Spitting whilst cycling – yes or no?
  • This topic has 30 replies, 26 voices, and was last updated 9 years ago by don simon fbpe.
  • #27345
    Canyon48
    Just seen this come up on another thread and I’m curious – who thinks it’s acceptable to spit (or snot rocket) whilst out in public cycling?
    I’ll lay down my cards first.
    Nothing wrong with it, providing you aren’t being stupid. Personally, I find that sometimes, when out on a cycle I’m left with little choice – either spit and clear my throat/mouth of gunk – or swallow it and probably choke to death.
    Obviously, I would avoid doing this on the high street of a quaint country village, but I see nothing wrong with departing with it into an unassuming hedge, away from built up areas.
    I would also argue that what comes out the back of cars is far, far more disgusting and polluting than what comes out during a snot rocket (though neither is particularly pleasant!).
    Thoughts?
    – Please don’t take this too seriously, it’s meant to be a bit of fun 😛
Viewing 15 replies - 16 through 30 (of 30 total)
  • #897133
    Al__S
    into a hedge from the back of
    into a hedge from the back of the group? Really can’t see what the problem is. If you’ve got phlegm, it’s usually better out than in
    #897131
    madcarew
    Kind of belongs in the “you
    Kind of belongs in the “you know you’re a cyclist when…” thread.
    And yep. Any time.
    Did snot rocket one time and got the wing of a BMW that was passing. The driver wasn’t happy and stopped and ‘asked’ if I did it on purpose. I asked him if he meant to pass me less than an arms length away on purpose.
    Pro tip… do it under your arm and it will land just outside of your pedal. Can be safely done just about any where then.
    #897129
    drosco
    Never have, never will. Just
    Never have, never will. Just gross.
    #897127
    One just needs to know which
    One just needs to know which side is on, if the right nostril needs clearing out then ensure to be in primary/outside if two/three abreast, if it’s the left nostril then on the inside.
    Etiquette dicatates a left nostril vacuation is done thusly;
    Visual check for busybodies whom will frown upon your vacuation, if a neighbour/A.N.other you don’t get on with is in the vicinty proceed as normal. check for other cyclists, if unwanted wheel sucker in vicinity, proceed as normal.
    final wind direction check, no point going through if wind direction will likely mean a face full of flob and will ID you as a newbie to the world of flobbing on the go to others.
    Turn head left and down, raise elbow forming an arch with your arm to give plenty of room and reducing chances of flob/goz from landing on you, press robustly against the right nostril (certainly don’t want any blowback from right nostril!!), inhale and blow for all you’re worth.
    Note size and direction of excretion for future analysis on stravawanker, ensure to check for any stragglers around nostril to be wiped by glove (you are wearing gloves right?), casually take sip from bottle.
    However, bonus points are awarded for braking, gear shifting, making acute turns/avoding potholes whilst in the act of vacuation, double bonus points if you break with etiquette and manage a full on flob onto the side window of any lowlife moton that you caught up with that razzed you not 30 seconds previous.  Triple bonus points if you get it through an open window, actually get it through a narrowed gap and hit said moton you get a free tommy tank off one of the fat slags from viz comic and a packet of haribo.
    #897125
    kil0ran
    Just swallow it, its not
    Just swallow it, its not poisonous and means you recycle some fluid/protein. Do it enough and you’ll get by with one less gel per ride 😉
    #897123
    700c
    guyrwood wrote:
    guyrwood wrote:
    I’ll spit if there’s no one around and I need to clear my throat, hard exercise causes expectoration and it needs to be gotten rid of. I wouldn’t do if there were any ‘civilians’ around though, I’d wait until I was on my own.
    Snot rocketing is f*cking discusting though. I was on a sportive a couple of weeks ago and a bloke did it right in the middle of a group which included me. Utterly revolting, stop and blow your nose if you need to, don’t cover other people in it.
    As you say, exercise often brings it on so there’s no difference whether it comes out of your mouth or nose, surely. It’s the same stuff.
    Always check you’re not doing it into path of another rider or vehicle etc.
    #897121
    Ush
    You have to make sure that
    You have to make sure that you do a proper gorge-cleaning, gargling and choking sound first in order to follow etiquette strictly. Personally (as I say to people in many other situations) I would prefer that you swallow 🙂
    #897119
    Sevenfold
    Yes, generally when I have
    Yes, generally when I have half swallowed a fly…
    #897117
    Dnnnnnn
    Yorkshire wallet wrote:
    on the open roads anything goes.
    I’m sure there was a story here the other week about Wiltshire police looking for a cyclist fitting that description…
    #897115
    Ride on my own most days so I
    Ride on my own most days so I don’t give a hoot about it. Probably would try and refrain if I was going through a town centre or something but once on the open roads anything goes.
    #897113
    don simon fbpe
    No problem at all. This is
    No problem at all. This is why I urge a wheel suckers to announce their presence.
    #897111
    ClubSmed
    sergius wrote:
    Only really required when I’ve got a cold, and I don’t see any distinction spitting out a load of gunk into a hedge and having a quick slash in the bushes.  Both of which I’ll do when no-ones about.
    To my mind there is the difference between being outside and being in public. If you are out cycling and there are people around then you are in public, otherwise you are just outside.
    So taking this definition it looks like both posters so far agree that it shouldn’t be done in public.
    Whenever I have nearly been hit by such a projectile from the cyclist in front that I am approaching, I have never seen them look around to see if there is anyone around. So therefor I conclude that they do not care about doing such things in public.
    #897109
    Mungecrundle
    I do suffer horribly from
    I do suffer horribly from allergic rhinitis and am a veritable mucus factory. But there is a time and place to void one’s sinus or buccal cavities. Personally I do make an effort not to expectorate when it may offend others. Even whilst spitting when no-one is around, it can be an entertaining challenge to try and get it down a drain grate as you pass.
    However on last weekend’s rideout after a sneaky concealed snot rocket, one of the following riders did comment that they thought it might be coming on to rain, bless.
    #897107
    StraelGuy
    #897105
    sergius
