- This topic has 21 replies, 20 voices, and was last updated 11 years, 4 months ago by .
Repair the puncture or throw it away and replace with new?!
Replace tube while out, fix
Replace tube while out, fix punctured tube when you get back home, to be used as spare tube next time.
I used to like sitting down
I used to like sitting down and repairing a few punctured tubes all in one go very a very satisfying feeling… mind you, that could’ve been the glue
repair, i had a tube with 8
repair, i had a tube with 8 patches, only replaced after the valve went
little nick about 8mm from
little nick about 8mm from the seam , ive repaired and left in the garage to dry before i give it air and put a new one on the bike
Depends, if the puncture is
Depends, if the puncture is on the seam, bin it, its much more likely to rupture dramatically (read ‘explode’) and temporarily deafen you in at least one ear. If its not on the seam fix it, its cheaper in the long term
Always new tube
Always new tube
