- This topic has 16 replies, 11 voices, and was last updated 12 years, 8 months ago by
Nat Jas Moe.
February 25, 2014 at 9:08 am #20794
Miles253
Hey guys
So I’m looking to have a little update of my cycle wardrobe, with a keen internet on covering all the bases for riding year round.
What’s very confusing is the combination of apparel required for all weather without in fact buying the lot and requiring a small loan.Naturally I already have shoes, caps a race cape and regular summer jerseys. I also currently go by the arm and leg warmer approach and I don’t own a base layer or bib tights ( only bib shorts) What else would you guys advise I invest in?
Long sleee jerseys? Windproof?
Softshell, hardshell, racecape?
Overshoes, over socks, winter socks ?So ruddy confusing!
Nat Jas Moe
Miles253 wrote:Nat Jas Moe
Miles253 wrote:Nat Jas Moe wrote:I’ve used these and find them okish as I commute there is plenty of left foot down at junctions and lights and unsurprisingly that one has secummed to duck tape to hold it in place. They have lasted about 4 months of fairly constant use 10 journeys a week. Not sure if this is good or bad really as I’ve not used any other make recently did have a pair of nw ones which were ok but suffered the same.e wear fait.What did they set you back for four months worth of wear?
Fabric backed gilets, great tip, ill do some research, if anyone has one they get I really well with point it out.
They set me back £25 or there about
dunnoh
My essential kit is a Helly
My essential kit is a Helly Hansen Lifa Dry base layer. Its ace and I wear one for at least 6 months of the year. I have tried loads of base layers and I always come back to these.Miles253
Nat Jas Moe
I’ve used these and find them okish as I commute there is plenty of left foot down at junctions and lights and unsurprisingly that one has secummed to duck tape to hold it in place. They have lasted about 4 months of fairly constant use 10 journeys a week. Not sure if this is good or bad really as I’ve not used any other make recently did have a pair of nw ones which were ok but suffered the same.e wear fait.movingtarget
Miles253 wrote:so you find a
Miles253 wrote:so you find a heavy overshell a touch to much overkill? That’s good news because those things are expensive! Can anybody recommend a good gilet? I’ve got a sportful one currently, windproof but not too warm. And also some overshoes?Not to knock waterproof shells as I’m sure some people find them useful, like commuting in steady, heavy rain, but for the type of riding I do their cons (not breathing well and getting soaked from sweating) cancel the rainproof benefits. I work from home so don’t have to commute so my rides are purely recreational/for training so I tend to go for speed and climbs. I find that as long as I’m exerting myself sufficiently a winter jacket with windproof and thermal panels that’s got a water-resistant treatment keeps me warm and allows sweat to evaporate. I also have the luxury of opting not to ride in heavy rain/downpour but a steady rain won’t cause me too much trouble, just a bit damp but not enough to make me uncomfortably cold.
Quite a few different companies make vest or gilets as you say across the pond with a solid fabric back instead of the mesh back which you might find warmer. (Capo Pursuit vest or Capo Padrone vest which has super roubaix insulation in addition to windproof fabric. I use their mesh backed vests with a long sleeve jersey when it’s below 15C and with a short sleeved jersey 20C. Campagnolo was really good about making solid fabric backed gilets for mountain descents if you can still find them. Too bad they stopped making kit. RIP.)
Hopefully someone who’s had luck with shoe covers will chime in as I’d be interested to find a more durable option. Have heard about Endura’s Kevlar fabric toed and bottomed ones but don’t know anyone who’s tried them.
arfa
There is some good value bits
There is some good value bits and pieces here http://www.cycle-clothes.co.uk/all-products/?type=road-cycling
The tenn overshoes are perfectly good and their bib shorts are good tooMiles253
Great post! Thank you. Very
Great post! Thank you. Very incitefull, so you find a heavy overshell a touch to much overkill? That’s good news because those things are expensive! Can anybody recommend a good gilet? I’ve got a sportful one currently, windproof but not too warm. And also some overshoes? I’ve never had luck with these. Ill definitely grab myself a decent base layer as well so thanks for the advice.movingtarget
The kit that gets the most
The kit that gets the most wear for me in the off-season are:–Long sleeve baselayer top (Castelli Iride): great moisture wicking so my skin stays dry and it’s easier to stay warm (your outer layer/long sleeve jersey or jacket will get wet from sweat wicking out). Similar principle in hot weather but with a thinner mesh sleeveless baselayer, wicks sweat to the surface so you can continue to stay cool through evaporation. Need to be good about hydration though. (Castelli core mesh sleeveless base layer–reviewed on road.cc http://road.cc/content/review/87361-castelli-core-mesh-sleeveless-base-layer And yes, your partner may choke to death on their tongue while asking you if they come with tassels but you can laugh yourself off the saddle when they’re prostrate from heat stroke halfway into the ride)
–Windproof winter jacket with thermo or super roubaix insulation and torso zip vents for when you get hot on climbs (Giordana Forma Red Carbon jacket)
-Wind vest for spring/fall when just a jersey is too cold but too warm for a jacket
–Bib knickers with windproof and thermo roubaix insulation panels, it’s mainly 0-10C where I live in the winter so although I have windproof, insulated full length bib tights I find that I almost never wear them as they’re too hot for the milder winters we have (Capo Padrone bib knickers). After having switched to bibs over shorts/tights I will never go back. They stay in place so you can forget about them and don’t dig into your waist when in the cycling position/waistband doesn’t roll over and drive you insane while you’re fiddling around trying to surreptitiously yank them up.
–Windproof, water resistant, insulated gloves with silicone palms for sure grip even when your bars are wet. Hard to shift/control the bike when your hands feel like blocks of ice (Castelli CW 3.1 gloves are so warm I can’t wear them if it’s warmer than 7C and I tend to run cold. They also can activate touch screens although I find the contact point is rather finicky. When it’s above 7C I love my Castelli Lightness gloves–water repellent with light thermoflex insulation and lots of dexterity. Almost no padding which I prefer but might be uncomfortable for some.)
–Wind and waterproof shoe covers keep my toes toasty and dry.
–Thermal headband to keep the ears warm. Makes a huge difference for me in terms of comfort and perceived warmth (Castelli Viva thermo headband)While I do have a waterproof cycling shell, I rarely wear it even though it rains throughout the winter here cuz while they keep the rain from getting you wet, they don’t breath well so you end up steaming in your own sweat so different kind of wet :S
I have expensive kit but except for the shoe covers (never been able to keep a pair alive longer than a season), they should last years unless you crash. I’m also small so I fit Euro whippet sx or small kit which usually gets heavily discounted 🙂
Miles253
Do Aldi always sell them or
Do Aldi always sell them or is it a once a year deal. Base layers confuse me, I see you can wear them in the summer and the winter, how does that work? Are there several types?
Beefy
Aldi compression base layers
Aldi compression base layers are fab! I usually think you get what you pay for but there base layers are as good as ones I have payed four times as much for.Martyn_K
I bought a pair of DHB Vaeon
I bought a pair of DHB Vaeon Zero bib tights for this winter and they have been awesome. A nice windproof panel on the front covers the shins and thigh offering good protection.Arm warmers with s/s base layer under long sleeve jersey provide options and then a fantastic Rapha gilet to keep the top half warm.
Endura neoprene shoe covers and sealskin gloves complete the winter get up.
zzgavin
A windstopper jersey is a
A windstopper jersey is a great thing if you ride in the cold or do long descents. Just bought a windstopper base layer, clever thing.
The nano flex castelli arm and knee warmers are fabulous.
Buy the nicest bib shorts you can find and do try them on, so much more comfortable than plain shorts. Try on a few brands and get the fit right, it should be comfortable in a bike shape and perhaps a bit tight when stood up, don’t get it too big around the waist, as it will shift about. You might be different sizes in bibshorts and tights. I’m a medium in castelli shorts, but a large in 3/4 and tights, due to leg length.
I also really like the craft sleeveless mesh base layer, very comfortable, these should be close fitting to work properly.Miles253
Great advice here guys,
Great advice here guys, thanks. So far, I feel a base layer and a lighter waterproof layer are essential, as are protecting the extremities. What about bib tights, thermo suits and long sleeve jerseys wind stopper or otherwise? Are they worth owning or is it better to just layer with arm warmers and leg warmers?Cheers
bollandinho
I’ve used two of these dhb
I’ve used two of these dhb long sleeve windslam jerseys for the winter (http://www.wiggle.co.uk/dhb-windslam-roubaix-long-sleeve-jersey/), and unless it’s raining heavily, they’ve stood up to a Glasgow commute.They’re pretty warm, and the windproofing on the front means that I really don’t feel the need for a softshell or anything over it unless it’s for some serious waterproofing.
Also, I’d recommend getting really good boots and gloves for the winter. Warm hands and feet are essential for me, so I got some Specialized Defroster boots on sale, and I wear Castelli Estremo gloves. Both are great.
Hope that helps.
stenmeister
My two essential
My two essential recommendations are good quality baselayers and a gilet(vest).I initially used compression baselayers which were okay but this winter I have been using a long sleeve merino wool baselayer and it’s fantastic. Not only is it warm but the problem of overheating and sweating during a winter ride is a thing of the past. Next on my wishlist is one of Castelli’s Flanders baselayers.
I was dubious about buying a gilet but it bridges the gap between wearing a soft shell jacket and summer jersey. I now have two, one which is more of a windstopper and which is use for early morning cycles and the other is which is a packable waterproof one which I carry in case the weather changes for the worst.
