Converting cable discs to hydraulic
  • This topic has 19 replies, 15 voices, and was last updated 8 years ago by Paul7189.
  • #29012
    T_B_K
    Can anybody advise me on this. I’ve had many fruitless google searches.
    I have a cannondale synapse 105 with cable disc brakes – which I’ve been running as my winter bike for three winters but since I’ve purchased a hydraulic brake cyclocross bike I’ve realised I’ve been accepting dangerously poor brake performance on my cannondale for too long.
    I had intended on getting a second set of wheels for my cyclocross bike but I have had a change of heart and wonder if converting the cannondale cable disc brakes to hydraulic may be similar cost and allow me to keep my much loved cannondale. I intend to get this done by my LBS but I’m not sure if it’s possible or the right decision.
    Any help or or advice would be very welcome as I seem to be going round in circles on this.
Viewing 4 replies - 16 through 19 (of 19 total)
  • #928321
    sizbut
    Having bikes with TRP Sprye
    Having bikes with TRP Sprye and TRP Hy-Rd I can say that the Hy-Rd are a significant step up in braking power. The initial lever movement before braking starts does throw you at first but you find yourself adjusting for that very quickly.
    The only thing that worries me now is that I’m braking much later for things because I know I will stop – its bound to all go wrong sometime. 😉
    #928319
    vonhelmet
    You could try TRP Hy/Rd
    You could try TRP Hy/Rd brakes – cable actuated hydraulic brakes. They’re about £200 new for a pair. They get fairly good reviews, though a consistent grumble seems to be long lever throw before they do anything. That’s about as close as you’ll get without much greater expense and possibly the frame mutilation referred to above.
    #928317
    CXR94Di2
    Dremel tool with grinding
    Dremel tool with grinding head would easily open the holes-done carefully it will look factory
    #928315
    Mr Pennington
    The problem you’re going to
    The problem you’re going to run into is hydralic hoses not fitting through the frame cable holes. If you have an LBS who can enlarge cable holes to hydralic hose diameter then go for it.
