Clicking noise every 1 & 3/4 turn…What to do?
  • This topic has 37 replies, 13 voices, and was last updated 7 years ago by Huckfinn.
  • #30065
    Huckfinn
    Hi all!
    I seem to have this annoying issue on my new bike with Ultegra RX.
    Crankset is 50/34, Cassette 36/11.
    Every time I’m on 34-27 (sometimes 34-32) I have this disturbing clicking noise exactly every turn and 3/4 of the crankset. It also happens when on 50-27 (which I don’t use often).
    Some cyclist remarqued that my tiny screws on cassette have to be adjusted (basically the external one for the larger cogs, the internal for the smaller cogs).
    Not sure how to go about it but… Can someone help me fix it myself?
    Thanks for any feedback
    H.
    PS: the noise doesn’t come from saddle/saddle post or when I lift the bike and just turn the pedals…
Viewing 7 replies - 31 through 37 (of 37 total)
  • #949133
    fixation80
    My experience of these kind
    My experience of these kind of regular clickings have been related to the chain, twice a link has been coming detached and once a stiff link clicking as it negotiated the jockey wheels.
    #949131
    Huckfinn
    Thank you all.
    Thank you all.
    “Pop the bike in that combination with it in a bike stand and slowly back-pedal the cranks – any kick from the rear mech?”
    I actually hear the click but seems to come from crankset accompanied by a sort of minor vibration..
    and: I’m now in a quite place and, in fact, if I suspend the bike and just pedal away I also hear it, in that gears combination, without mounting the bike!
    #949129
    CXR94Di2
    Huckfinn wrote:
    I suspended infact the bike and tried but could not hear the noise….
    And, no! I don’t…
    AND, by the way, thanks for getting back to me!!
    Read this Shimano doc on adjustment of ‘low’ and ‘high’ adjustments also ‘end adjustment’ or B screw more commonly known
    https://si.shimano.com/pdfs/dm/DM-RXRD001-01-ENG.pdf
    Watch a few youtube videos of how to setup and adjust rear derailleurs.
    Things to bear in mind with niggle faults, correct width chain 10 speed or 11 speed.  There is a small difference in width between the two chains and on most setups, it really doesnt affect performance but some bikes are a little temperamental so require the correct kit.
    #949127
    Some things are onlt apparent
    Some things are only apparent when putting power through the drivetrain.
    Park gives great workshop advice, here’s their page on rear derailleur adjustment
    https://www.parktool.com/blog/repair-help/rear-derailleur-adjustment
    Good luck, bicycles should be quiet, and any noises are very irritating.
    #949125
    kil0ran
    Stiff chainlink?
    Stiff chainlink?
    #949123
    Huckfinn
    And, no! I don’t…
    #949121
    CXR94Di2
    What you need to do is get
    What you need to do is get the bike on a stand or suspend it, so you can hand pedal slowly.
    Watch and listen to the chain passing over the gears and through the derailleur.  Do this slowly because a tiny click can usually be seen even at very slow chain speeds.
    Ive sorted quite a few minor niggling issues by using this method. Its generally due to minor indexing derailleur alignment/position or bent/damaged parts.
    Do you know how to use the end stop screws and B screw adjustments and inline cable adjusters?
