Prescription Cycling Glasses
  • This topic has 29 replies, 22 voices, and was last updated 7 years ago by amazon22.
  • #29515
    road
    Been looking around the net for some (For use with both cycling and a bit of running) as my normal glasses just don’t cut out quite enough of the glare and they slip somewhat when sweating…
    A company called KagaOptics has cropped up since the last time I looked for some.
    The only reviews I can find are on their own site which is making me a little nervous but they are coming in around £100-£150 cheaper than equivalent from other manufacturers .
    Anyone here used them?
    Cheers
    JimD
Viewing 14 replies - 16 through 29 (of 29 total)
  • #939251
    Careful, I’ve been caught out
    Careful, I’ve been caught out, being quite short sighted, about -7, by trying to get glasses that are too big or too curved.
    #939249
    janusz0
    srchar wrote:
    Order a pair of replacement Oakley frames (a split frame like the Racing Jacket)  from their warranty phone line (£40) and take them to your optician to get them glazed with reactive lenses.
    Srchar, can you explain further?  What does “split frame” mean here?  Are the lenses held between a pair of front and back mouldings that clip together?  Which Oakley frames are “split frames”?
    Do your prescription lenses completely replace the original glazing?
    A photograph would be appreciated.
    #939247
    Jack Osbourne snr
    srchar wrote:
    The best thing I have ever bought for on-bike comfort.
    Guess what Im doing at 0902 tomorrow!
    #939245
    srchar
    #939243
    Drinfinity
    I’ve got prescription Oakleys
    I’ve got prescription Oakleys with photochromic lenses, very useful for riding in the woods. The optician had a fancy fitting gadget and a tablet to make sure the lenses lined up exactly with my pupils. I had an old pair before that was available, where I always felt they only worked through the top half.
    I’m very satisfied with them, and used the ‘second pair free’ option at Vision Express to pay for most of the cost.
    #939241
    I was gutted to discover,
    I was gutted to discover, after deciding  to not endure the torment that my use of contact lenses had become and after getting a lovely pair of Oakley perscription frames which the optician put in lenses, that Oakley do not make their lenses powerful enough for my percription.  So no Iridium lenses.
    I did without sunglasses for a while.  Too many years of finding the sun too bright, and several pairs of really bad oakley percription frames, I thought I would get myself a pair of sunglasses that could also be used as my spare pair.  I found to my delight that there is quite a market for second hand oakleys on ebay.  Found the sunglasses version of the glasses that I had loved for many Years, Ti Zeros, and got my optician to make up a set of my shockingly complex and expensive tinted lenses for them.  As I wanted them as emergency spares I went slightly lighter than I may have done for full on sunnys.
    The original perscription Zeros frame had had slightly narrower lenses, as my lenses get quite fat at the edges, but since I had them, they have created a coating that reduces distortion towards the edges, and it really works, there’s still a little bit of “squeezing” but nothing like without it.  It’s so good when looking through the tops to look down the road or the sides when looking behind.  So good that I got the coating rather than the option of a mirrors coating, and I love the mirror thing.
    Got my real glasses done all the same way, spare parts.
    #939239
    Thanks all
    Thanks all 🙂
    Quick couple of thoughts in response to points made:
    Optilabs were my original choice but being able to find more or less the same thing for >£100 cheaper made me think.
    Looked at the Rudy Project stuff…oh my…I thought Oakley’s were expensive!
    Need a new eye test but may just have to take the plunge 🙂
    #939237
    dooderooni
    If you want to go down the
    If you want to go down the more conventional sports sunglasses route then Honillesi on AliExpress might be to your liking. I’ve had everyday glasses from them and the lens and frame quality has been excellent.
    My experience of the Jawbreaker clones from eBay or AliExpress is that the ones I’ve handled and used have been better than my Kaga’s.
    #939235
    Jack Osbourne snr
    Just had a look and they are
    Just had a look at Kaga Optics offerings and they are certainly well priced.
    They remind me of some that Planet X used to sell a few years ago, although you had to then take them to an optician for glazing
    #939233
    ibr17xvii
    I’ve used the Rudy Project
    I’ve used the Rudy Project clip on insert for a fair while now with zero problems.
    Took a bit of getting used to but now they are spot on.
    #939231
    Jack Osbourne snr
    I’ve used clipons a few times
    I’ve used clipons a few times and the inserts always break. I now just stick to my normal glasses or sunglasses.
    They tend only to last one set of lenses (at best) as they, for me at least, usually snap somewhere around the lens.
    They’re fine if your prescription is stable, but if it’s changing frequently, you’ll quite likely be on a full set of glasses every time.
    Having said that, at potentially less than one third of the cost of eg prescription Oakleys, they do still hold a certain attraction…
    #939229
    dooderooni
    I’ve used Kaga and they use a
    I’ve used Kaga and they use a clipon prescription frame that mounts to the bridge piece of the main sunglasses frame. This clipon cracked in mine after a couple of months and I had to superglue it back together.
    You can get similar and cheaper prescription glasses off AliExpress if you have your prescription.
    I’ll post more details later when I get back from work.
    #939227
    Pilot Pete
    If you only need readers,
    If you only need readers, save your money and buy stick on prescription lenses. They cost about £15 and simply stick on with water and work fine.
    PP
    #939225
    janusz0
    A quick look at their website
    A quick look at their website suggests that the prescription lenses all sit behind the main eye shield. This can be alright as long as the prescription lens frame doesn’t change position as you ride (I’m looking at you, Rudy Project) and the prescription lens doesn’t get brushed by your eyelashes (they leave greasy marks). There’s another problem. You will get annoying dirt and fluids lodged in the space between the lens and the shield, so make sure it’s easy and quick to temporarily remove the prescription lens frame. I’ve used Optilabs wrap arounds, where the main eyeshields are formed from prescription lenses. They don’t wrap around quite as much of your face as real, prescription less wraparounds, but they do a good job of keeping insects out of your eyes and have various photochromic, tinted or partially mirrored options.
    Try for fit, before you buy and if you use bifocals or varifocals, bear in mind that you’ll be looking down, with your eyes tilted up when cycling, so you need to get the optical centre of the bit that gives you good distance perception, higher than normal.
    For people that only need reading glasses, there was a company at the London Bike show with sports glasses with a reading insert at the bottom, allowing you to read the gizmos on your bars.
