- This topic has 16 replies, 12 voices, and was last updated 9 years, 6 months ago by .
Hi all
Looking for some advice with regards to what i now know to be a fairly well documented problem…
I have a 2016 cannondale synapse ultegra disc and i suspect that it has already developed a creaky bottom bracket. Some digging has led me to a few bits of information:
1/ It is a common problem with bb30 bottom brackets which i believe mine is
[Edit: just realised it is a bb30a, so now unsure as to whether the adaptors will even work anyways…]
2/ there are adaptors available to relocate the bearings to outside the frame in the same vein as a htii bottom bracket setup. The favourites seem to be Rotor and Praxis on this front.
So with that in mind i am looking for some information regarding my options really, the cranks on the bike are the cannondale own brand ones that came with it and ideally i would like to keep the costs down as this is more a frustrating issue than anything more sinister. Would the cranks on the bike now be compatible with the above adaptors or would i have to shell out on a set of new cranks as well as the adaptor if i were to go down that route?
Any help would be much appreciated!
Cheers
Col
