Gov.uk consultation proposals on a review of The Highway Code
  • This topic has 26 replies, 10 voices, and was last updated 6 years, 3 months ago by LetsBePartOfTheSolution.
Viewing 11 replies - 16 through 26 (of 26 total)
  • #962819
    quiff
    Rule 66 could do with more
    Rule 66 could do with more work, but that’s exactly what the consultation is for. Also, as you note, the Highway Code is a package and different rules have to be read together. Better work has been done on the complementary rules more relevant to motorists, e.g.
    [quote Rule 213]
    On narrow sections of road, at road junctions and in slower-moving traffic, cyclists may sometimes ride in the centre of the lane, rather than towards the side of the road. Allow them to do so for their own safety, to ensure they can see and be seen. Cyclists are also advised to ride at least a door’s width or 0.5m from parked cars for their own safety
    [/quote] [quote Rule 163]
    give motorcyclists, cyclists, horse riders and horse drawn vehicles at least as much room as you would when overtaking a car (see Rules 211 to 215). As a guide: ─ leave a minimum distance of 1.5 metres at speeds under 30 mph ─ leave a minimum distance of 2.0 metres at speeds over 30 mph
    [/quote]
    #962817
    quiff
    It’s not presumed liability
    It’s not presumed liability but, to be fair, it does propose introducing an express concept of a hierarchy or road users ~bigger vehicle more responsibility
    #962815
    Yes I’m really upset by that
    Yes I’m really upset by that suggested rule 66 change
    Your snippet is the clearest explanation I’ve ever seen regarding appropriate lane-use in relation to cyclists
    Why on earth couldn’t they just incorporate words to that same effect in the HC, rather than their take-all-subclauses-into-account mish-mash
    To me it’s pretty simple ( and I’m sure someone could come up with a better version ):
    Cyclists may chose their lane position as appropriate or necessary: this includes riding in the primary position, or up to two abreast.
    Other road users Must only overtake either:
    1. On the right in a separate lane, or
    2. On the right by leaving at least 1.5m lateral clearance. With additional clearance when at high speed.
    #962813
    CXR94Di2 wrote:
    CXR94Di2 wrote:
    Where is presumed liability, mass advertising campaign to public to drum it into stupid drivers that they need to stay clear of cyclists
    Those would be separate things. If you’ve been tasked with reviewing the Highway Code, you can only reflect the current law and add surrounding advice. You can’t go around creating new law and policy – those are someone else’s responsibility.
    #962811
    CXR94Di2
    #962809
    I thought this was widely
    https://pbs.twimg.com/media/Dl1a_ZOW4AATC7Y.jpg
    I thought this was widely known by interested parties, but it isn’t made use of in that rule 66 change.
    #962807
    Just don’t tell burt about
    Just don’t tell burt about rule 59
    #962805
    IHateSummer
    Good point. Although I don’t
    Good point. Although I don’t think the revision rules out two abreast on non-narrow lanes, just that cyclists should move back to single file, if, drivers want to overtake AND it’s safe AND when not on narrow lanes in larger groups (sometimes).
    You’re right, it doesn’t make sense!
    #962803
    I’m not sure the second part
    I’m not sure the second part makes sense either. Whereas the previous text implied that two abreast was fine except on narrow lanes, busy roads, and bends, the revised text suggests that it’s only appropriate to ride two abreast when on narrow lanes and in a large group.
    #962801
    Awavey
    no wait,the ‘gear change’
    no wait,the ‘gear change’ stuff today just announced consultation on the highway code for updates for cycling…whether it results in any change is another matter but its there
    #962799
    Interesting point; well made.
    However – I think that the chances of any revision of the HC actually happening are pretty slim.  I suspect there’ll be this consultation and then it’ll get kicked out into the long grass…
