- This topic has 16 replies, 7 voices, and was last updated 10 years, 8 months ago by .
hi all,
Has anyone had experience with setting the preload on the Supersix Evo? I’m having real problems with play in the headset of my frameset after a short period of time (less than 10 miles). I’m running the max length of steerer allowed at the moment (55mm) until I get fitted properly.
The 55mm is frankly ridiculous so have ran tried it with 10mm and 15mm above the stem but with all 3 options I still end up with the same issue.
i’ve torqued the bung up to spec and then tightened the cap to set the preload but it never tightens the headset to the point I tightening the steering up and it looks like the top cap is deforming so am concerned I will do damage.
Any ideas?
