Dual Eyewear glasses
  • #21396
    jova54
    Been reading the cycling sunglasses Road Test in Cycling Plus and interested in the Dual Eyewear glasses with the in-built bifocal lens.
    I use vari-focals all the time and need to wear them when cycling so I can see my phone and cycling computer, so these might be a solution.
    They get a good review but the bifocal section is a fixed diopter.
    Does anyone have any experience/opinions on these?
Viewing 15 replies - 1 through 15 (of 17 total)
  • #791843
    jova54
    Hi Ants and Bikebot.
    Thanks
    Thanks for the replies.
    I’ve found the glasses on High on Bikes as well and the spiel says that a slightly weaker prescription works well with the SL and Pro glasses.
    Mine is still +2.5 for the varifocal. What strength are your prescriptions and did you get lense of the same strength or weaker?
    Cheers
    #791841
    Jack Osbourne snr
    Nigel, look at the difference
    Nigel, look at the difference in domains…
    Your posted .Co.UK link is to the very bland webpage of a draughtsman.
    The safety specs people have a .Com Web address… And amusingly, they carry an advert by some CAD design people… But, you will note…different ones from the guy with the straightlines.co.uk address.
    I was going to give you the benefit of the doubt and suggest that it must be the autoincorrect on your device… But then you besmirched by vision.
    Whoops… Egg everywhere. Welcome to the pedant-filled world of cycling.
    #791839
    bikebot
    I also bought a pair of Dual
    I also bought a pair of Dual Pro’s last year. I’m happy with the purchase.
    #791837
    NigelSign
    Jack, obviously need glasses,
    Jack, obviously need glasses, look past the front page and you will find the glasses on the straightlines site
    #791835
    Ants
    When I was looking into this
    When I was looking into this some people reported issues with varifocals for cycling – I think this may depend on type/strength of lense and some have better transitions. Even though I use VF for everyday use I can manage without them for distance but was having issues with reading the Garmin. I added the stick-on lenses mentioned above and cut them down by several mm to keep them out of normal vision. They are quite expensive though considering an extra set of lenses for the Dual SL2 Pros are less. Both solutions work for me but I prefer the Dual SL2 Pro over the stick-ons on my Racing Jackets. If the stick-on lenses were cheaper I may have gone for that but almost £60 for 3 sets for my lenses is pretty close to the £85 for a pair of SL2 Pros and 2 extra sets of lenses – and no chance of the stick-on falling off. Prescription lenses were possible for the Oakleys but only just (due to shape of lense) and were much too expensive. Optician did suggest varifocal contacts or alternatively using a close-up lense in one eye and distance in the other. Even though this sounds crazy it does seem to be possible.
    #791833
    andyp
    ‘Optician did suggest
    ‘Optician did suggest varifocal contacts or alternatively using a close-up lense in one eye and distance in the other. Even though this sounds crazy it does seem to be possible.’
    it’s an incredibly successful and popular form of vision correction. Your brain can handle it really well.
    #791831
    andyp
    multifocal contact lenses &
    multifocal contact lenses & normal shades?
    #791829
    jova54
    Cheers for the comments
    Cheers for the comments guys.
    Posted the original last year so surprised to see it pop up again.
    I’ve tried the industrial route with bifocal stick ons but I’m so used to varifocals that they made me feel ill on some transions.
    Going to look at the Rapid Eye Wear stuff and Wiggle again for the Dual Pros
    #791827
    Jack Osbourne snr
    NigelSign wrote:Take a look
    NigelSign wrote:
    Take a look at http://www.straightlines.co.uk they do safety glasses for about £8.00 in clear dark or yellow, can have a small lense with your prescription for seeing computer or reading the coffee menu. Look like cycle specific glasses and I use them all the time find them great for riding
    That link is an advert for a draughtsman. I’m wearing my normal prescription specs and can see that without squinting or moving my tablet back and forward.
    http://www.straightlines.com/safetyspecs/
    #791825
    NigelSign
    Take a look at
    #791823
    jthef
    #791821
    Guernsey Donkey
    I have a pair of the Dual SL2
    I have a pair of the Dual SL2 glasses (not the Pro) which I have had for about 10 months.
    The reading part of my Varifocals is +2.25 and I have the SL2’s in +2.0. I find them excellent and have bought the amber and clear lenses to go with the standard smoke ones.
    How you will get on with them will depend on your distance vision. Mine is basically uncorrected so these work fine for me but if your varifocals have a correction for distance vision as well as near you might struggle.
    I’ve just looked at Wiggle and they have lenses in +1.5, 2.0 & 2.5, not just the 1.5 stated above.
    #791819
    pcaley
    I am at the point of needing
    I am at the point of needing bifocal cycling glasses. The ones that caught my eye (as it were!) were pro performance plus from rapid eye wear. Do an internet search for Rapid Eye wear and select prescription sunglasses. £105.00 looks very tempting to me. Also available through Amazon.
    #791817
    Ants
    I bought these as I was fed
    I bought these as I was fed up with not being able to read all fields on my Garmin and unwilling to pay the £300+ for Oakley prescription lenses. I tried stick-on bifocals which worked OK with a bit of trial and error but these are a much better solution. Now all fields of the Garmin are sharp by just looking down with my eyes (not moving my head) – the bifocal area is perfect for riding as it is has no effect on normal vision of the road. They do a good range of tints at a reasonable cost but the best feature over my Racing Jackets is that they fit OVER my helmet straps 😉
    I can’t believe other manufacturers haven’t created a similar lense.
    #791815
    jova54
    Just got a copy of the
    Just got a copy of the prescription for my current varifocals from the optician. It’s +2.5 for each eye so pushing the probable limit of these glasses but they sound a better option to inserts.
    Be interested to know if anyone has any practical experience. Wiggle only carry +1.5 lenses. I had read somewhere, but can’t remember where, that these don’t need to be as strong as prescription glasses.
