- This topic has 9 replies, 5 voices, and was last updated 3 years, 7 months ago by .
Shimano Tourney 160mm discs (the least expensive Shimano discs to be found) come with a disc lockring having the normal external notches for a tighten/slacken tool but with an unusual 10-spline internal (in the axle hole) arrangement that’s also slightly bigger in diameter than the internal diameter of standard disc and cassette lockrings.
I’d like to apply an internal 10-spline tool to these Tourney lockrings as this enables use of a torque wrench, which is not possible when using the big notched spanner to tighten disc lockrings via the external notches.
I’ve searched up & down on the interweb but can’t find a 10-notch/spline tool to fit these Tourney lockrings. Anyone know where such a thing may be had – and why just the Shimano Tourney disc lockrings have this non-standard arrangement when every other lockring has the standard 12-spline arrangement?
