- This topic has 49 replies, 43 voices, and was last updated 10 years, 9 months ago by
TFR.
December 2, 2013 at 10:50 pm #20299
Dinners
As soon as I slid at a mini roundabout I realised I need some better tyres for this weather. My frame will probably only accommodate 25s. What would suit?
TFR
specialized armadillo elite
specialized armadillo elite on my winter trainer/commutter. Not had a puncture in 2 years and they last for ever.
DaveE128
GP4Seasons give better grip
GP4Seasons give better grip than gatorskins in the wet and roll well. However, I have killed three on potholes, so the casing isn’t super-strong. They are a goood tyre for year-round use, as the name implies.
Richard D
I’ve used Gatorskins without
I’ve used Gatorskins without incident for the last five years, though I’ve never felt that they were unusually grippy.
In May I bought some new wheels which had Mavic Yksion tyres on them. I crashed in the wet in June when the front wheel just washed out from under me on a fast bend, broke my femur and haven’t been able to ride since.
So I can’t recommend them as winter tyres, and given our summers, I wouldn’t even recommend the Mavics for that.
And its looking increasingly like “winter riding” is something I won’t need to worry about until winter 16/17.
DaveE128
GP4Seasons grip better than
GP4Seasons grip better than gatorskins in the wet, and I think they are faster (they are pretty good all year actually) but I think they probably wear faster.
monkeyhumanoid
I use Vittoria Open Pave
I use Vittoria Open Pave which were designed for riding on wet cobbles. Great grip and only had one puncture from a piece of glass which would probably be the case with any other tyre. I reckon I can get 2500 to 3000 miles on them before I feel they need changing. I had 24mm before but have swapped to 27mm this year and they are pretty comfortable.
Shades
Schwalbe Marathon Plus,
Schwalbe Marathon Plus, although recently wore a set out and slipped (and fell) on day 2 with the new ones! Might need a bit of wearing in. Currently trying the lower pressure/ride less aggressively approach for winter/wet conditions. Pretty ‘bomb proof’ but if you do get a flat, they’re a real b#tch to get off and on again.peghook
I recently swithed from 25mm
I recently swithed from 25mm Continental Gatorskins to 25mm Vittoria Rubino pro techs, since the rain keeps falling. I have found them to be pretty reliable in storm like conditions, riding through gravel, wet (raised) road markings, mini-roundabouts, mud and fallen leaves. From my experiences so far I feel much more comfortable riding on the Vittoria’s over the Gatorskins, when wet.
surfingalan
Well that’s it just fitted
Well that’s it just fitted conti 4 seasons after slipping on my gatorskins. So here’s hoping for some weather that’s not too extreme to try them out.edster99
dunnoh wrote:Vittoria Pave’s.
dunnoh wrote:Vittoria Pave’s. Honest they saved my bacon the other night when I hit a patch of mud at speed. I know that any other tyre would have gone but they just caught hold. They are silly expensive but I just wont go with any other tyre anymoreI’m using them too this winter (tubs) and they are excellent. Running at about 85psi and no punctures, no terror.
Cyclist
Have used shwalbe luganos
Have used shwalbe luganos 23mm solid black with green slime tubes for the last 3 years, never had a single issue other than when a broken beer bottle slashed the tyre last New Year’s Day. Only change to MTB when snowing, other than that, every element that comes I use that combo. My expierience has let me to the conclusion that the more grip/pattern a tyre has less surface contact you have. I have used winter/rain specific tyres and fallen off on a few occasions. For me this is MY perfect combo. I run them between 80-90 psi, depending on conditions.Kinggary
I use 4 seasons 25mm all year
I use 4 seasons 25mm all year round. I did use gatorskins previously and the ride difference between the two is surprising.
The gatorskins were far from puncture proof on winter country lanes and the grip and ride was in my opinion very poor. They did wear well, but that offered little compensation when I ended up on my ass last year.
PSA: 2 x Durano 700×32 (new)
PSA: 2 x Durano 700×32 (new) on ebay. £9.95 and zero bids, auction ends on the 17th – http://www.ebay.co.uk/itm/161171647787Parker International, sponsor of the Shropshire inter-club time trial series for a number of years, are closing down so flogging off various items cheaply.
These are excellent winter tyres. I was going to bid but unfortunately 32mm is too big for my SCR’s mudguards 🙁
Craig0605
I run Michelin Pro 4 service
I run Michelin Pro 4 service course all year round with no problems what so ever. Never slipped in the wet even on greasy roads and roundabouts.brandobiker
I only use shwalbe tyres on
I only use shwalbe tyres on all my bikestom_w
I’ve just switched to Open
I’ve just switched to Open Paves, they definitely feel more planted than my 23mm Conti 4000s. I’m running a 27mm up front and a 25mm on the rear (biggest the frame and forks would allow) at about 15psi lower than normal They don’t feel any slower, but they do feel a lot more compliant and like they are gripping better.They also have green stripes on the sides and make you feel like you’re riding a spring classic.
