Rear wheel pulling out of dropouts
  • This topic has 37 replies, 17 voices, and was last updated 11 years ago by tyceman.
  • #20490
    Jack Osbourne snr
    Dear Learned Friends,
    Any sage advice welcome to help solve an annoying issue…
    On and off, for about two years, I have found myself pulling my back wheel out of the dropouts when climbing out of the saddle. I’m getting very fed up having to stop and reset my wheel on hills.
    Wheel pulls out of drive side dropout and wedges on non drive seatstay
    Frame and dropouts are titanium
    Wheels are Prolite Bracciano
    I’ve tried a few things, but nothing seems to work consistently:
    Changed stock open cam skewers to closed cam levers.
    Added serrated washer to drive side
    Experimented with monster clamping force and different lever positions
    Any ideas how to stop this? Would roughing up the dropout surfaces help? If so what with and by how much?
Viewing 7 replies - 31 through 37 (of 37 total)
  • #768657
    Jack Osbourne snr
    Flying Scot wrote:This sounds
    Flying Scot wrote:
    This sounds like a classic case of the axle not being centred in the hub – which means that the quick release is binding down hard on the end of the axle rather than on the drop out. Count the number of axle threads protruding from the drop out – they should be equal.
    …Only thing is, these aren’t cup and cone hubs are they?
    So can you actually re-centre the axle, IIRC, the non drive side just taps in with a fixed cone and you adjust the drive side.
    If only it was. I ruled this out at the roadside the first time this happened.
    This isn’t the issue as there is about 2mm between the outside edge of the axle and the outside of the dropout with the QR out. Both sides appear equal and the gap drops equally under compression from the QR. At no point is the end of the axle any closer than 1mm to the
    Inside faces of the QR.
    Prolite Bracciano wheels have cartridge bearing hubs, so no adjustment as with cup n cone.
    #768655
    Flying Scot
    #768653
    Jack Osbourne snr
    Let’s imagine that I can lay
    Let’s imagine that I can lay down the power, if not for long! I’m more Jan Ulrich than Marco Pantani when it comes to climbing style…but only style.
    I haven’t tried another wheel, no. That would have been the obvious thing to do #o
    Not the best of pics…
    #768651
    jason.timothy.jones
    looks deep enough, but it is
    looks deep enough, but it is a bit rounded to the front, but I cant imagine that would be the problem if the QR is tight enough
    im stumped
    #768649
    allez neg
    Have you replicated the
    Have you replicated the problem with a different wheel?
    #768647
    jason.timothy.jones
    can you take a photo of the
    can you take a photo of the drive side dropout and post here?
    #768645
    allez neg
    Pass.
    (Other than saying get
    Pass.
    (Other than saying get thee to a frame builder so they can check alignment of the frame/dropouts and hub width)
    Do you have legs that make Rob Forstermann look like Charles Hawtrey?
