- This topic has 17 replies, 7 voices, and was last updated 7 months, 4 weeks ago by .
Good afternoon,
One here for the home mechanics and any Shimano pro mechanics who are on the forum. About a year ago I managed to get a Claris triple groupset at a bargain price, so I swapped out the Microshift R8 triple groupset that came with my Triban 500 SE bike.
Installation was fine and the Shimano groupset overall is better than the Microshift was. Only one problem. I could never remove front mech rub when in the large 50T chain ring and the smallest 11T sprocket on the cassette. Dialling out the limit stop (to the point where the chain should really have been falling off the large ring) and increasing the cable tension (beyond the point of overdoing it) would not help put space between the chain and the front mech outer plate. I was following Shimano’s instructions in their dealer manual to the letter and it was just no joy. Besides, the setup of the Claris triple front mech is really boilerplate for a front mech, with no special setup features that you need to be aware of. In the end I shrugged my shoulders, created a bit of mech rub in the small chain ring large rear cog combination (in order to throw the front mech cage fractionally further out and give more space between chain and front mech outer plate) and resigned myself to some noise at both ends of the gear range.
However, yesterday I was putting on a new cassette and chain and while I was checking that indexing was still okay, I had the idea to pull on the front mech cable (externally cabled frame) while the chain was in the small rear large front combination. Suddenly the rubbing was gone and the front mech did what you would expect: it went out as far as the limit screw setting. When just using the shifter it matters not where the limit screw is set: the cage will just not go out far enough to avoid rubbing. So, I realised that the problem was not the front mech (the spring, the limit screw setting or the cable tension), but it was actually the shifter that was limiting the movement to allow sufficient cage clearance in the small rear large front combination.
Does this sound like a manufacturing fault with the shifter (its range is just slightly too short for three chain rings)? Is there an adjustment that can be made to the shifter’s mechanism (saw nothing about this in Shimano’s manual)? Or is that just the way that the Claris triple shifter functions, and the front mech rub is a “feature” and not a bug for the lower end groupsets?
All views welcome. It’s only my commuter bike, so I can live with the mech rub. But my pride wants to solve it!
Thanks and regards,
roadbikepilgrim
