- This topic has 25 replies, 9 voices, and was last updated 7 years, 3 months ago by
ktache.
August 18, 2019 at 6:18 pm #30027
bikelo
The bike was £275, I’m not sure if a £25 u lock is enough or one for £32 with rope is better, Anyone know from any cheap websites to get from ?
jaysa wrote:
It’s not necessarily twice as secure. If a thief can cut through one arm of a 13mm lock shackle unmolested then they’ll may have time to do both. I’d consider two different types of lock but even then you’re buying extra time, not a guarantee that your bike won’t get stolen.jaysa wrote:I gave away a Kryptonite Kryptolock 2 because it locks one side only of the D (the other side ends in a bend), so a single cut releases the lock. The Clas Ohlson locks both ends of the D, so two cuts in thicker metal are needed to release …I have the Series 2 D-lock and it’s probably overkill for where I live. I mentioned the 785 chain because I’d recently seen a video by a locksmith (lockpickinglawyer on YT?) who was impressed at how resistant it was to picking. I like the idea of a chain because it’s easier to carry than the D-lock. Both are inexpensive next to supposedly more secure locks.
In the end, for a relatively inexpensive bike, I’d check my household insurance will cover it then I’d buy a decent lock for rear wheel & frame that doesn’t weigh a tonne plus a secondary lock (a chain type or armoured cable) that will go through the front wheel and frame. I’d not waste energy worrying about it.
jaysa
Many of the negative Clas
Many of the negative Clas Ohlson reviews are Swedish, complaining of the lock seizing up and keys not turning. It dries up , so if you keep it oiled/lubed it’s fine – some of the Swedish reviews say that.
Round my way, thieves are a greater risk, so the price/performance works for me.
I am a big fan of Kryptonite,
I am a big fan of Kryptonite, they just look the part.
But for cheaper, very good value OnGuard are meant to be good, they definitely look the part.
When I looked them up Trendz has many Gold SS locks, proper bargains
zero_trooper
What do you want the lock for
What do you want the lock for? Home or work, outside the supermarket, or cafe stops?
bikelo
Tom_77 wrote:I have this (“Oxford 10 Square Link Chain with Double Locking Padlock”) for locking the bike up at home:£30, Gold rated. Weighs a little over 3Kg.
For a portable lock I use a Kryponite KryptoLok D-lock with a cable. Anything that’s Silver or Gold rated ought to be good enough.
Do you have a link for a latter?
Is it this one ? https://www.halfords.com/cycling/bike-locks/bike-locks/kryptonite-kryptolok-d-lock-with-4-foot-kryptoflex-cable
bikelo
jaysa wrote:A good value Gold rated lock is Clas Ohlson’s 31-2166 (catchy name …) for £18.99It has an 18mm shackle, so you can use it to break down doors if you like.
It’s weatherproofing isn’t great, so grease / oil it regularly if using in the rain – otherwise it’s fab.
I threw away all our rubbish locks and we use three of these now.
those reviews are shocking though, can anyone else recommened this or anything else that I should use ? and first replier how much is that and do you have a link?
That Clas Ohlson looks a
That Clas Ohlson looks a proper bargain. The reviews are telling mind.
jaysa
No lock is thief-proof and
No lock is thief-proof and you can drive yourself mad with the myriad options available. Kryptonite series 2 u-lock and Keeper 785 chain (85cm,Sold Secure silver rated) are good, inexpensive options that would deter all but the most determined and well-equipped thief.
Heavier, stronger locks probably won’t really provide significantly greater security. OTOH cable locks are pretty weak. Many can be cut with pocketable pliers so are usually only recommended as a second lock through a wheel or for 5 minutes or a cafe stop where the bike is in sight.
I’d buy from a reputable online retailer so you can be sure it’s genuine.
