Viewing 15 replies - 2,011 through 2,025 (of 3,165 total)
  • #965813
    Not just any lorry…
    Not just any lorry…
    https://www.gazette-news.co.uk/resources/images/14100996.jpg?type=responsive-gallery-fullscreen
    https://www.gazette-news.co.uk/resources/images/14101142.jpg?type=article-full
    https://www.gazette-news.co.uk/news/20279193.marks-spencer-lorry-gets-stuck-colchester-side-street/
    I do not know how the driver decided to embark on this short cut. It must have been difficult to even make the first turn off the high st.
    #965811
    I think the tight fit theory
    I think the tight fit theory must be right – 99% sure you’d have to pass under the bridge to get to/from the pier and you wouldn’t want to be a passenger on the top deck if so.  Also did you notice the second picture on the article? is this where someone says “a lick of emulsion will sort that”? In this case, I think it would.
    Also in Google street view, it briefly captures an enclosed scaffold column under the bridge:  perhaps making good the last incident?
    https://cdn.road.cc/wp-content/uploads/roadcc/EEC0C064-B38F-4C8C-8124-DD4FD1D6F8BD.jpeg
    #965809
    No buildings harmed here, but
    No buildings harmed here, but tell me again how LTNs delay the emergency services? Surely if lives are in danger, the fire brigade are less worried about some driver’s paintwork?
    Solar panels kicking out so much power they’re overloading?
    Warning over ‘inappropriate’ parking after fire in Verwood
    https://www.salisburyjournal.co.uk/news/20272609.warning-inappropriate-parking-fire-verwood/
    #965807
    To see its flat-mate?
    I met a double decker bus on my Sunday ride, out on one of our lovely tree-lined OS yellow roads, where no bus has run in decades and probably not ever a double decker. Wedding reception, was my best guess.  At least the height of a bridge is known, overhanging trees, not so much.
    #965805
    stonojnr wrote:
    stonojnr wrote:
    But there’s not an alternative road the bus could take, how did it get to the pier in the first place ?
    It is odd. From the lamp posts visible in the photo, and comparing to Street View, it does appear to have been attempting to drive out away from the sea. Maybe the open top bus is close on height, and would just fit if driven right down the middle. In which case, it wasn’t “driven accidentally under the bridge,” it was just driven incompetently under the bridge.
    #965803
    But there’s not an
    #965801
    Another rail bridge strike.
    You can see the deformed tracks resulting from this.
    https://pbs.twimg.com/media/FXeRPf3X0AAekwZ?format=png&name=small
    #965799
    Found better images, and one
    Found better images, and one sign says clearance is 11′-9″, and the other says 3.5 m, which is just under 11′-6″.
    Google says a London double decker is over 16′ tall, the shortest I could find is 12′-3″, and even a single decker bus is over 10′ tall.
    This is like me trying to drive my MINI under a lorry trailer. Oops, it accidentally didn’t fit.
    #965797
    Nice looking bridge.
    Should of course be covered in hiviz retroreflective warnings.
    Not that it makes that much difference….
    #965795
    hirsute wrote:
    hirsute wrote:
    “Following a promotional event outside the Clacton Pier on Sunday evening, the Clacton Breeze Open top bus was driven accidentally under the bridge causing damage to the front of the bus on the upper deck.”
    Accidentally driven under the bridge? Did the bridge suddenly jump out in front of the bus? I think it’s a safe bet that the bus was deliberately driven (most of the way) under the bridge, it’s just that the driver either:
    • didn’t know what these signs mean
    • didn’t know how tall the bus was
    • wasn’t good at maths
    • was an utter moron
    https://cdn.road.cc/wp-content/uploads/roadcc/clacton.png
    #965793
    This one is worse than the
    This one is worse than the initial headline I saw
    https://www.altonherald.com/news/999/woman-safely-rescued-from-car-crushed-by-hgv-at-wrecclesham-bridge-554601
    https://tindle-web-prod.brightsites.co.uk/tindle-static/image/2022/07/12/07/1a055e32-d29c-41bb-ac6c-f4ad824fb14a.JPG?width=669&height=445&crop=669:445,smart&quality=85
    Bus hits bridge – luckily no passengers at the time.
    https://www.gazette-news.co.uk/news/20272285.open-top-bus-crashes-venetian-bridge-clacton/
    #965791
    Rooted to the spot (with luck
    Rooted to the spot (with luck).
    #965789
    Better pack a gilet!
    Joking apart, I’ve reached the stuffing paper down my front stage a couple of times as it often drops a couple of degrees on my two fave routes.
    #965787
    Another driverless car
    https://www.gazette-news.co.uk/news/20269788.car-collides-tree-clingoe-hill-colchester/
    “A car caught fire after it left the road and collided with a tree in a incident off a busy roundabout, it is understood.”
    The status of the tree is unclear.
    #965785
    ktache wrote:
    The story that got me was that only one side of the suspension bridge was getting a heatwave.
    You may laugh (and yes, it is a f-ing stupid statement that they made) but there are definite areas that have microclimates.  If I’m riding home, I go down into the village of Abbots Leigh and the temperature noticeably drops by several degrees for a hundred metres or so.  I keep expecting to see the Ghostbusters investigating this Cold Spot…
