- This topic has 17 replies, 10 voices, and was last updated 7 years ago by
Carax.
October 30, 2019 at 11:11 am #30234
Carax
Hi All,
Just wondering if there are any other Topstone users who have had issues with the bike.
Firstly, the party trick, the Kingpin bolt came loose halfway through a ride. Chain stays had about 5 mm of play.
Shop took it apart and tightened it, but that was about 2 weeks into ownership.
Now, the rear freehub is broken. Not spinning at all, advised all bearings need replacing, etc etc.
I mean the bike is about 9 weeks old and has been off the road due to these issues for about 4 of those weeks.
Anyone else had similar problems with it? Or just me?
Carax
Yes, that sounds like a
Yes, that sounds like a terrible experience!
extrusion wrote:Yes, loads.Knocking from bottom bracket after a week, took to lbs who added a spacer. Still feels too loose to me but no more knocking.
Persistent clicking noise from suspected headset and juddering of front brake, sent back to dealer who helpfully tightened the headset cap that I had loosened for transport and claimed everything sorted. Clicking remained. Replaced stem, seemed better but would get worse as the day warmed up, replaced bars, same, removed top headset bearing and head as it was slightly notchy, now seems to be okay.
Derailleur hanger screw not screwed in and no loctite applied.
Shifters incredibly rattly, dealer said they were no worse than other bikes in their shop and there was no guarantee Shimano would warranty them. Others I have spoken to have said theirs make no noise. I will be sending them back soon.
I have just ordered a new caliper and will fit that and hope the juddering is gone.
Bar tape applied in 2 different ways and direction.
Front derailleur not set up properly, stabilisation screw not used so was impossible to get correct shifting until I realised the shops mistake
O rings that stop the axles falling out both ripped.
All in, utterly shite!
Definitely one for the not fit for purpose and reject under the Consumer Goods act, it sounds like a right bag o poop knocked out as a Friday afternon special a la british leyland et al!
I’ve been so bloody lucky with bikes, even second user ones, my commuter/ute is 10 years old now and aside from a broken pin on one of the v brake arms it’s been ridiculously reliable and bombproof to boot despite been mashed, smashed and lots of urban miles.
extrusion
rjfrussell wrote:How much of all that is down to cannondale, and how much just a shit build by your retailer?50/50 I guess, but the guy was asking about the topstone carbon and I detailed the issues I’ve had.
Retailer is Tredz by the way, not the first time I’ve had issues with the pdi on a bike I’ve bought from them, but it is the last time I’ll buy a bike from them.
rjfrussell
Obvs experiences differ. After 2 years of riding a 2016 synapse my LBS noticed a hairline crack on a seatstay. Took it back to Evans, they dealt with Cannondale- frame replaced under warranty without question, and not only that, they allowed me to upgrade to the new model for only an extra £150 (whcih given they were both hi-mod frames was a huge bonus). Fantastic response and service by cannondale and evans gatwick.
extrusion
Yes, loads.
Yes, loads.
Carax
Yeh, I’m talking with the
Yeh, I’m talking with the shop’s warranty debt now.
It’s just so annoying.
pockstone
When I say ‘get a new one’..
When I say ‘get a new one’…I mean a new bike, not a new freehub with a nice long wait attached!
pockstone
Sale of Goods Act..
Sale of Goods Act…merchantable quality. ( I think those are the magic words.)
Take it back to the shop… get a new one or satisfactorily repaired.
30 days warranty on a freehub?…bollocks…see above.
Rapha Nadal
Budgieman wrote:I have a Topstone 105 AL and have done 350 miles in 6 weeks without any issues.I’m looking at the Ultegra version via our C2W scheme. What’s it like? Looking to book in a test ride with Evans soon.
Drinfinity
Ok, I stand corrected.
I had a similar issue with daughter’s shock mount bolt working loose when new – blue loctite sorted that.
I’d still be suspicious of the same happening at the hub axle though, especially when new and all the factory grease is nice and slippery. Obviously don’t want to use loctite there!
Carax
Drinfinity wrote:By ‘Kingpin’ do you mean rear thru-axle? If so, you have to keep an eye on how tight it is, regardless of brand.
If you were riding for any length of time with 3mm play at the chainstays, that won’t be good for the freehub. It is axle tension that is supposed to cause the dropouts at the end of the chainstays to compress the freehub on to the wheel. Without that, a new hub could move sideways so the pawls are not engaging correctly (or splines if it’s a DT ratchet style).No, the “Kingpin” is the party piece on this bike. Allows the seatpost and seat stays extra flex, there’s sort of in built frame suspension
Carax
Hammermason wrote:
Hammermason wrote:Not a Topstone but a Synapse, freehub went after 3 months. According to Tredz C’dale view it as a wear and tear part, so only 30 days warranty! Maddux wheelset, same as the Topstone? Tredz were decent enough to replace foc.Ouch! Yes this is getting replaced, but it’s so frustrating as a new bike is out of action.
Drinfinity
If you were riding for any length of time with 3mm play at the chainstays, that won’t be good for the freehub. It is axle tension that is supposed to cause the dropouts at the end of the chainstays to compress the freehub on to the wheel. Without that, a new hub could move sideways so the pawls are not engaging correctly (or splines if it’s a DT ratchet style).Sriracha
That’s the stuff reputations are built of. C’dale – you just can’t pay for marketing like that – comes free of charge, but at great cost.Hammermason
Not a Topstone but a Synapse, freehub went after 3 months. According to Tredz C’dale view it as a wear and tear part, so only 30 days warranty! Maddux wheelset, same as the Topstone? Tredz were decent enough to replace foc. -
