- This topic has 25 replies, 16 voices, and was last updated 14 years, 8 months ago by .
Just had a confidence crisis, not sure I’m doing this right
Def under. Stops bib straps
Def under. Stops bib straps rubbing.
Has to be under
Has to be under 🙂
Yep, good to see I am with
Yep, good to see I am with the majority on this one – under for sure
Under. Helps if you need to
Under. Helps if you need to go to to the loo.
Whew,thanks that’s a relief
Under. Comfy.
Under. Comfy.
Under, close fitting next to
Under, close fitting next to the skin. your trying to reduce air flow (draughts) to improve insolation (at least in winter).
IIRC the base layer is meant
IIRC the base layer is meant to be against your skin to draw away the sweat and stop you getting a chill. If it was over your bibs then it wouldn’t do it as effectivly apart from the chest and back area where the bib doesn’t cover.
same here – base layer, bib
same here – base layer, bib then top
in the summer the base layer is given a miss
Base layer underneath for me.
