- This topic has 13 replies, 11 voices, and was last updated 5 years, 7 months ago by .
I recently attempted to change my brake pads. The pad axles that secure the pads are threaded and have a flat screw head on the small bolt. Both bolts were completely seized and both heads started to strip after not much effort to unscrew them. Uh oh……
A quick check online revealed this to be a not uncommon problem with some talk of the different metals in the pin and the caliper reacting with each other and making them vulnerable to seizing.
I quit before I did too much damage and headed off to my LBS and it was a right headache for them to sort out, they’ve had to drill out both of the bolts.
Fortunately I got the groupset from my LBS and they would have been able to submit a warranty claim if the problem had been insurmountable or the calipers got damaged.
I bought some Deore pad axle bolts to replace the Ultegra ones because they have a hex head. The LBS have used some copper slip when fitting the new bolts and pads.
So, a wee word of warning to all y’all, you might want to check those pad axles and take some preventative action.
I can’t quite believe Shimano have used such crappy bolts. My LBS don’t know why they don’t use a pin rather than a threaded bolt.
