Road cyclists with bad backs
  • #21382
    Widge34
    I’m a Mountain biker who has dodgy back. I’ve been told by my Osteopath that in the long run I maybe better off riding a road bike. Anyone here ride a road bike and has a bad back? Are you ok riding?
Viewing 15 replies - 1 through 15 (of 23 total)
  • #791541
    Widge34
    Well, first trip out on the
    Well, first trip out on the new bike today, 25 miles and back felt good.
    #791539
    Rupert
    Without knowing the true
    Without knowing the true cause of your back pain I cannot suggest anything in particular.
    I would say that bike position and core strength play a major part in reducing back pain.
    I wouldn’t say that just moving over to a road bike is going be much difference to riding a mountain bike apart form less juddering on rough surfaces when mountain biking. Just moving over to the Road bike won’t make much difference to the underlying problem with your back.
    I would seek more advice from someone who knows what they are talking about. There are a lot of riders these days taking up the sport with poor core strength with conditions such as sway back etc. Without a strong flexible core cycling at the very least will be less enjoyable, and in some cases depressingly painful.
    I would say don’t go riding on any bike until you have identified the problem and used different exercises to correct it.
    I wish you well and hope you sort this issue out soon.
    #791537
    monty dog
    I was suffering from chronic
    I was suffering from chronic back pain from years of cycling(road/MTB/CX) and not paying enough attention to my core. Since taking up flatwater kayak racing my back has improved massively and I’m back to riding for 5+ hours without discomfort. Upside is my n+1 also includes 18ft of carbon-fibre racing kayak!
    #791535
    Airzound
    chin ups for core strength
    chin ups for core strength and running strangely work for me to keep my back in fine fettle. Also good footwear helps.
    #791533
    Colin Peyresourde
    drmatthewhardy wrote:One day
    One day I had the idea of lowering the bars, and then started lowering them more and more, month by month. I now can now ride with a -10º stem stammed on the headset with no spacers on a bike with a short head tube.
    Meanwhile my back has hugely improved from the regular exercise, and I can go for long periods (touch wood) without a relapse. If it is hurting, I find the lower position on the bike more comfortable than walking, because there’s less weight on the saddle. A side benefit is no probs with saddle comfort too.
    So my advice is, try it lower, bit by bit, it may actually take some of the weight off your lower back.
    That is certainly counter-intuitive. I won’t knock it because I haven’t tried that.
    I would say that hip mobility and ROM will likely have a bearing on whether that works for some. If you can’t raise your knee much beyond parallel when lying or standing, you’re going to find it hard to do it seated….and then that puts strain on the back (your hip curves around to compensate for a lack of flexibility, which then strains the back).
    I’m assuming your doctor mentioned road bikes because of the jarring involved in jumping about on mountain bikes, and not because of any other feature. Road cycling on a road bike is very smooth, and if you get carbon, it actually absorbs a certain amount of jarring. I ride my mountain bike to work, and my road bike everywhere else.
    Like all the others here, a combination of core strength, and flexibility training (yoga, pilates or a good stretching regimen) are the main accoutrement for a healthier back. Try MWOD. There are plenty of free youtube videos which detail good stretches and good habits. Ideally you should consult a physio, but experiment with what works for you…..do not try the touching your toes stretch, that just tests yours back and tweaks your sciatic nerve.
    #791531
    matthewn5
    I’ve suffered from a bad back
    I’ve suffered from a bad back since 1986 when I attempted to pick up something that was much heavier than it looked… long story.
    Anyway, when I got a road bike again about 4 years ago, typical Mamil, I had the bars up quite high, and struggled to find a comfortable saddle. One day I had the idea of lowering the bars, and then started lowering them more and more, month by month. I now can now ride with a -10º stem stammed on the headset with no spacers on a bike with a short head tube.
    #791529
    notfastenough
    farrell wrote:I screwed my
    farrell wrote:
    I screwed my back due to a combination of wearing socks, a ringing phone, a run down the stairs and a sister that though furniture polish was a good idea on a laminate floor.
    If you remember Wizbit then it might make sense when I say that my legs went “ha ha this a-way” and my upper body went “ha ha that-a-way”.
    My oh my!
    (Sorry!)
    #791527
    bobinski
    I am 51y old and had 2
    I am 51y old and had 2 prolapsed discs, l4 then l5, 18 months apart some 15 yrs ago. I was pretty much unable to work for over a year. I refused surgery and relied upon osteopathy and acupuncture( to deal with the pain from the former which was unusually invasive) and developing my core to recover. I was never particularly heavy but i also lost weight. Although they healed up i would get an occasional flare up. That only stopped after i took up road cycling just over 4 years ago. I know it sounds counter intuitive, but i ride fairly low, not stem slammed, on a planet x sl pro and so i am pretty stretched out. My neck occasionally gives me a little grief especially if i have not ridden much for a while but i actually find that riding a road bike has been a boon or aid to my back problems. I am long backed and apparently short legged so my experience may reflect my own physiology but riding a road bike has been an entirely positive experience for me. I just wish i could get out on the bike more!
    #791525
    farrell
    Since then it gets painful and uncomfortable when riding road bikes.
    And when riding mountain bikes.
    And when riding BMX.
    And behind a drum kit.
    But it’s much, much, much worse when I’m sat round doing nothing. Sitting on a sofa will give me loads more grief. Keeping moving, as long as your not caning yourself, will have far more benefits. Just get comfy and enjoy it.
    (I’m not a medical professional though, so feel free to ignore at will)
    #791523
    Cyclist
    Planks Planks Planks
    Planks Planks Planks Planks…. Side Planks Side Planks Side Planks everyday.
    #791521
    Widge34
    Thanks for all your advise
    Thanks for all your advise and comments Guys. Appreciated.
    #791519
    tom_w
    Get a bike that will take
    Get a bike that will take 28mm tyres too, there really is a noticeable reduction in jarring compared to 23mm tyres. Having recently swapped to wide (24mm) rims I’d strongly recommend those too.
    #791517
    amole29
    I have scoliosis and have
    I have scoliosis and have been having it reset by Osteos for past 11 months..
    I agree with others here, core strength is a must to support… i can truly recommend pilates… if done correctly at a proper class, not a gentle one it is great for the core and has helped me no end!
    #791515
    Cyclist
    You need to know why you have
    You need to know why you have a dodgy back…? Before you can fix it.
    Muscular? Skeletal? imbalance in anterior / posterior chain? Or just plain old weak? Being told, in the long run etc doesn’t really help you fix it. Everyone who rides road bikes over a certain distance will suffer some kind of back discomfort during a ride. You need to find the cause of the problem first.
    #791513
    SamShaw
    Might be worth checking out
    Might be worth checking out this fairly extensive blog by Nick Hussey on bike fit and problems that can arise.
    http://www.vulpine.cc/Blog/health/how-to-make-your-bike-fit
