Garmin Heart Rate Monitor problems.
  • This topic has 22 replies, 17 voices, and was last updated 9 years ago by Leeroy_Silk.
  • #25422
    Leeroy_Silk
    Can someone help please?
    I have a Garmin HRM connected to a Garmin 800. A while back I noticed my heart rate would sporadically stop recording, when it did record I noticed my heart rate was much, much lower than one would expect. Since I first saw the issue, I’ve cleaned the strap and contacts, replaced the battery, I’ve tried pretty much everything I can think of to try and it still doesn’t seem to record properly.
    Currently, it’s doing this: turn on Garmin 800 whilst wearing strap and it finds strap immediately but doesn’t record a beat, go for a hard ride where I’d expect my rate to be 160 BPM + and it records a max of 85, as I cool down it stops recording again, despite still being connected.
    Any advice, even if to tell me it’s kaput!
Viewing 7 replies - 16 through 22 (of 22 total)
  • #867333
    700c
    Weird. My soft Garmin strap
    Weird. My soft Garmin strap has been fine since I had it (18 months, intermittent use)
    Stupid question, but are all those reporting problems thoroughly wetting the three contact points before use? It will continuously drop out if you don’t.
    #867331
    sergius
    I’ve had no problems with
    I’ve had no problems with mine (around 1 year old, ride around 5-6 hours a week on average, washed about every 1-2 months), but from what I’ve read the hairer the chest the more common the problems, anecdotal of course.
    #867329
    FatAndFurious
     In my opinion the Garmin
     In my opinion the Garmin soft straps are just a POS and not fit for purpose.
    I went through two with exactly those symptoms. Garmin replaced both under warranty, but I’ve just kept the last one in the box for emergency standby. A friend gave me an old Garmin HRM1G “hard” strap which paired up with my 800 without issue and has not missed a step in 2 years, though it does seem to be sensitive to flappy clothing until I get properly warmed up (i.e. sweaty). Any ANT+ replacement strap should suffice.
    I’ve heard of people having success with ultrasound gel, but my advice would be to give up on these straps entirely and get something else.
    #867327
    mrmo
    on dreamlx10’s point, i didn
    on dreamlx10’s point, i didn’t need to do any trimming to my polar strap. Only been a few months but have no issues at all using a polar strap and a garmin transmitter.
    #867325
    davel
    Yeah mine hiccupped and then
    Yeah mine hiccupped and then just died about 6 months ago (did the whole change battery, clean etc), so I binned it and bought a new one. I did some googling and loads of people have the same issues – but it seems that other brands have similar ones too. The favourite explanation seems to be build-up of salt.
    Garmin’s advice on maintenance has changed – used to be wash every 7 wears; now it’s rinse/soak after each use, and wash after every 7. I’ve followed this and not had any issues – but it’s still only 6 months old (of really regular use though – 60k commutes 3,4,5 times per week, plus the other usual stuff including runs).  The contacts are a slightly different layout on this new one so they have changed it over the past couple of years.
    Hopefully this one will last a bit longer than my last one (18 months) but I figure the worst case is I have to replace it every year or two, and you can usually get them for about £20 on sale.
    #867323
    dreamlx10
    Buy a Polar strap and attach
    Buy a Polar strap and attach the sensor from the Garmin, takes a bit of trimming with a Stanley knife but works and is much more reliable.
    #867321
    kev-s
    Best advice is to chuck the
    Best advice is to chuck the peice of shit in the bin
    Mine played up within 2 months of use, Garmin replaced it and that one played up too
    Lots of people have problems with the Garmin straps even when following the instructions to a tee
