- This topic has 29 replies, 22 voices, and was last updated 6 years, 10 months ago by
amazon22.
April 6, 2019 at 3:09 pm #29515
road
Been looking around the net for some (For use with both cycling and a bit of running) as my normal glasses just don’t cut out quite enough of the glare and they slip somewhat when sweating…
A company called KagaOptics has cropped up since the last time I looked for some.
The only reviews I can find are on their own site which is making me a little nervous but they are coming in around £100-£150 cheaper than equivalent from other manufacturers .
Anyone here used them?
Cheers
JimD
amazon22
I can recommend www.extreme
I can recommend www.extreme-eyewear.co.uk for prescription cycling glasses – they can digitally map your prescription to quite extreme lense shapes for haters of inserts. I bought some Rudy Rydons last year with prescription transition lenses – fast turnover and very high quality. They have the advantage that I can easily swap out the lenses for my new prescription. Run by Simon, a dispensing optician. Very pleased with the Rydons also – no more watering eyes no matter how fast!
Durian Rider
Never buy prescription
Never buy prescription cycling glasses from Kaga Optics.
Poor quality & shocking customer service.
I bought 2 pairs of glasses from them and the plastic inserts that hold the prescription lenses have cracked on both pairs. I have gone though 6 inserts within the year.
They ignored my emails & no one answers their phone. I only got a response when I threatened them with legal action. It has been 5 months since my last insert cracked and they have shown no real intent to resolve this. They lack basic knowledge of Consumer Law & have denied me of my statutory right to a refund. Looks like I will be taking them to court.
jbw118
I run and ride and never
I run and ride and never spend more than £20 for a pair of prescription glasses. For running riding the key is a very light pair with composite frame. For an added bonus I use anti fog spray (Swimming goggles spray) So I dont steam up at all on these cold misty days we are having 🙂 Goggles4u always have offers on, if you dont need a complicated prescription you can even get a pair for under a tenner…
Pilot Pete
Nat Jas Moe wrote:If you just need reading glasses buy bi-focal safety spec.This is where I get mine from:- https://www.straightlines.com/ or
https://www.safetyspecs.co.uk might be worth a punt but haven’t used these
Not sure why anyone would want to spend £60+ on safety glasses when they ‘just need readers’ when they could spend £15 on Hydrotac lenses and stick them in their purpose made Oakley sunglasses or the like.
And your first link doesn’t work…
PP
Nat Jas Moe
guidodg
if its only for reading your
if its only for reading your phone or GPS the the small stick on ones work perfectly when cut to size and stuck onto the bottom of the lens of your regular cycling glasses….and cheap to boot!
bikin
If you only need “readers”
If you only need “readers” this company rocks with selection and customer service: https://www.dualeyewear.com/
mdava
JohnnyRemo wrote:If you’re looking at cheap/spare glasses I’ve found these fine for my mild short-sighted and astigmatic prescription. Works out at less than £60https://www.selectspecs.com/glasses/infinity/gm-231-aluminium/ss260.83.html
They have other options available.
Johnny – if you see this – do you find that those frames are curved enough that they don’t get in the way when you are on the drops and therefore looking up through the top of the lens?
I ask because I bought some other frames from SelectSpecs and while they were an incredible bargain and fine for running etc, the fact that the frame is flat means that the top of it is in the way when you are on the drops and peering upwards.
Thanks
David
nniff
Just something that may be
Just something that may be helpful – I wear non-prescription sunglasses and, at this time of year, suffer badly from hay fever. I mostly wear a pair of wrap-around Oakleys and the purpose is two-fold – keep the massive airborne pollen-boulders out of my eyes and dim the lights a bit. The other day, being disorganised, I couldn’t find them and went with a pair of smallish RayBan Wayfarers. I was greatly surprised to find that there was a lot less buffet around my eyes and it was overall a marked improvement. They might not have the same aero-speeding-bullet look, and they will not fit onto my helmet vents, but right now I don’t care. I am embracing my new urban-aero look and am happier for it.
So – to the point – I think you can use a more conventional lens shape and have just as good a result. Oakley Trilby are a similar shape to Wayfarers.
pockstone
mikepridmorewood wrote:There are/were some voltx safety glasses on a large online shopping site that were £30 for a set of clear, yellow and tinted that came with a smal bifocal section in 1.0,1.5,2.0 etc. Look like wraparound cycling glassesGot two pairs of these about 18 months ago. Best spend on stuff for the bike (Under 30 quid…) ever. They are getting a bit scratchy now, probably because I treat glasses with no respect whatsoever. I would put a dab of glue under the rubber nose pads and inserts that grip behind the ears. Some of these have disappeared on mine. Great if you only need readers for maps, phone computer etc.
After a chance meeting in the
After a chance meeting in the LBS, and having tried on glasses with inserts…..I’m back to plan X. The inserts sit too close to my eyes and drove me mad. That was after about 30 seconds. Ah well.mikewood
Thump
Pilot Pete wrote:If you only need readers, save your money and buy stick on prescription lenses. They cost about £15 and simply stick on with water and work fine.PP
Agree with this if you can’t see your garmin or phone. They are brilliant.
Top tip… leave them in really hot water to soften for a few minutes before applying them. Everyone over 50 in my cycling club are dead jealous of them.
Search for HydroTac Stick-On Magnifying Lenses on Amazon.
srchar
janusz0 wrote:Srchar, can you explain further? What does “split frame” mean here? Are the lenses held between a pair of front and back mouldings that clip together? Which Oakley frames are “split frames”?Do your prescription lenses completely replace the original glazing?
A photograph would be appreciated.
Split frame as in two separate lenses (which an optician can grind to shape) rather than a single lens piece (which they can’t). Mine are Racing Jackets which are designed so that lenses can be easily swapped out by unclipping the lower half of the frame from the nosepiece. Yes, the prescription lenses would have completely replaced the original glazing, if there was any.
https://www.google.com/search?q=oakley+racing+jacket&tbm=isch
JohnnyRemo
