- This topic has 23 replies, 13 voices, and was last updated 8 years, 10 months ago by .
I bought a 130psi hand pump.
I had to use it today.
I went to leave work and noticed my front was flat.
A Maxxis refuse 700*28c with an inner and outer tube protector. I pulled a 4 mm deep thorn from the tire, pulled the tube out, the tube appears to be non punctured so I reassembled and rode home. The rear had deflated too.
I guess a work mate is helping me learn..
Anyway having inflated both tires, upon getting home I added more pressure using a decent floor pump.
I seem to achieve 30-40 psi using the hand pump! Is this normal? I rarely get punctures, I can’t remember the last tube that was punctured yet I wouldn’t want to ride 30km upon the pressure achieved from my hand pump!
I use 2 road bikes. Both use the same front rim; a refuse 28. 1 rides both refuse 28. The other being tonights bike rides a session 28 rear (a lot more volume with no problems at 40 psi).Did I get sucked into a did road bike pump?
A Samurai bbb/bmp-50 mini pump.Any suggestions please per road side 100psi?
My best guess is to purchase a co2 inflator to do the effort bit of 30-100psi with.
Next best guess is a larger volume higher pressure pump.
