Rear Light for Hamax Bike Seat
  • This topic has 7 replies, 6 voices, and was last updated 9 years ago by gthornton101.
  • #26344
    gthornton101
    Has anyone found a decent rear light that can be attached to a Hamax bike seat?
    I can’t find a way to attach either of the two that I currently have on my bike (Exposure Flare and Knog Blinder 4 R70) no matter how many cable ties I use!
  • #879253
    gthornton101
    sc129806 wrote:
    I’ve found myself in the same situation today, existing lights with various old brackets and still I can’t find a way to get my rear light fixed.
    Wondering what solution you found?
    I actually ended up cutting the rubber attachment off the Knog (so it would sit flat) and attached it through the foot support holes with a couple of cable ties.  Very secure.
    Oh and reusable cable ties to take it off and on for charging.
    #879251
    Silver Rider
    I use a lezyne zecto drive
    I use a lezyne zecto drive rear (Aldi had some knock-off versions in their recent sale) and the rubber strap loops through the top hole in the seat and fastens up pretty securely. Not sure if every Hamas seat has this hole, mine is the model that reclines slightly, but an older one – a quick Google suggests several of the current models have a central hole near the top (sleepy and Kiss do) but some don’t, I guess you could always drill a suitable hole.
    #879249
    BarryBianchi
    Do what I did and get some of
    Do what I did and get some of the super strength velcro with sticky back (department store/haberdashers/Screwfix).
    #879247
    sc129806
    #879245
    gthornton101
    Thanks, will check out both
    Thanks, will check out both options!
    #879243
    Dun_runnin'
    Hiya
    Hiya
    Aldi currently have the following lights for sale in the shop (See links below).  I bought a set and they are very bright and good value.  They come with a flexible rubber/silcon strap and a certain amount of angle adjustment to align them horizontally which may help with your issue.
    I googled “Hamax bike seat” to see what you were up against and as far as I could see there are holes or straps in the seat that the lights could be attached to…….good luck
    Front and Rear LED Bike Lights – £ 9.99
    https://www.aldi.co.uk/front-and-rear-led-bike-lights/p/072029062109500
    I’m unsure of the fixing of the second link however,  it is also good vaule and worth a look at to check the fixings
    Aluminium Red Rear Bike Lights £ 12.99
    https://www.aldi.co.uk/aluminium-red-rear-bike-lights/p/072177062208400
    #879241
    rnick
    Hello – I recall a similar
    Hello – I recall a similar problem a few years ago.  You might be able to get a cateye rack bracket to fit – drilling may be required. I think the fiddly bit is trying to get the light pointing horizontally.  I backed up the light with a few strips of 3M reflective tape.
