- This topic has 19 replies, 14 voices, and was last updated 12 years, 10 months ago by
Welsh boy.
January 12, 2014 at 11:25 am #20452
jasonm945
So ultimately the question is, are Sram Rival shifters and rear mech an “upgrade” or am I just spending money for the sake of it?
I do prefer sram’s clunkiness(?) on my MTB but not sure if that would cross over to the road, I am also finding that my 105 is very woolly and occasionally misses a shift (especially going down the cassette).
Suggestions?
Thanks
Jay
Welsh boy
In answer to the original
In answer to the original question, SRAM is much crisper than Shimano equivalent. I have never had to feather a change on my SRAM kit but it is a regular occurrence on the Shimano stuff. However, if your 105 has been good at some time, new cables will probably restore it to its former condition.jasonm945
Quote:jasonm945: You can’t
[quote]jasonm945: You can’t just replace the 105 levers with the Sram Rival levers. The cable pull ratio is different.You can swap cassettes and cranks, but you can’t mix levers and rear mechs:
http://sheldonbrown.com/drivetrain-mixing.shtml
Thank you for that, I wasn’t asking about mixing parts I was asking about SRAM rival in general, but I will heed your warning 😉 😉
matthewn5
Be warned!
700c
are people saying
are people saying ‘industrial’ when they mean ‘agricultural’ (i.e. clunky) ?!105 on the GF’s bike shifts well, in a crisp, industrial manner. which I would call utilitarian. That’s not a bad thing for a shifter! New cables and moving parts kept clean and well lubricated.
For comparison, Campagnolo Veloce action on my bike is lighter, more based on feel, I’m used to it so I like it. Not as reliable shifting as her lightly used 105 though, but it’s over 4 years old and still works!
As others have said, just clean thoroughly, re-adjust, replace cables if necessary, is my recommendation. no need to spend £££
jasonm945
Ahhhh, I think the nail has
Ahhhh, I think the nail has been well and truly hit on the head. When I shift with the brake lever the action is fairly light and barely audible clicks don’t help. I am starting to “feel” with my feet when the chain slips down to the next gear and this was what I translated as “woolly”.
I am looking for a more “positive” clunk and this was the question as I was asking about SRAM Rival (I can’t afford Force or Red prices)!
I believe the question has been answered, now how much will I get for a set of 2nd hand 5700 shifters and mech 😉Jay
ajmarshal1
Bigcog wrote:I ran the Scott
Bigcog wrote:I ran the Scott CR1 team on the 105s for at least 7000kms, and traded up to Ultegra. I can tell you that it was a night and day experience for me..I agree that you need to be happy with your cables and set up – my 105s were great for a long time – but even after servicing were never as direct and positive as the ultegra have been since day 1.
Well worth the upgrade if you ask me. B-)
I have to disagree here. I would put that ‘night and day’ difference down to your 105 being a bit aged after 7000kms. I have a 105 bike and an Ultegra bike and I would defy anyone to tell the difference in a blind test. Weight aside, I sure as hell can’t.
Well maintained, 105 is all the groupset most of us will ever need* IMO and for the price Ultegra isn’t worth the cost to upgrade unless you get it at a good price on a whole new bike.
*Need not want. Otherwise I wouldn’t be saving for SR.
therevokid
went from apex/force to
went from apex/force to Athena 11. Campag is crisp and exact, SRAM was,
as noted, industrial and positive.Thinks of it like this …
Shimano you barely feel.
Campag you get a click.
SRAM you get a clunk.Of them all campag everytime but to get over the “softness” of 105 I think
that SRAM will give you what you’re after ….hill4544
I moved over from Shimano to
I moved over from Shimano to Campy on all of my bikes. Never looked back and never will
matthewn5
Ultegra give you amazing
Ultegra give you amazing shifts, especially the 6600 series with exposed cables, light and precise as you could want. You can pick up a pair of ST-6600 shifters, an RD-6600 and an FD-6600 very cheaply on Ebay. Worth the (minimal) expense if you’re unhappy with 105, as you can sell the 105 on Ebay afterwards.But as I said, if you want a more ‘industrial’ feel, replace the top guide pulley with one of these:
That WILL give you more positive shifts, but at the expense of a (very) little harshness.
jasonm945
I think I am getting away
I think I am getting away from the main thrust of the thread. I have no problems with my 105’s, I just don’t like the way they feel. I was wondering if the Rivals were an upgrade or just a waste of money.
I know that Ultegra is an upgrade but again will they be the same as 105’s but even lighter.
Either way I will probably upgrade, I can get the (seemingly) more expensive Rivals for slightly less than Ultegra!Jay
Bigcog
mooleur
I’d have a look at those
I’d have a look at those cables to be honest, my 105 eats through ’em at a rapid rate in comparison to Ultegra. You shouldn’t have any issues with poorer shifting unless something is wrong, as others have said 105’s reliable as anything.Every time mine slips it’s always the cables that either need a bit of a tweak or just all out replacing. I’ve done about 10k km’s on mine and have only needed to replace the chain & casette once, but cables have been done about three or four times, aside from that it just keeps going!
If you’re thinking of upgrading (I can’t comment on SRAM) Ultegra overall is only about 280grams lighter and there really isn’t too much in performance.
racingcondor
SRAM is that bit more
SRAM is that bit more industrial (I also like that about it) but I’d definitely recommend new cables including the housing first. Moving to SRAM should give you that positive feel but it’s a very expensive option for a small change in feel.Jagwire is good, Yokozuna is even better. Try to avoid tight curves in the housing too when you install it.
LondonDynaslow
I think you need to adjust
I think you need to adjust your cables and lube the pawls. If that doesn’t fix it, new cables. If that doesn’t fix it, downgrade to Tiagra. I find 105 shifters quite firm compared to Ultegra (but just as good at shifting) and people say they get even heavier further down the range. Anyway, 105s are brilliant – unless they’re worn out, you should be able to get lovely shifts.bendertherobot
jasonm945 wrote:Don’t get me
jasonm945 wrote:Don’t get me wrong my 105 is usually faultless, I just sometimes over shift but only move 1 cog. I also don’t feel the shifts are “positive”. Are sram shifters as industrial as they are on MTB’s?Depends what you mean by industrial! I quite like my X9 shifters.
105 is smoother than SRAM Apex (for example). Apex is more positive. Not industrial, just positive. Like Camapg in that respect.
Personally I find that Shimano from Tiagra to Dura Ace feels the same, but gets lighter.
SRAM has some differences in feel. SRAM Red 2013 is like butter. As close to electronic without batteries as its possible to be.
But, as others have said, it’s unlikely your issues are group set related.
