29 comments
It's possible to go handbuilt for your budget too.
I picked up a pair of 29er wheels with XT hubs and no name rims for £85 with 2 pairs of tyres, one of which I sold for £30.
One word of caution for going the 29er wheel route is the rear hub width, MTB OLN is 135, Road OLN is 130mm.
cheers, just received my wheels from Merlin though... Road disc OLN is also 135mm by the way... unless its 142mm.
Slight misunderstanding. When I first replied I used external widths as this is what I believe most of people are more familiar with that, then I started quoting internal dimensions to be more precise.
I realise how wide "proper" Mtb rims/wheels are as I wouldn't use anything narrower than 35mm myself but the ones within OP's budget typically are ERTO 622-19C...
As for Cannondale Bad Boys, 25mm is a stupid size (just a strong personal opinion) for urban commuting (or even training on some roads) regardless of the rim width.
Aye, 622-19 would be great with 28mm tyres which sound a good choice for the OP.
I'd ideally not use 25mm for commuting either, but run 25mm Open Paves on 622-17 on the 'road' bike which come up a nice bit over 27mm and work well for general abuse on tarmac and light use off it.
Having used a rigid MTB as a commuting hack for many years I can tell you that you don't want to mix a true 25mm tyre and a MTB rim.
You want to go up to a 32mm tyre, for those working in imperial that means go 1/4" up from the rim size, clubman bikes stuck to this formula for decades back when 27x1 1/4" was the standard.
For the nay sayers who think it's fine - Cannondale made the mistake of using 25mm tyres when they first released the Badboy, they ended up having to provide replacement front wheels to a lot of people as a 25mm tyre on a broad rim doesn't provide the air pocket needed to prevent dented rims if you hit anything like a pot hole, steel road plate, an out of place concrete edger, raised iron work etc etc.
The only measurement relevant in this discussion is inner width measured at the the bead hook(s).
The new generation of 23mm rims measure around 17mm inside and the 25mm ones listed above have 19-21mm inner width which is exactly the same as many MTB XC wheels.
Precisely, so when you wrote
..I said I really wouldn't recommend it, and have been giving you figures based on internal rim widths ever since.
Most 29er MTB wheels have internal diameter much higher than 19mm, which is about as wide i'd feel comfy putting a 25mm tyre on and a bit more than recommended elsewhere.
thanks for the responses and accompanying discussions :). I've ordered some Aksium disc wheels, should be here by friday so I'll report back on them once I've had a chance to fit them.
Someone tell those guys they are doing it wrong! Their rims have the same or wider inner width that many mtb wheelsets (typically 24.5-25mm and 19mm inner)
http://www.bikeradar.com/road/gear/category/components/wheel-sets/produc...
http://road.cc/content/review/132864-spin-koppenberg-max25-25mm-wide-fat...
http://www.planetx.co.uk/i/q/RIPXCT45CCL/planet-x-ct45-carbon-clincher-rim
..perhaps you should try and understand how rims are measured... then review what i've been trying to say.
£40 over budget? Merlin have Kinesis Disk specific wheels for £240 shipped - get great reviews
as to 29er wheels i went thru same loop when got a 2nd set for my CX style gravel racer/adventure shopper and concluded that plenty of people run narrow tyres on 29er rims despite contrary advice from some manufacturers and that i didn't want to be the one person in a million who actually loses a tyre off a rim which would have pretty nasty consequences
2nd set well worth having by the way
I think it's a similar situation to running non-tubeless mtb tyres... tubeless with a bit of sealant, gaffer or Gorilla tape or split tube ghetto method. It looks and sounds dodgy, it shouldn't work, Mavic says that it can kill you... (because they want you to buy their expensive UST rims and ignore what consumers really want) but... it works and plenty of people enjoy the benefits.
Like I said before many people have been using narrow slicks with various mtb rims for ages and I haven't heard any stories about spontaneous blowouts. What Mavic and many other companies say you can or can't run is dictated largely their legal and marketing teams IMO.
The guys from Continental would be terrified if they knew that I'm running their 28mm (32mm) slick tubeless at 50PSI at the front... but I know it works
No, no it really isn't similar...
Nothing to do with their over-priced rims - it's the tyre width they're talking and they could have chosen any size for their new tyre with no additional cost to them. They have nothing to gain by choosing a particular width beyond technical merit.
I really doubt they would - however you're still completely missing the point but, hey, whatever - i'll leave the thread and let the OP hopefully get some more useful information about what they actually asked about.
i wouldn't be afraid of cup and cone bearings just make sure plenty of grease in them and once a year replace the balls for just a few quid - sealed cartridge bearings are a pain to change in my opinion and not always sealed!
Thanks but I wrote that I'm not afraid of cup & cone bearings...
Have thought about the kinesis wheels but I'm really trying to keep the budget down. Plus there seem to be a number of reviews that say the freehub gets chewed up and they aren't that well built.
Here's a typically sensible take from Sheldon
Followed by a table with recommended rim/tyre widths, itself followed by the equally sensible foot-note
Erring on the side of caution, that table gives the following minimum recommended tyre size for a given rim
622-17 -> 25mm
622-19 -> 28mm
622-25 -> 44mm
..which, for the smaller sizes at least, is in line with what Mavic were saying they'd actually tested. Food for thought ?
P.S. Many budget MTB wheels come with 25mm wide rims anyway. Put some 28mm or wider tyres on and it'll make a perfect commuter setup.
I don't really get it.
Bead security issue? Plenty of people run 1" ish slicks on 26" rims at 100PSI and they are still alive.
The width of mtb rims isn't an issue but an ADVANTAGE. Nowadays it's normal to run 23mm rubber on 25mm rims so logically +25mm tyres will spread better on wider rims.
Currently I run Conti Grand Prix 28mm mtb slicks (exactly the same as their 700C cousins) on 28mm Stans rims. They stretch to around 31-32mm and they handle beautifully.
The max pressure warnings on mtb rims are about wide mtb tyres run tubeless. It's only to prevent some fools to put 60PSI in their 2.35" tyres;-) You can still run narrower tyres at high pressure without an issue.
It looks like anything with a MTB label on it is evil in a road cycling world;-)
Not at all - it's just that it seems that there is some feedback to suggest that it may not be the best mix and, potentially, dangerous. I run wide road rims and narrow and wide tyres and enjoy the benefits - but i'm also willing to listen to advice from others who have thought about it, and tested it, more than me. Again, i've done - and do - things that may not be recommended but it's a personal choice and judgement based on the rims, tyres and where i'm going to be riding (hence pressure). I'm not comfortable with telling someone else to try something that is explicitly advised against by those that may have much more of a clue than me. 23mm tyres on 25mm rims is hardly normal either.
Back to why... my take would be that given the way the a bead hooks into a rim I think it's quite clear that the relationship between the width of the rim and tyre will dictate how much the tyre will need deform to adopt a certain shape.
If you have a narrow rim and a wide tyre the issue is normally the light-bulb stress (double curvature) and pinch flats. If it's a very wide rim and a narrower tyre then to engage the bead in the hook securely then i'd imagine it's the extra strain in the side-walls.. think about the angle of the bead/sidewall and the rim hook - doubly so with tubeless (which I use), you really want the two the match more the higher the pressure.
Anyway, not matter what you and I might think, maybe have a look at what people are saying why it's not ideal to go to far either way with fat tyre/narrow rim or vice versa.
I'm one of them. Used the Specialized 25mm Turbos on a variety of 26" rims since the 90s without any un-seating problems. They were really tough to get on a few rim combinations, so zero chance of them coming off.
I looked into 29er wheels before and as well as the width issue, not all rims are rated to road tyre pressures so it's a bit of a minefield.
There is no reason why not.
25mm tyres will easily go on 25 or even 26mm rims. Pressure isn't an issue either when using with tubes.
I managed to put 28mm Schwalbe One tubeless tyres on 28mm Superstar MTB rims. The tyres stretched to wonderful 30-32mm
They can fit, and they may be alright but it's not recommended for bead security reasons and ride quality, e.g. from the road.cc review of the Mavic All Road
or the CTC discussion of rim/tyre widths
I've used various non-recommended combinations and i'm still here (currently) but that is my choice and it is definitely not something i'd recommend to anyone else. That said, I really like your tyre choice
I can't recommend any particular model as I never use factory wheels but look also at 29er MTB wheels. Many of them will have 25-26mm wide rims so no problems with using 25mm or 28mm or wider tyres. Weight will be similar.
I'd be really careful trying to use MTB rims with road tyres that narrow, especially the 25mm.
cheers for the suggestions - my limit is £200 so the Hunt and the DT swiss are over that unfortunately. Also not mad keen on alloy nipples for a utility wheel. The Mavics look OK and they are adaptable for thru-axle so at least have some forward compatibility built in., could give them a try.
Hunt wheelset £350
My Mavic Aksium discs are proving good for both road and cross. I still swap the tyres over which is a pain as you say.
DT Swiss R24 DB. They reviewed well recently on road.cc. I have the non-disc version and they're nice enough wheels. Especially running tubeless with Schwalbe Ones.
