8 speed-9 speed chain
  • #20526
    big mick
    Just a question.Will a 9 speed chain work with an 8 speed index system.It looks the same width to the naked eye
  • #769671
    Flying Scot
    I use the same chain for 6,
    I use the same chain for 6, 7, 8 and 9 with no issues.
    I believe the 10 is narrower and the 11 entirely different.
    #769669
    Matt eaton
    It should be fine. I’m
    It should be fine. I’m running a 10 speed cassette and chain with old ‘7 speed’ chainrings. The only time I think you are going to have problems is if you try to run any 8-9-10-11 speed chain on a single speed set-up designed for 1/8 inch chains.
    #769667
    yenrod
    Don’t know if this is much
    Don’t know if this is much use to you but I once swapped from 9 to 10 but swapped back.
    I then used the 10spd chain on the 9 spd block – no probs.
    So, technically, try it..what have you to lose ? 😉
    #769665
    glynr36
    9 speed is narrower, years
    9 speed is narrower, years ago I tried this and it won’t seat properly in the cassette.
