- This topic has 32 replies, 19 voices, and was last updated 7 years, 11 months ago by
Griff500.
October 17, 2018 at 6:01 pm #29057
Griff500
Externally routed cable – no problem, a few quid, 20 minutes, job done. Internally routed cables? PITA, but a bigger PITA if they snap. My good bike rarely gets wet, and has just crossed the 5,000 mile mark. When should the inners be replaced, and I guess equally important, what about the outer sheath?
Griff500
huntswheelers wrote:
huntswheelers wrote:vonhelmet wrote:I think shimano fixed the shifter snapping issue. It was a major problem with 5700 / 6700 but they changed things up for 5800 / 6800 and I think that sorted it.Nope…. still get the 58/6800 in for snapped off at the nipple…. many are found early (as I take a look now) and some are found with just a few strands left connecting the cable to the nipple…..
Mine is a 2016 bike with 6800. Broke at the shifter.Canyon48
The new STI’s seem pretty bad
The new STI’s seem pretty bad for wrecking cables (5800 6800 r7000 and r8000) I’d recommend changing inner gear cables every 3k miles.I had two snap both around 3k miles.
huntswheelers
simonmb
Griff500 wrote:
Griff500 wrote:
I used the big ring to get me to the nearest cafe, then phoned mission control to send a rescue shuttle.I once suffered the misfortune of puncturing front and back (tubulars) simultaneously at the end of a 120km ride – but right in front of my favourite café.
Mind you, a cortado and biscotti did nothing to take the sting out of the fact that they were silk-lined FMBs.
janusz0
Griff500 wrote:
Griff500 wrote:
Half a k South of Simiane la Rotonde.janusz0 wrote:Griff500, what everyone will want to know is: where exactly was the break?
Nice evasion. (Not the town, the question!)
Haute Provence eh? Some riders have all the luck!
Griff500
janusz0
Griff500 wrote:
Griff500 wrote:Oh the irony! A month after making this post, and allowing myself to be persuaded by you lot not to worry, my shifter and RD ceased cooperating with each other 20 miles from home. 8600km recorded on the bike since new. Not much fun being left with only a 36/11 gear ratio. There was no advance warning (roughness or dodgy shifts)Hubris?
Griff500, what everyone will want to know is: where exactly was the break and would you recommend the café?
Mungecrundle
Griff500 wrote:
Griff500 wrote:Mungecrundle wrote:Griff500 wrote:… Not much fun being left with only a 36/11 gear ratio…You cross chained all the way home? Any true English gentleman of breeding would have left it in the big ring and risen to the challenge, willing to sacrifice cartiledge and sinew to do the right thing.
Afraid not. I used the big ring to get me to the nearest cafe, then phoned mission control to send a rescue shuttle.Honour restored.
Griff500
Mungecrundle
StraelGuy
I changed all the internal
I changed all the internal cables on my Giant recently. This led to the best bit of advice I could give anybody about cable inners if you’re fitting new brifters. DON’T use the Shimano inners they come with, the inners that have that weird flakey coating. When you eventually come to remove them, this coating sheds and completely bungs up all the tiny holes you need to get inners in and out of. Bin them and use bog standard stainless inners instead.
matthewn5
Griff500 wrote:
Griff500 wrote:Oh the irony! A month after making this post, and allowing myself to be persuaded by you lot not to worry, my shifter and RD ceased cooperating with each other 20 miles from home. 8600km recorded on the bike since new. Not much fun being left with only a 36/11 gear ratio. There was no advance warning (roughness or dodgy shifts)That sounds like the cable end came off in the shifter.
Griff500
Oh the irony! A month after making this post, and allowing myself to be persuaded by you lot not to worry, my shifter and RD ceased cooperating with each other 20 miles from home. 8600km recorded on the bike since new. Not much fun being left with only a 36/11 gear ratio. There was no advance warning (roughness or dodgy shifts)vonhelmet
huntswheelers
I always advise customers on
I always advise customers on 105/Ultegra to swap out cables annually (obvs I know who put the miles in) to save the Shifter snap issue… always these 2 japanses shifters…
As for internal cables…. apart from the above caveat, it’s bike dependent… a certain manufacturer/online retailer in Sheffield has some routing issues under the Bottom Bracket to derailleurs but I only see it as I have the bikes stripped out… most only need new cables when the old ones (if galvanised) break out and drag inside the housing (common on some of the so called “brands”) …other than that…. it’s owners preference or what is seen at service and customer advised before replacing
