- This topic has 47 replies, 14 voices, and was last updated 8 years, 11 months ago by
HurdyGurdy.
October 2, 2017 at 9:54 am #27698
ibr17xvii
Finally got sick of the British weather so the time has come to invest. I fancy a direct drive version & will deffo be using Zwift.
I’d be grateful for any tips / recommendations & also is a trainer that Zwift can control the resistance a must?
Sounds like a good idea to me but they are a fair bit more expensive so if you were in my shoes would that be a dealbreaker?
ChasP
Argos74 wrote:http://www.halfords.com/cycling/turbo-trainers/trainers/elite-turbo-muin-smart-turbo-trainerDown from £499 to £290. Works fine, though I’ll need a new computer to get the full benefits – not much software out there for old 32-bit computers.
At the moment I’m using GoldenCheetah which doesn’t pick up power correctly. It thinks I’m cranking out 14,000 watts, cruising at 130kmh, with sprint bursts of 200 kmh.
Have you got the sensor configured correctly?
ibr17xvii
I’ve looked at that one before but I’m pretty sure Zwift won’t control resistance so ruled it out.
Great price though & if I was looking for a cheap (ish) introduction to trainers I think I’d buy it.
Argos74
ibr17xvii
CXR94Di2 wrote:You can get a refurbished Kickr with a year warranty(2yr limited) from Wahoo £649http://uk.wahoofitness.com/devices/bike-trainers/original-wahoo-kickr-powertrainer-refurbished
When they come back into stock!
Great shout, I’ll certainly be keeping my eye on that.
CXR94Di2
If you’re a heavy rider the
If you’re a heavy rider the Tacx Flux 10% incline might not be enough to give real resistance feel on high percentage climbs, Ok if you’re a lightweight.
CXR94Di2
ibr17xvii
CXR94Di2 wrote:
CXR94Di2 wrote:
Yes I use the Kickr. It’s the V1 model. It’s been absolutely solid in operation. I trimmed a small section off the cowling due to it catching my long cage derailleur. This issue was eliminated on V2 with a sleeker cover. V2 has a new method of power reading by analysing the magnetic forces in the electronic brake. More accurate and reliable in operation. V1 uses a strain gauge which I’ve heard can be easily damaged when transported. Good news was a couple of weeks back there was a firmware update to V1 which altered the power reading to that of V2 so disabled the sensitive strain gauge. There is now a V3 which allows the bike to be lifted on the front to simulate climbing hills, you need the climbing mount aswell. I can recommend the Kickr, works very well on Zwift Trainer road and others. Early versions cost around £650-700 new, with a new model expect some discounts for V2ibr17xvii wrote:Thanks chaps.
You use either of them CXR94Di2?
Cheers for the info, very helpful.
The V1 is £799.99 which is absolute top whack of my budget which I don’t mind paying if it it’s for the right one. Will certainly take a close look at it now.
Currently eyeing the Tacx Flux which is £699.99 on Wiggle but is widely available at £629.99 so they should price match it.
CXR94Di2
ibr17xvii
cortina wrote:I was in the same position – went for the 2017 Neo. Unfortunately it died after 25 minutes of use and was returned to Wiggle. I decided not to get a replacement due to so many stories of similar issues. Great bit of kit if you’re lucky enough to get one that isn’t faulty.Another reason why I’m slightly limited is that I would prefer to buy from Wiggle.
Always had top notch service from them not just with things that have worked out but when things haven’t & I’ve had to return stuff.
This is a large investment & would rather not take chances.
cortina
ibr17xvii
jaysa wrote:I use a Tacx Neo with VeloReality and would recommend.Some chainstays can foul the unit if they are bent in too much to avoid your shoes, and the 2017 version appears to fix that. It’s quiet at 300W, but gets a bit louder beyond 600W – still much quieter than fan or hydro units though.
Tacx Neo certainly looks the business but it’s the budget buster that’s for sure.
jaysa
ibr17xvii
Thanks chaps.
Thanks chaps.
Team EPO
I reckon we are due an update
I reckon we are due an update soon but here is DC’s latest reviews
https://www.dcrainmaker.com/2016/10/annual-winter-2016-2017-bike-smart-trainer-recommendations.htm
CXR94Di2
Wahoo Kickr, tacx Neo.
Wahoo Kickr, tacx Neo. -
