- This topic has 20 replies, 13 voices, and was last updated 8 years, 2 months ago by .
Just wanting to vent a bit.
I’m cycling to work this morning on a shared-use path – through Abbots Leigh just outside of Bristol.
I go to cross a side road (from the left, for any cars coming out of that road). I was coming out from behind the pub you can see here – https://goo.gl/maps/tejryrhLjcp – I was crossing from left to right across this streetview picture (The footpath was turned into a shared-use path and upgraded a couple of years ago, and the council announced at that time that they had no intention of making any sort of changes to priorities on any of the side roads, as that might hold up the traffic…).
Anyhoo: the side-road appears clear, but as I reach the kerb a small hatchback type car races up to the give way line, angled slightly to the left and with the driver *only* looking to her right, clearly intending to turn left out onto the main road. Having to change my line at the last minute I go up the side of her and around the back – I was about three feet behind her car (maybe two).
I’m nearly out of the way when she decides to finally move forward onto the main road, but she clearly was trying to hold her car on the clutch, as she rolls back before catching the car again on the clutch bite: her car knocks my back wheel and rack with a crunching sound. She brakes, rolls down her window as I shout, and opens by saying that I’ve run into her, until I point out that she’s rolled back and hit me.
She then shouts that I should have given more space to safely pass behind her, and I point out that I was ready to go out onto the road when she approached it at speed and only looking to her right (at no point did she look to her left), and what if I had been a child?
She gets out of her car, starts to move down the side of her car toward the rear then has to leap back in and put the handbrake on as her car starts rolling backward (!!!).
She carefully inspects her rear bumper, tells me off again for passing her too close, how its all my fault and she hopes I’ve learned my lesson, and then drives off.
(Five minutes later I wish I’d laughed at her when her car started rolling away without her in it, and maybe said that it proved my point…)
