- This topic has 44 replies, 20 voices, and was last updated 9 years, 2 months ago by
rollotommasi.
September 18, 2017 at 11:34 am #27654
Looks like the fixie rider has gotten 18 months.
rollotommasi
Bikebikebike wrote:The stopping distances quoted in the trial for the single-brake bike were about the same as a car. And given you’re less likely to hurt someone going at 18mph on a bike than a car, it’s really a struggle to say that 18mph on a bike is criminally reckless.But it’s not the cycling at 18mph in itself that’s criminally reckless. It’s cycling in a way that’s reckless for the current road conditions. Plus failure to take reasonable steps to avoid a collision (i.e. braking). Plus using what he knew (or should have known) was an unroadworthy and unsafe bike. Plus lack of remorse.
Bikebikebike
rollotommasi wrote:Bikebikebike wrote:18 mph = reckless?18 mph may be reasonable, unreasonable or reckless. It depends on the road conditions at the time.
To give a slightly exaggerated example, which can still apply in some way to a high street. The speed limits on the roads around Murrayfield or Wembley may be 30mph. But that doesn’t give me the right as a cyclist or driver to drive at those speeds if crowds are spilling out of the stadium onto the streets.
In this case, the Evening Standard reports the judge as saying that Alliston was shouting and swearing at pedestrians (plural, not just Ms Briggs) to get out of the way. So he knew there was a clear risk of collision but still chose to cycle on at 18mph.
If you haven’t got a bell then shouting is what you do. If he was ringing a bell whilst going along does that indicate he know there was a clear risk of a collision?
Plus we all know that if a car had hit a pedestrian who had stepped out without looking going at 18mph then they would not be looking at a custodial sentence, or even a prosecution. The stopping distances quoted in the trial for the single-brake bike were about the same as a car. And given you’re less likely to hurt someone going at 18mph on a bike than a car, it’s really a struggle to say that 18mph on a bike is criminally reckless.
Jimmy Ray Will
theironduck wrote:Bikebikebike wrote:18 mph = reckless?From the other thread, the judge commented that “If your bicycle had a front wheel brake you could have stopped but on this illegal bike you could not and on your evidence, by this stage, you were not even trying to slow or stop…You expected her to get out of the way”. I’m not really sure what to make of this. Was it the illegal bike that was reckless? Was it his supposed failure to try to stop (which seems to contradict the prosecution case that he was incapable of stopping) that was reckless? Some clarity would be helpful.
This just highlights how emotive and non objective this case was.
I felt the judge had a job to do in comments and failed here. It is not possible to say if 18mph, or 14mph or even 10mph, which I believe were all put forward as potential speeds the cyclist was travelling at, was objectively reckless. What made it objectively reckless was that without a front brake, practically any speed was unsafe.
To me that should have been the focus. Shouting, not shouting, braking, not braking at the time of impact… its totally irrelevant.
I have shouted at pedestrians being stupid and risking both their own and my safety. I was right to do so as well. Is it right, that should I have hit someone 2 minutes later that my previous shouting shoud be seen as evidence of recklessness? It doesn’t prove or demonstrate a thing.
The finer points of the impact were equally irrelevant in my opinion. He shouted because he couldn’t stop… because he didn’t have a front brake. He was not neglecting his responsibilities beyond not having a front brake. shouting was probably the best thing he could do. It does not objectively show recklessness.
Who cares if he swore or not, either before or after the incident. He wasn’t being a twat he was acting in the heat of the moment. A moment that was more heated than it could have been if he’d had a front brake. Swearing does not objectively demonstrate recklessness.
Not braking at the point of impact wasn’t displaying objective recklessness… it was, I’m sure the best course of action the rider felt he could take at the time… Again, because no other course of action was in place because he didn’t have a front brake.
There should be two takeaways from this case.
1. There needs to be tigher control of bikes being sold without front brakes as standard.
2. Cyclists need to be made more aware of their legal requirements when it comes to equipment. For every knowingly reckless hipster ‘dude’ out there, there is a simply ignorant person riding around without working brakes… we need to stop ignorance ruining lives.
Canyon48
jh27 wrote:wellsprop wrote:The stupid thing is I make sure I’m in primary position and cover my hands with my brakes at all times, both these collisions happened as I was following motor traffic.The fact that you were in primary position and covering your brakes (presumably not your hands), possibly contributes to the fact that you are here to tell the tale and not under some vehicle that was trying to over take you (which far to many motorists will do, if you aren’t in primary, even when you are travelling at the same speed as the vehicle in front). That said, and I’m not accusing you, it is possible that if you were in primary position and closely following the vehicle in front, said vehicle may have obscured you from the view of any pedestrians looking to cross the road (assuming they looked).
I was following reasonably close (as close as you’d expect most motor vehicles to follow each other and in primary position – so you are right that it is possible I could have been slightly hidden.
The annoying thing is, if I rode not in primary position and followed the traffic from a distance, some impatient nutcase will overtake then cut in front.
What do you want to die of I guess :/
theironduck
rollotommasi
markfireblade
It’s not the speed of impact,
It’s not the speed of impact, it’s cheerfully doing it on a bike with no front brake and the twat’s general attitue to everyone else on the road that makes it “reckless” I’d think. If you show consideration for everyone else and don’t ride like a knob, no-one’s really that bothered about your speed….
rollotommasi
wellsprop wrote:It’s just when you compare it to incidents like the bin lorry driver who knowingly drove with medical conditions – the CPS didn’t even prosecute.I have some sympathy with the argument that he should have been prosecuted. But, from my reading of that case, the Procurator Fiscal Service (i.e. the Scottish version of the CPS) didn’t choose to treat that driver leniently. They concluded that dangerous driving laws as they stand didn’t allow them to prosecute in a way that would secure conviction, because they couldn’t show criminal intent from reckless actions when the crash occurred as he was unconscious then.
In other words, I think your example is good at showing why dangerous road use laws should be revisited (if the PFS wasn’t able to build a prosecution on the fact that he should have known that his health condition could lead to him driving dangerously).
But it doesn’t show a driver being treated more leniently than a cyclist.
Canyon48
Bikebikebike wrote:rollotommasi wrote:Wellsprop.I’ve not read the judge’s statement, and I guess you may not have either.
But, from what I understand, the proper comparison isn’t simply with “motorists [who] run over pedestrians”. The proper comparison would be about what sentence was given to a motorist who drove a car they knew (or reasonably should have known) was unroadworthy; who drove in a reckless manner; and who showed no remorse for their actions.
I can’t point to any specific cases. But I’d guess any motorist convicted in those circumstances (unroadworthy vehicle; reckless driving; no remorse) should also expect a custodial sentence of at least the same length.
18 mph = reckless?
This is just it, 18mph (even in a city centre) is not reckless. The law needs to be bought up to date so he could have been charged appropriately.
I’m very concerned about what this ruling could potentially mean for me.
When I commute through Bristol, I keep up with the traffic (often I’m going faster than the traffic).
So, if I’m keeping up with the traffic at around 20mph in the city centre and someone steps into my path. In the event that I am unable to avoid a collision, am I liable for wanton and furious driving?!
I’ve had a couple of collisions with pedestrians in Bristol city centre. One was too busy looking at their phone to even check to see if the road was clear, the other just walked straight into my path after looking at me. I’m not alone either, most of my mates who cycle have had collisions with pedestrians who have stepped into the road without looking.
Bikebikebike
18 mph = reckless?
Canyon48
I ought to clarify. The idiot was riding a fixed wheel track bike without a front brake on the road. Which is illegal.
He doesn’t deserve to get off particularly lightly – I agree with tough sentencing.
In reality, all road traffic offences – particularly involving death – should carry heavy sentences. I just wish judges would apply this to ALL road users equally.
rollotommasi
Wellsprop.
Wellsprop.
Canyon48
Literally just seen that.
Literally just seen that. Makes me despair.
18 months because he didn’t stop in time and didn’t have a front brake.
Meanwhile, motorists run over pedestrians and it’s called an accident.
