- This topic has 7 replies, 6 voices, and was last updated 5 years, 1 month ago by .
After nearly one year with my ADV 8.9, 4500 miles ridden I need to do some component replacements. I’m posting here because there is so little ‘out there’ at the moment.
Last week I took a little tumble and later found I can’t get bottom gear, it was surprisingly difficult to identify the rear dropout. There are a lot of ‘hits’ for the ADV 8.9E, and most of those are not in stock.
Google shows for ADV 8.9E at https://www.rearmechhanger.com/ it is CC191.
But the pages like this wanrt to be sure you need CC191 as CC195 is identical on one side, the other side of CC195 looks more like the ADV 8.9 I have. Then there is the Vitus hanger B442 which looks the same.
Boardman customer support were great an advised their systems show it is a 442 and sold by ..
” https://www.mountainbikecomponents.co.uk/product/derailleur-hanger-442/ ” .It was in stock, about £28.
Other changes: the G-One tyres had fairly poor rolling resistance which made ‘keeping up’ on hill climbing more difficult, I changed the G-One tyres for Marathon Supreme 32mm front and 35mm rear, rolling resistance better.
I have bought replacement large chainring FSA 50T to give a bit higher gearing, I previously increased the difference between inner and outer chainrings on two other bikes and found it worked fine.
Issues –
The gear cables sometimes stick, won’t change up. Halfords say they don’t need lubricating, I bought their Gold service so the cables will be replaced as part of that.
The cables fitted new are all too long, they rub on the forks! I have tape to protect.
The frame has space for larger tyres than G-One’s but the fonrt deaillieur moves across into the line of the tyre, this is the limiting factor, not an issue for me, but looks like a design oversight.
