- This topic has 48 replies, 32 voices, and was last updated 12 years, 7 months ago by
surly_by_name.
April 19, 2014 at 9:49 pm #21206
rnarito
I’m new to road cycling (10 months and going strong!) I’ve read quite a bit about how power meters can really help you improve, but here’s the deal. I’ll be 54 this year and have no intention of competing (the occasional sportive notwithstanding), how much will this help me? I’m somewhat financially stable, so the cost is not that big an issue for me. Can someone out there give a good enough reason to take the plunge? Many thanks!:)
surly_by_name
glynr36 wrote:Streamliner
glynr36 wrote:Streamliner wrote:
For me I’ve felt it’s been worthwhile, and I’m surprised the above list doesn’t get more of a mention in power meter discussions.Because all the naysayers are people who can’t/won’t stump up the cash, and think any technological advancement is ‘unpure’.
I have no objection to technological advancement. I could but I won’t stump up the cash.
I know that I won’t use a powermeter – I usually can’t be bothered to attach my Garmin (and when I turn it on I tend to find I have failed to recharge it) let alone analyse the data it produces, so my chances of using even part of the functionality of a power meter are pretty low. And the last thing I need is another thing to fix (or even calibrate) on my bike – I’ve got a long enough list of brakes that need recabling/whels that need truing/tubs that need gluing as it is thanks.
glynr36
Streamliner wrote:
mooleur
Great post! Have to agree
Great post! Have to agree although much better coming from as experienced a rider as yourself Streamliner.Especially agree with position, after bike fits I’ve seen my power increase (especially when climbing) by a surprising amount.
Streamliner
I’ve been riding bikes for 2
I’ve been riding bikes for 2 decades either mountain bikes or road bikes. Earlier this year I took the plunge and bought a powertap pair of wheels, my first power meter. I have never raced other than a handful of TTs, and maybe I will try a race if I feel I won’t get crushed by the regular racers.So my motivation was curiosity, and to get more focused on my training. At the end of the day it’s your money so you can spend it on what you want!
I have found it very useful so let me answer those here saying they have no point and you should just go ride more, or time yourself up hills, or look at your HR etc.
The main benefit I’ve found is in real time, during the ride. You can see in front of your eyes your power vary as you pedal. Sound obvious?
Since having a power meter I’ve learned:
Tiny changes in your riding position make big differences to your power. You can get big increases from improving your bike setup.
What you subjectively perceive as pushing hard at any point bears little relation to your actual output. To a degree this is also true of HR if you are for example too cold, or fatigued, or pedalling inefficiently.
Seated vs standing power outputs may be nothing like what you expect.
Whether you are getting better power from lower or higher cadence.
Which part of the pedal stroke to focus on to generate the most power.I didn’t expect any of this beforehand, I thought I would just be able to do more effective training! But the above has transformed my performance just through position and pedalling technique improvements.
Not really. You can do a
Not really. You can do a pool-based tri in a tri suit, or in your swimmers and change into bike/run kit, for the princely sum of £30. As I am on Monday.TheHound
BBB wrote:I’m somewhat
BBB wrote:I’m somewhat financially stable, so the cost is not that big an issue for meThis is really the only important bit. If you can afford it, buy it. Every real man needs a new gadget occasionally. It’s what separates us from the beasts.
Colin Peyresourde
I agree. But the triathlon
I agree. But the triathlon community has even higher barriers to entry than cycling because you have to be able to afford a wetsuit and a bike – generally this means higher disposable income and ergo the ability to splash the cash on what some call an extravagance. The cost of a wetsuit might equate to the cost of a bike to some.Affordability really is at heart of some of these comments. No one needs a HRM or PM, but they certainly can help.
giobox
chokofingrz wrote:Old-school
chokofingrz wrote:Old-school power measurement: ride the same hill once or twice a week, go hard, and time your ascent. You could even keep a log of the times if you need charts to look at.Sure, you could use a £500 electronic gizmo or a mathematical formula, but time-to-the-top over a set course is really as good a metric as any for the amateur cyclist to track (and improve) their performance.
It really isn’t. This assumes conditions each time you hit that hill are exactly the same. A power meter removes this ambiguity. The idea that an amateur cyclist can’t benefit from a power meter is a myth that some in the road cycling world need to get over.
On a different note, the one thing I really admire about the triathlon community is there is none of this old road racing world dogmatic thinking to be found. An aversion to new technology is a peculiarity of the road racing scene, the tri guys seem far more receptive to innovation. I guess they are not bogged down in the “Merckx only needed [insert remark about number of gears/weight of bike/etc here]” as road riders are.
chokofingrz
Nick T
I should have put /sarcasm in
I should have put /sarcasm in front of my post.
fukawitribe
Nick T wrote:crikey
Nick T wrote:crikey wrote:
Buy a bike with mudguards, buy a decent waterproof.If that doesn’t answer your question, OP, then I don’t know what will.
Something helpful ?
fukawitribe
Nick T wrote:crikey
Something helpful ?
Nick T
crikey wrote:
lolol
surly_by_name wrote:Tell you
surly_by_name wrote:Tell you what, if you pay me £1k I will send you an email after every ride that tells you that you aren’t powerful enough.Like having an accountant to tell you how poor you are
It depends.
Are you going to
It depends.
Are you going to enter races (I include sportives in this; others may not!) – then it could be worthwhile.
If not then it’s probably not worth it. Just don’t hope that Strava’s ‘estimates’ will fill the void!
I got my PT2.4 SL+ on ebay, including a matching front wheel, for less than a set of decent new wheels. I don’t always use it but have found my use on the increase.
Never broken it. Nice to meet you 😉 -
