‘cafe’ bike lock
  • This topic has 12 replies, 11 voices, and was last updated 10 years ago by Simon E.
  • #20675
    lisa76uk
    I’ve searched the forum and online and got a good idea of some lightweight ‘deterrent’ locks for use while out on rides if I need to run into a shop/toilet. My Hiplok is great for commuting but will be holding me back on Strava :^o
    I’ve narrowed it down to two that look ok as a ‘deterrent’. Has anyone here used either of them?
    Knog Milkman… http://tinyurl.com/nafxtgf
    Kryptonite KryptoFlex R4… http://tinyurl.com/qzyg4gr
    Thanks in advance!
  • #773579
    Those wire ones look like
    Those wire ones look like they could be snipped with a pair of pliers or the cable easily wrenched from the casing. Visually not much of a deterrent either.
    I have 2 thicker coiled cable 4-digit combination locks very similar to this Abus one for £13 on ebay. They feel solid, clicks are precise and the numbers are clear and easy to see, which is handy when you leave the pub a little later than planned 😉
    #773577
    ClubSmed
    I use this for quick stops:
    https://www.evanscycles.com/abus-1200-combination-chain-lock-EV167195
    It is permanently wrapped around the head tube (in-between the top tube and down tube) so it’s never in the way and weighs little at 136g . I feel confident enough that it can’t be easily cut with pocket sized cutters and as the code isn’t changeable I feel that it may be a little harder to crack too.
    #773575
    dottigirl
    Any more current
    Any more current recommendations please?
    #773573
    philtregear
    brilliant idea. thank you.
    brilliant idea. thank you. just bought one from ebay
    #773571
    dafyddp
    I’ve got a 99p lock from
    I’ve got a 99p lock from Planet X. That’s about ‘3% of the winter bike’s value, so definitely not recommended for more than a quick cafe stop (in very low-crime areas). They do quite a few options for that price, although you need to spend £20 to get free delivery so not really worth buying by itself
    http://www.planetx.co.uk/c/q/accessories/bike-accessories/bike-locks
    #773569
    Stumps
    robdaykin, i liked the look
    robdaykin, i liked the look of that laptop lock so much i’ve gone and bought one. The noise it makes is what made my mind up. Cheers bud.
    #773567
    Shades
    I use a Kryptonite but the
    I use a Kryptonite but the Targus option is good idea.
    Had a conundrum last year whilst road riding in France. Was going to be out all day and stopping for lunch/sightseeing in a town with a concern that the bike would be out of sight. After some thought (cables, chains, hip lock etc) I managed to work out how to carry an Abus Mini-U Lock I use for commuting. The barrel went in the seat pack (large Specialized one) and the U fitted quite snugly between the seat pack and the saddle (held in place by the straps). OK, it was extra weight but rather that than having the bike nicked.
    #773565
    notfastenough
    robdaykin wrote:I use a
    [quote=robdaykin]I use a laptop cable lock with a motion sensor. Doesn’t look much, but the blinking red light and loud klaxon when interfered with have the desired effect. Also fits in a jersey pocket.
    That looks like a great option.
    #773563
    lisa76uk
    Shamblesuk wrote:My local 99p
    Shamblesuk wrote:
    My local 99p (you know, the chain of them) shop sells one that is a pretty good deterent and it costs……..
    They also sell a perfectly functional mudguard set for……..wait for it………
    thanks! I’ll have a look in there
    #773561
    Shamblesuk
    #773559
    lisa76uk
    Ah, that’s something I hadn’t considered and the cable length and diameter (for what it’s worth) look the same as the others too. Thanks for that!
    #773557
