Back pain and stem length/saddle position
  • #21099
    road
    Hi there
    I have had my Cannondale CAAD10 for around 12 months now and have struggled a little with the fit since I had it.
    I bought it from Epic Cycles in Ludlow and had their proper fitting at the time.
    It’s a 56 frame, but I am 6’0-6’1 and my other bikes (a Charge Filter, now replaced with a Genesis Equilibrium) are a 58.
    I have regularly suffered with lower back pain which I have noticed moreso on the Cannondale. This tends to be after about 20 miles. I highlighted this to Epic a little while after I had bought the bike and they suggested moving the saddle back a bit (which I have done a couple of times) and if that doesn’t work, to fit a shorter stem.
    I am of the opinion that the frame might be slightly too small for me.
    Logic would dictate that if it’s too small for me, a longer stem might help, but Epic seemed to think a shorter stem would push me more upright, thus putting less strain on my back as I’m not reaching as far.
    I have checked as best I can, and the saddle height would appear to be ok, as my hips don’t rock.
    It has a 100mm stem on it at the moment, and I’ve just ordered a 90mm to give that a try.
    I wondered if anyone had had a similar situation and how they solved it? Would a longer stem work instead?
Viewing 16 replies (of 16 total)
  • #784709
    mooleur
    I struggled with proper fit
    I struggled with proper fit after having a regular fitting at my LBS a couple of years ago. Constantly tweaking here and there.
    I know it’s kind of expensive but I can’t recommend Retul fitting enough, if you shop around you should find someone (usually not an LBS but a lot of coaching services do it) that does it.
    I’d particularly struggled after damaging my knees and shoulders after a couple of altercations with iron horses, despite the bike being fitted no amount of fettling seemed to ease these issues. Got a Retul done and lo and behold all pain just disappeared, even my power output was higher.
    On the saddle, I find if my lower back is hurting it’s usually a wee spot too low…but I’m no Dr or expert so probably don’t take my advice there! Everyone is different.
    I’ve since bought a new bike and I’ve tried to fit it the same myself and it’s just horrendous, I’ll be taking it back for a Retul fit asap!
