- This topic has 17 replies, 13 voices, and was last updated 10 years, 4 months ago by
irh123.
April 12, 2016 at 12:53 pm #25599
irh123
Hello. I am fairly new to road cycling, mountain biked for years.
I have been using my mountain bike spd shoes but have now purchased some proper road shoes.
I am looking for pedals/cleats that give a good amount of float so as not to aggravate my knackered knees.
Many recomendations? Budget is up to £80 ish.
Cheers.
irh123
Thank you all for for your
Thank you all for for your replies.
I have taken a good look at the speedplays, they look like the best option for bad knees with the amount of float available. But they do seem to need a lot of setting up
But.
After talking to club members I am going to go with the ultegra pedal (which is cheaper than the speedplays) and get a professional bike fit (was going to get one anyway) as they set up your cleat position too.
matthewn5
Another vote for Speedplay
Another vote for Speedplay Zeros, infinitely adjustable float and if you buy a pair of aftermarket Keep-On-Kovers (sic) the cleats will never wear out.
Really easy to clip in and out, like spds, but super secure once in.
Best of all, double sided like spds, and you can add ‘platformers’ if you want to ride to the pub in your ordinary shoes.
D-Squared
Speedplay for me too – enough
Speedplay for me too on the road bike – enough float, and they come in variable length – keeping hips, knees and feet in the same line (my right knee in particular tends to swing in and out). Also have wedge to cater for shorter left leg. Not a lot of cartilage left on inside of my right knee – mainly from other sports. Still using spd on my mountain bike.
barbarus
It partly depends on why your
It partly depends on why your knee is dodgy. If, like me, it’s dodgy because one of your feet isn’t level then no particular pedals will help in the long run and you will need cleat wedges. Have you tried reading any of Steve Hogg’s websites?
Poptart242
Shimano pedals for up to 6
Shimano pedals for up to 6 degrees of float, very low maintenance, go on forever and parts/servicing super easy to come by.
Speedplays for dual sided engagement, unlimited float, and lots of maintenance (relatively speaking).
I’ve got some Ultegra pedals at the moment and fancied a change but to be honest I couldn’t find anything I really liked. I’ve an especially dodgy left knee but it doesn’t flare up on the bike with my cleats set up properly – enough float in the yellow cleats to keep my knee happy.
srchar
Pedals are personal. For
Pedals are personal. For example, I use 105 SPD-SL with blue cleats and have no knee issues. My brother in law uses Speedplays and, despite constant adjustment of the float and cleat position, has enough knee pain to keep him off the bike for weeks at a time.
OP, I don’t think you can get a usefully straight answer to this on a forum. You just need to try them.
Nixster
Another vote for Speedplay,
Another vote for Speedplay, Zeros in my case.
You can be fine with Spd-sl of course but if you’re getting pain then the every which way adjustability of Speedplay means you will almost certainly be able to resolve it. The maintenance issue is overplayed but while you can replace every part, those parts are expensive. Customer service is excellent though, they sent me some shims completely gratis once even though I’d bought the pedals second hand.
I would buy them again but the cleats are the weakness in the system design, very sensitive to dirt etc. but they last well.
freebsd_frank
fukawitribe wrote:I get mine re-greased every 1500-2000km or so by the place I got them from (Bike Science in Bristol) who don’t charge, which works for me.IIRC, Speedplay say re-grease every 1000 miles or so, dependent on what sort of weather you use them in.
They do a grease gun for their pedals but it’s horrendously expensive (over £40). For those who don’t have an LBS who can re-grease their pedals, you should be able to use a gun similar to this one:
As you say, clipping into them is much easier than SPDs. With my SPDs, I always had to look down, whilst wobbling about – not good. The Speedplays, I just stomp on the pedal approximately where my cleat should be and I clip in. Dual-sided entry is a big plus.
Like you, I’ve never unclipped from my Speedplays when I haven’t meant to.
madcarew
Which is better is going to
Which is better is going to be down to the individual, the particular issue with their knees, and their riding style, miles etc. I ride ultegra and dura-ace pedals and I have dodgy knees, and I hae no issues with those pedals at all. I find they provide a more stable base (fot can’t tip over as much) as with some of the other models I have tried (including an early version of speedplay). I can only vouch that for me, with slightly iffy knees, that the shimano model is not a limiting factor. Big gear work is another story.
dottigirl
irh123 wrote:
irh123 wrote:The reason for going away from spd ‘s is due to the pedals I’m using are old ones and I got a great deal on some road shoes.Just to play devil’s advocate: if you’ve found something which works for you, and doesn’t worsen your joint pain, I’d be wary of changing things too much. Could set off a very nasty hornet’s nest, and the amount of money you spend on trying different pedals could be more than you saved.
Remember also that you can walk properly in SPDs, whereas road shoes will change your gait.
(I have joint problems and once I have the pain settled, I’m very wary about changing my setup – the one time I did, I regretted it.)
fukawitribe
Another vote for Speedplay here. I’m using the Zeros and find them excellent for float and by far the easiest road pedal i’ve used to clip in to. I was using Time iClics, and they were pretty good – personally found them easier to get in and out of than SPD-SLs and about the same as SPDs, but with a more positive action. The reason I originally changed was I really benefitted from pedal spacers, and couldn’t use the Times with the spacers I had (they bolt through the back with a hex key)… can’t say i’ve looked back and would choose the Speedplays over them (or anything else i’ve tried) even if I had the choice.
The Zeros allow you to limit the float, should you wish, although I tend to run them pretty much ‘open’. Never had an unexpecte pull-out with them for what it’s worth, although that may say more about my power than anything else 🙂 If you do decide to try Speedplay, and aren’t using the new “walkable” versions, i’d recommend KeepOnKovers for the cleats – weigh bugger all, stay on, grip pretty well and stop the cleat surfaces getting knackered (also improve the clip in slightly IMO). I get mine re-greased every 1500-2000km or so by the place I got them from (Bike Science in Bristol) who don’t charge, which works for me.
Pedals are quite a personal taste but i’d say it’s probably worth you giving Speedplays a go – if you don’t like them the resale value is pretty high so I doubt you’d lose much, and might gain a lot. Best of luck with the search.
ibr17xvii
Just FYI about the Shimano
Just FYI about the Shimano cleats:
http://www.wiggle.co.uk/shimano-spd-sl-cleats-2/
I have a (reasonably) dodgy knee & went from the yellow to start with & then to the blue without an issue.
Obviously the key is to get them set up to suit but once they are not had a problem.
irh123
Thank you for your replies.
I didn’t realise that you could get different cleats with different amounts of float.
So next question- which are better? Speedplay stainless or ultegra 6800?
le Bidon
Ultegra carbon pedals with
Ultegra carbon pedals with yellow cleats (6 degrees of float). Job done.
For reference, blue cleats are 2 degrees and red are fixed.
dottigirl
What’s your reason for
What’s your reason for deserting SPDs? I’ve used them for years on my road bike.
