4 comments
Would be very odd if it was junction B, that's just a bunch of connectors, no electronics/logic involved.
I've had similar with my old 6870 system, I resolved it buy unplugging everything from the battery (easy as mine was external) and plugging in each component separately and seeing if it powered/operated. Each of them was fine and when I cabled everything back up and plugged in to standard diagnostics (eTube) it all worked fine.
As most of the brains of the system is in the battery that's always the place to start.
Thanks for the replies
Been looking over it all night and think I’ve found it.
Also helped if I changed the USB cable to a better one as the charger unit now shows the Master Init can’t be found!
Unplugged the battery and plugged it directly into the junction A box (bypassing junction box b) and it came to life.
So it is either the battery cable or Junction Box B. I’ve ordered a new box from Wiggle to hopefully see if this is causing it.
It may have gone into crash mode if you knocked the derallieur somehow, you cant use the rear derallieur but the front normally still works.
Have you the Shimano diagnostic box, PCE1 ? Not the one that connects through the port charger BCR2. Or you can unplug each item and see if the system comes alive. Unplug front derailleur and one lever, if system comes alive its either the disconnected lever or front derailleur. If its still dead plug the lever back in and disconnect the other and so on, to eliminate items. If non of it works then you will need the diagnostic box to connect each item to check over and update firmware/reset
After that its checking over cables for damage/corrosion
