wheels evaporate when going uphill and they only tend to make you look like you got lost on your time trial. As other posters have mentioned the pros don’t use them on climbs, and cross-winds can be a problem.
These wheels have their place, but a solid set of Ksyeriums will see you round most things.
dreamlx10
timtak wrote:The best way to
timtak wrote:The best way to climb faster is to loose weight. The best way to loose weight is to get on your bike. One good way to motivate yourself to get on your bike is to get one with a lot of bling including aero wheels.Why can’t you spell “lose” ?
