- This topic has 27 replies, 13 voices, and was last updated 3 years, 2 months ago by .
Hello all
Lucky enough to have taken delivery of a new steed, set up tubeless – my first such experience.
– How do I top-up the air? Can’t find any vids or articles about it, they all address inflating from flat upon set-up. Any air escaping means sealant comes with it, right, and I always get a whoosh of pressurised air when I take my track pump off the Presta valve on other non-tubeless wheels. I suppose whether the tyre was flat to begin with or not is irrelevant really, either way you’re facing the same problem of taking the pump off under pressure and some air escaping.
An additional factor is the novel (to me) concept on these rims, with detachable valves that you only put on for inflating and which otherwise stay tucked inside a valve tool (with the resulting hole in the rim covered by a click-on cover). I’d imagine that screwing and unscrewing them when inserting them will also result in sealant being shot out?
Any tips or ideas gratefully received, thank you.
They are Newmen Streem Advanced R50.
Don’t know if I can add YouTube links here but their website has a video about set-up, and it skips taking the pump on and off the valve (and also inflated it from empty, meaning you don’t have the problem of screwing in the valve when it’s under pressure and with sealant already in).
