- This topic has 29 replies, 14 voices, and was last updated 6 years, 5 months ago by
srchar.
June 10, 2020 at 2:05 pm #30815
0-0
I’d like to reduce the amount of stuff I carry around with me on a road bike ride.
Mainly reducing the bulk, not really for weight reduction.Tyres are Pirelli Cinturato. Which have pretty good puncture protection.
At the moment I’m carrying a mini pump, two CO2 cannisters and injector, spare tube, puncture repair kit (glue, patches and cut up inner tube strips for tyre boots) and tyre levers attached to multi tool.If I bought something like the Stans Dart (I’m using their sealant), could I reduce the carry to:
Mini pump, glue and tyre boot, tyre levers on multi tool.Thanks for any advice.
Secret_squirrel
Thats odd. Ive had 2 causes
Thats odd. Ive had 2 causes to use my Lezyne tool and none of the issues you’ve faced. First one plugged perfectly, 2nd failed to seal because the cut in the tyre was C or J shaped and I dont believe any plug would have sealed ir. Sealed enough to limp home at low pressure then fixed with a patch on the inside.It stands to reason that a tool designed to pierce a tyre is going to threaten rim tape. Thats basic physics.
snsb
With the stem being hollow
With the stem being hollow and waterproof I have jammed two £20.00 notes ; some small cable ties ; puncture patches etc. No real added weight , fairly easy to get to and fortunately so far never used.
0-0
nopants wrote:
nopants wrote:When I used inner tubes I used to carry the same as you, but no pump. I don’t think I ever had a situation where I wasn’t able to get home except for a couple of terminal side-wall failures.
I’ve gone tubeless, and seem to be puncturing all the time, so I added a mini-pump too. Most very small punctures seem to seal at a lower pressure (well below the 80psi I ride at). Anything much bigger than a pinhole that does seal takes me down to ‘get-me-home-at-walking-pace’ pressures.
I have now ditched the co2 – it is easier to top up just a bit with a pump, and to get to a point where you are not blowing the sealant out every time.
I would drop to mini pump, tyre boot, tyre levers on multi tool and a small lightweight inner tube like a continental supersonic. IME it would be a big mistake to ditch the inner tube.
Thank you very much for the advice 🙂nopants
0-0
Chris Hayes wrote:
Chris Hayes wrote:Carry a tubeless repair kit by any means, but DO NOT – whatever you do – buy a Lezyne one.
Just back from a cold, wet and windy ride in Norfolk, a large part of which was spent covered in slim by the roadside trying to fix a puncture. I tried to plug the tyre, but the fork mechanism is so wide you need to apply a massive amount of force to get the plug through and so you stand a fair chance of damaging the rim tape.
I’ve long thought Lezyne a sh1t brand, but gave them the benefit of the doubt on the tyre plug, I mean, it was compact, well priced and how hard could it be to design one?
An inner tube saved my day….another day like today and I’ll be an innertube convert.
I’m sorry to hear you had problems.
But thank you for the advice.Chris Hayes
0-0
Thank you very much
Thank you very much hawkinspeter, peted76 and Westy.
Great advice 🙂(I couldn’t get the multi quote to work).
I changed to tubeless about 4
I changed to tubeless about 4 years ago, and haven’t had a flat since (have had 2 or 3 punctures I didn’t know about at the time as they self sealed). I use Stans Race Sealant, injected through Milkit valves, and checked/replaced every 2-3 months, with either Schwalbe Pro-One or Hutchison/Mavic tyres). For the first year I still carried puncture repair stuff and a tube, but for the last 3 years (about 20k miles) I have only carried a phone – haven’t had to use it for a help call even once. Down side is that I haven’t been able to help others with problems, something I would always have done previously.
peted76
I carry one of those stans
I carry one of those stans dart things (not used it yet), a small bottle (30ml) of sealant, valve core remover & mini pump. Which I suppose would replace: inner tube, mini pump and tyre levers.
The way I look at it is, if I had a tyre failure which couldn’t be repaired with some additional sealant OR a plug and some additional sealant, then I’m probably calling a taxi.
On the odd few times a year I go ‘away’ and might find myself stuck for a lift/taxi/train home then I’ll also take a small pack of tyre patches with me (like tube patches but thicker).
Probably tempting fate and all, but I’m pretty unfussy as to the kind of surface I ride.. the ‘only’ time I’ve had a tyre failiure which required a broom wagon.. was a sidewall tear about a third of the way around Hell Of the North Cotswolds in 2018, that was on 33mm Schwalbe X-One Speeds, which weren’t the most suited to that kind of terrain.
0-0 wrote:
0-0 wrote:
Thank you. You sound like you also need to reduce the bulk 😉 Do you think my pared down list sounds OK or too risky?hawkinspeter wrote:I carry a dynaplug racer, spare tube, mini pump, CO2 cannister plus injector, tyre levers, minitool, chain tool, spare links and a park tool tyre boot. Definitely too much as I rarely use any of that. I did give the spare tube to a punctured cyclist near Keynsham the other day, so I’m glad that I’ve bothered carrying it unused for so long.
Sounds fine to me. Ultimately it depends on how lucky you are and what risk you’re happy to accept. Personally I’m always thinking in terms of how things go wrong (I work with computers) and it really bugs me if it’s something that’s easy to fix with the right tool and foresight.
0-0
Thank you.
You sound like you also need to reduce the bulk 😉Do you think my pared down list sounds OK or too risky?
0-0
Nick T wrote:
Nick T wrote:That’s a lot of stuff. I thought tubeless was about less faff? I’d have thought a mini pump and a spare tube would suffice. Swap the tube for a dynaplug perhaps.
I only carry a spare tubular, a mini pump, 1 tyre lever to help get a flat tub off, plus wallet and phone. Only had to get a train once in 10 years, when I forgot my spare tyre
Thank you for your help.
I think the faffness increases when it goes wrong 🙂Nick T
