- This topic has 49 replies, 14 voices, and was last updated 11 years, 6 months ago by
Malc Wiffin.
April 10, 2014 at 12:16 pm #21141
Jack Osbourne snr
Okay… Having decided pretty much within minutes of the launch of the 2014 range of Boardmans that the CX team was the next Cycle2Work commuter bike for me, the time has come to put the thought into action… Nearly.
So… for those that have bought one, what do you think?
Is it the great all-rounder it promised to be?
Is it the perfect fast commuter?
Are there any parts that need swapped out immediately?
Are those wheels truly crap?and… most importantly…how did you get round the mudguard issue at the front? I think I have a couple of viable solutions, but these, like my assessment of the bike itself, are purely on paper at the moment.
Jack Osbourne snr
Even though it’s going back,
Even though it’s going back, here are my first impressions following the ferry run and the first commute:Harsh but responsive ride
Accelerates well
Brakes not so well
Bar tape crap
Wheels needed 2 minutes in the jig of truth
Front mech poor shifting
Strange front brake cable routing. Comes right to left BEHIND the fork?
Interrupter levers too close to centre line for comfortably safe useThis is however a very good bike for the money. Some of the issues above are build related and others are a function of me having not ridden for seven weeks and still being in recovery after crashing.
When I swap this one for the non-cracked replacement it will quickly lose the Interrupters and gain an Ultegra FD and probably acquire better brakes fairly soon after that.
Jack Osbourne snr
Ironically, my hybrid is more
Ironically, my hybrid is more substantially damaged than I had first thought, so I’ve just arrived back from Halfords with my new CX TEAM lol.It’s going back though!!! The seattube crack issue has not been resolved.
newtonuk
Terrible! I must admit, I
Terrible! I must admit, I emailed them every week for several weeks before I got a response.Jack Osbourne snr
newtonuk wrote:Let us know
newtonuk wrote:Let us know how you get on.Well… It’s two weeks later and nobody at Boardman has bothered their arse to reply.
So…I’m not going to bother my arse buying their bike. I’ve repaired my hybrid and that will now go back into full service rather than semi-retirement.
antigee
Quote:Interested by the
Interested by the thoughts on the bb7… I have no experience with them, but thought they were betternot used BB5’s so can’t compare just went with the forum consensus that BB7 better than BB5 as easier to adjust and I built up bike so had choice at not a big price difference
In theory you can turn the inner adjuster by hand on the BB7’s so quick and easy to do – in practise it is hard to turn and often need to dig out torx tool – I think BB5’s don’t have the monkey fingers dial and you have to use the torx tool – if you keep a tool handy it is only a 30second job each wheel then they are a consistent brake – problem is single moving pad design is not for the lazyedit not forgetting that discs are much better than rim brakes when commuting in the wet – I see the Boardman come with bar top levers – great for when sitting up in traffic – as said above downside is limited room for lights
Jack Osbourne snr
Interested by the thoughts on the bb7… I have no experience with them, but thought they were better. Inconsistent braking on my commute could be problematic.
antigee
Not a Boardman CX rider but
Not a Boardman CX rider but some interesting points.
Have a Kinesis Pro6 which I use for gravel trails some single track and commuting – run BB7’s and think the issue for me is lack of predictability. If I’ve remembered to wind in and out recently and I’ve managed to wind the inner side without digging out a torx wrench and are set up how I like then I’m not going to panic and grab too much and lock out in traffic but sometimes the amount of movement is just not what I expect. Much better than rim brakes and simple to set up but you have to do it too often or not consistent enough. So when they are readily available I’ll be fitting some spyres not an obvious design solution (cable to hydraulic) but looks very neat and reviews good. Though I suspect UCI endorsement of road discs is pretty close so might see some other options soon.
As to front mudguards Pro6 comes with eyelets and I’ve run full mudguards but the toe overlap (small frame) when doing “u bends” on bridges needs a lot of careful coordination – so beware you may get mudguards but if your commute has tight turns you may need to be very alertJack Osbourne snr
Bump.
I know there’s another
Bump.I know there’s another couple of CX owners out there…
newtonuk
Let us know how you get on.Jack Osbourne snr
Email to Boardman duly
Email to Boardman duly sent!I’ve set up loads of bb5 brakes for other people, so know what a faff they are… Which I would class as ‘occasionally irritating’. It’s gonna be my grab and go bike so faffing about dialling them in and reducing rub every few days is not a welcome feature.
The bike will be doing 15 miles every weekday so I don’t mind spending a bit on justifiable upgrades and modifications, particularly if it can be spread. It’s my car!
newtonuk
You’re welcome to the
You’re welcome to the mudguard solution 😀 I’ve fed it back to my local Halfords as well, as I am sure that this will be a contentious issue for other potential purchasers. One thing to add though, I had a little exchange of emails with Boardman at the beginning of March who advised that they are currently reviewing an upgraded fork for the CX which includes mudguard eyelets. They couldn’t offer any sort of lead time (other than saying they’re expecting to sign it off soon), but they did say that it would be available to current owners under warranty.I’m considering the TRP Spyres as well, but I’m torn with just how much I want to put into the bike given its role as my year round commuter this year and then my bad weather commuter next. When it comes to replacing the brake pads, I might consider a brake upgrade with a bit more thought. My LBS suggested that removing the interrupters would improve brake feel immediately, so I think that will be the first job.
For your consideration, I’m running 28mm Gatorskin Hardshells and I find that stopping quickly is not hindered by the BB5s, but the rear wheel locking up, especially on a wet road, so the brakes have enough power, but they are faffy to set up and keep set up.
Other than that, one absolute positive that this bike does have is that when I get on my “nice” bike, it feels like a “very nice” bike in comparison (not that there is anything terribly wrong with the CX, it gets far more use than any of my other bikes).
My commute is a 17 mile round trip 3 or 4 days a week and I’ve been within seconds of my best time on the CX which I had set on a Cannondale Synapse previously, so it’s not a bad fast commuter on balance.
Jack Osbourne snr
Interesting differences in
Interesting differences in opinion on the interrupter levers. It’s my plan to run with them initially, at least until I get used to the doubletap levers – my other drop bar bikes are Campagnolo equipped.I’ve had test runs with bb5 flat bar brakes, so I suspect they may be the first thing to get swapped out. I’m pretty certain the double whammy of dropping from hydraulics and moving to road levers will make me want more stopping power. I ride from one side of Glasgow to the other, at peak times and straight through the city centre, so powerful braking is essential. BB7 or TRP Spyre being the likely replacements.
Great suggestion with the bottle cage mounts… Wasn’t on my list of solutions for the front fork/ mudguard issue… It’s now no.1! Mudguards are a year-round essential in this part of the world.
newtonuk
bollandinho wrote:I wouldn’t
bollandinho wrote:I wouldn’t say that a click is inherent to the BB30, given that my Cannondale Synapse has a BB30 and is silent.Strange that, my Cannondale Synapse had a BB30 too and that clicked, and it took several attempts by the LBS to resolve the issue, but eventually they did.
Unfortunately, my Synapse 6 found it’s way under the front of a car whilst I was on it. Fortunately the Synapse Carbon 6 that replaced it, which also has a BB30 (BB30A), hasn’t shown any BB issues.
I’m running a Cateye Volt 300 at the moment and yes, it sits above the interrupter levers so it doesn’t interfere with them.
However, how about contributing an answer to the OPs question?
bollandinho
Oh, and I’ve found that a Cat
Oh, and I’ve found that a Cat Eye mounting is so flat on the bars that you can fit it on around the extra levers very easily. I know a lot of people hate them, but I find them really useful when I’m sitting at lights, especially on a hill.bollandinho
I wouldn’t say that a click is inherent to the BB30, given that my Cannondale Synapse has a BB30 and is silent. It’s more inherent to Halfords. My Boardman became far better once I took it to someone who knows there way around those components, and that really isn’t the case at Halfords in my experience. -
