Back pain and stem length/saddle position
  • #21099
    road
    Hi there
    I have had my Cannondale CAAD10 for around 12 months now and have struggled a little with the fit since I had it.
    I bought it from Epic Cycles in Ludlow and had their proper fitting at the time.
    It’s a 56 frame, but I am 6’0-6’1 and my other bikes (a Charge Filter, now replaced with a Genesis Equilibrium) are a 58.
    I have regularly suffered with lower back pain which I have noticed moreso on the Cannondale. This tends to be after about 20 miles. I highlighted this to Epic a little while after I had bought the bike and they suggested moving the saddle back a bit (which I have done a couple of times) and if that doesn’t work, to fit a shorter stem.
    I am of the opinion that the frame might be slightly too small for me.
    Logic would dictate that if it’s too small for me, a longer stem might help, but Epic seemed to think a shorter stem would push me more upright, thus putting less strain on my back as I’m not reaching as far.
    I have checked as best I can, and the saddle height would appear to be ok, as my hips don’t rock.
    It has a 100mm stem on it at the moment, and I’ve just ordered a 90mm to give that a try.
    I wondered if anyone had had a similar situation and how they solved it? Would a longer stem work instead?
Viewing 15 replies - 1 through 15 (of 16 total)
  • #784739
    Nixster
    I’m on a Supersix which has
    I’m on a Supersix which has the same geo as the CAAD 10 having moved from a Synapse. The Supersix is a 50 and the Synapse was a 54 which looks like a massive change in sizes but the top tube difference is only 15mm. The cannondale racing geo is stretched out so a 56 CAAD 10 could well fit you for reach as well as a 58 Genesis. The head tubes are relatively short however and I’ve found I’ve swapped upper back discomfort for lower back discomfort! Happens after the ride not during though, which I take some comfort from.
    It seems in my case the reason is quite a steep increase in saddle to bar drop, which I am hoping will resolve itself by getting all the spacers under the stem and working on strength and flexibility before trying to move it down. Your situation sounds similar in some ways and those things are free to try first if like me £100+ on a bike fit is out of the question.
    #784737
    I’ve tried flipping the
    I’ve tried flipping the original stem and will see how that goes. Should hopefully stop me reaching too low which might be causing the back strain
    #784735
    Brown dog
    I had the same problem on
    I had the same problem on both of my bikes with back pain after riding for about 1h. If you are getting back pain when you are riding it may be an idea to get your back checked out.
    Any chiropractor should be able to asses your back and sort out the problem in a few sessions …….
    #784733
    glynr36
    If you’re looking for a Retul
    If you’re looking for a Retul and are in the Midlands, give dynamic rides a try
    #784731
    Jimmy Ray Will
    Lower back pain is generally
    Lower back pain is generally caused by cramp in the supportive muscles at the base of the spine.
    Now the reason they cramp is because they are working harder than they can sustain.
    As highlighted here, there are two answers to your problem; 1. make the muscles stronger so that they can resist the workload being asked of them, 2. change your position to lessen the strain on the muscles.
    option 2. is by far the best route in the short term.
    In my experience, the pain is caused when the angle in the hip is too extreme, and isolates the stabilising muscles at the base of the spine. This can be caused by a host of reasons, from the saddle being too high, too far forward, more than likely too far back, or indeed the bars being too far away and too low. It can also be that the saddle is too low, and in a way to counter this, you move your body position back, which in turn then makes the hip angle more acute.
    So… without seeing you on the bike its hard to say.
    it could also be that the bike fit has simply allowed you to engage those muscles in the back for the first time and they are going to need some time.
    What you mention about the shoes is interesting…
    What size feet do you take? When on the bike, do you hang off the back of the saddle or sit in the middle?
    I’m interested in the hand numbness… that is generally because the saddle is too far forward, or the reach is too long… which is kind of counter to the cause of lower back pain… unless you were super stretched out. Which your comments of feeling like the bike is small, kind of goes against.
    #784729
    harman_mogul wrote:My
    harman_mogul wrote:
    My 2d-worth: my Cervélo also gave me severe lower back pain when first set up for me. (I do suffer from back pain generally, but this was severe.)
    Of all the tweaks tried, by far the best was to swap to an inline seatpost (a Syntace P6). This has pretty much banished the pain.
    I surmise the problem with the standard setback post was that I was sticking my arse out too far backwards.
    Presumably nudging the saddle forward might be worth a try then?
    I have a Selle SMP Drakon which has loads of room on the rails
    #784727
    harman_mogul
    #784725
    mcvittees73 wrote:To add to
    mcvittees73 wrote:
    To add to the comments already posted, can I suggest adding a routine of situps, superman and plank core work? I’ve found that the stronger my core is the better I’ve been at adapting to my bike postition (e.g. as I’ve gradually lowered my stem). The exercises really do work and can completely elimate back pain.
    My core is pretty weak but I never really have the discipline to do regular core exercises and find them incredibly boring. Perhaps it’s time I gave it a go properly.
    #784723
    Having re-read the emails
    Having re-read the emails from Epic about the fit, the saddle retreat and stem reduction were to attempt to fix the other problem I had at the time, being numbness in my fingers. This now seems to have been alleviated a little by wearing padded mitts and the saddle retreat.
    I think I have been noticing the pain again in my back as I have recently changed shoes from a bog-standard DHB R1.0 to some Fizik R1s which have quite a high depth of sole, and therefore raised the saddle accordingly.
    I will try the fore/aft adjustment and the shorter stem.
    If the frame feels too small, presumably a longer stem would help instead?
    #784721
    jmaccelari
    I had exactly the same
    I had exactly the same problem on one of my bikes, with lower back pain after an hour or so in the saddle.
    I replaced the standard 120mm stem with a 90mm one (a big change) and that has sorted the problem out.
    #784719
    Cantab
    I’m not expert on bike fit,
    I’m not expert on bike fit, always relied on trial and error tweaking, to get bikes ‘just so’. What you describe to me sounds like being stretched out too much (ie having to bend the lower back more to reach the bars), so a smaller frame and a shorter stem would be better. Your LBS recommending moving the saddle back but shortening the stem seems paradoxical to me, one will stretch you out, the other will let you be more upright.
    I don’t have time to look them up just now, but what are the relative head tube heights of your various steeds? Again a taller head tube (normally on a larger frame) will sit you more upright, requiring less bend and hopefully less pain.
    Retul fittings like Mooleur suggested have a good reputation might help, though if your frame is the wrong size in one way or another, there is probably a limit to how much can be done even with different stems etc.
    #784717
    mcvittees73
    #784715
    zzgavin
    check the handlebar width, my
    check the handlebar width, my CAAD10 is a 60cm and it came with gigantic 47cm bars, which gave me shoulder and neck pain. Cannondale seem to scale the bar width pretty rapidly. The saddle to bar drop is pretty big too, as the head tube is pretty short. when it fits it’s a great frame, I’ve raced it, ridden 100 miles plus many times and ridden it through the alps and pyrenees three years running.
    In terms of lower back pain, a brilliant stretch is to work out your glutes is this one
    I do this about once a week and after hard rides, particularly racing and it really helps, can feel quite amazing in fact.
    #784713
    The stem on the CAAD10 has a
    The stem on the CAAD10 has a couple of spacers and is the “normal” way up as far as I am aware.
    There are a couple of bike fitting places local to me – MidlandBikeFit who use a “Dynamic Fitting System” (midlandbikefit.com), which would seem to be similar to a Retul fitting but half the price?
    #784711
    SamShaw
    A CAAD10 will have a
    A CAAD10 will have a different head tube to your Charge & Genesis, probably much shorter, giving a lower drop from the saddle to handlebar. Is the stem slammed? Do you have the stem angled down? Bringing it up might help.
    First thing to do is to measure up the bike that is comfy and set your CAAD10 to the same dimensions: reach, bar drop and saddle setback are the things that resolved the issues I had with lower back pain. 10mins with a tape measure and a plumb line will let you know where things need to be moved and dictated what stem you need to buy.
    That and doing plenty of hamstring stretches!
    EDIT: I’d also recommend a Retül fit. I’ve not had any problems whatsoever since getting it done. http://road.cc/content/blog/88098-get-fit-get-bike-fit-experiencing-ret%C3%BCl
