Carbon bikes too stiff for lighter riders ?
  • This topic has 31 replies, 18 voices, and was last updated 5 years ago by andystow.
  • #31804
    BSA rules
    Is the trend for fitting larger volume tyres to carbon road bikes an admission that the frames are too stiff especially for lighter riders? All bikes have to be designed and manufactured for the safety of the heaviest riders, I don’t think a 65 kg rider on any carbon bike even a sportive model will feel any of the comfort advantages associated with this type of bike if it has been designed to be safe for a 120 kg rider, hence I’ll be adding my 28 mm tyres running 70 psi, a carbon seat post,and the best cycling shorts I can find, anyone agree?
Viewing 15 replies - 1 through 15 (of 31 total)
  • #985171
    hirsute wrote:
    Not sure that is right as a number of wheels state a lower mass than that.
    Was that a quote from a website ?
    https://www.halfords.com/bikes/faqs/adult-bike-maximum-weight-limit.html
    #985163
    Dnnnnnn
    I was interested to note
    I was interested to note Lizzie Deignan claiming to have run 2.3bar/33psi in her tubeless tyres in the Roubaix race. Hard to believe – I’ve probably blown balloons up with more pressure than that – but a direct quote, apparently.
    #985169
    #985167
    I certainly prefer 32s at 65
    I certainly prefer 32s at 65 rather than 25s at 85 given the state of roads around here.
    Plus if I use the odd bit of uneven cycle track, it is much easier.
    #985165
    I’ve unintentionally ridden
    I’ve unintentionally ridden with a tubeless tyre at around 20psi, but it was very squirmy and the rim bottomed out on ironworks and potholes.
    #985161
    BSA rules
    Ha,ok, substitute”won” for
    Ha,ok, substitute”won” for “competed in” ?
    #985159
    EddyBerckx
    BSA rules wrote:
    BSA rules wrote:
    Nice one, exactly, I should know! My old bike rides( 05 carbon trek madone)feels just as supple as the few big tubed, dropped seatstays modern bikes I’ve tried. I wonder if the frame on the madone was ok for Lance when he won all those TDF’S? I didn’t hear him complain it wasn’t stiff enough!
    yeah you might wanna check his Wikipedia entry, it’s been updated in the 16 years since you last looked ?
    #985157
    BSA rules
    #985155
    No, it’s an admission that the target market is generally getting fatter. Fat tyres for fat arses, anyone riding 28mm or above is tacitly admitting this.
    While the population has been getting heavier on average that is over a far longer timescale. Or do you mean the recent rise of the MAMILs?
    As for fat arses riding 28mm, I weigh 60kg and after years on 25mm I now ride 28mm tyres (~55 psi) on the crappy roads of Shropshire. I have 32mm that I intend to try presently to see if it makes any difference. Do I need to do my food shopping at Greggs?
    As others have stated, the stiffer = better marketing bullshit has been around for a while. The power we put through the pedals is a fraction of pro riders, we don’t need oversized head tubes and ovalised ‘drainpipe’ downtubes but the brands want us to believe… It’s the same as the shoe stiffness bollocks and the lightweight bullshit – “Your wheels are heavy. Shave of 300g with these wheels and you’ll fly up those hills”. It’s just bullshit. But it sells.
    #985153
    BSA rules
    Adult bike Maximum weight
    Adult bike Maximum weight limit
    Unless otherwise stated, adult bicycles are designed to carry a rider of up to 120 Kg (18st 12lbs) and up to 20 Kg of luggage. All luggage carried must be securely mounted on the frame, uniformly distributed and fitted as low as possible, to minimize any adverse effect upon stability. The maximum total weight of the cycle, rider and luggage should never exceed 160 Kg. Unless otherwise stated, folding bikes are designed to carry a rider of up to 85kg (13st 5lbs) and up to 15Kg of luggage.
    Recently Viewed
    #985151
    srchar
    …or perhaps the target market simply has the pleasure of riding on the UK’s decrepit road network, with the potholed, cracked and patched-up stretches of tarmac that qualify as roads.
    #985149
    EddyBerckx
    BSA rules wrote:
    BSA rules wrote:
    Hi all, thanks for all the posts/advice, I addmit now it looks like I’ve fallen for all the marketing/reviews/ hype, maybe i would’ve been much better off updating my 2005 trek madone with bigger tyres/higher stem/better bar tape/and comfier saddle as advised. Looking at both bike’s together, the trek has smaller diameter frame tubes everywhere as well as much thinner forks compared to my “endurance/sportive” bike with it’s oversized but trendy frame and fork, it makes sense now that fitting larger tyres will make so much difference to comfort levels,but that’s not what I read in the reviews, it’s all about one bike in a test of many winning in the comfy bike stakes on the tyres it came with, ah well,we live and learn as they say, at least it’s a cheap fix,I don’t know why they bother with an endurance bike category just put higher bars and bigger tyres on a race bikeand Bob’s your uncle!!!
    i doubt your 2005 bike will take anything bigger than 25mm tyres tbf
    Thanks to bike manufacturer innovation disc brakes (and the wide widths they enable) are now commonplace – yet people have been raging against this “marketing bs” for years…it’s not all a con and EVERYONE HAS A CHOICE!! ?
    #985147
    BSA rules
    #985145
    Chris Hayes
    Dump it on eBay….there’s
    Dump it on eBay….there’s still a shortage of bikes.
    #985143
    BSA rules
    Hi all, thanks for the posts/
    Hi all, thanks for the posts/ /ideas, now I feel like I’ve fallen for the sales, reviews,marketing hype sucker punch! I would have been a couple of thousand pounds better off if I’d have just swapped the tyres/bar tape/seat post/higher stem and saddle on my 2005 Trek madone, looking at both bike’s the trek has smaller diameter carbon tubes everywhere including much lighter looking forks compared to the huge looking tubes and forks on my new sportive/endurance bike,ah well we live and learn, thanks for all the posts.
