Tyres for winter? Gatorskins? Marathons?
  • This topic has 36 replies, 30 voices, and was last updated 11 years ago by Exup.
  • #24809
    roadgenius4
    I have a specialized Sirrus with stock 28mm espoir tyres on at the moment. They are ok in the dry weather however now winter is approaching and the rain is starting I am in need of some winter tyres.
    I would like to go for 32c as I think this will give best grip and comfort. I mainly cycle city roads and a few tow-paths and gravel tracks.
    I have considered the following:
    Schwalbe Marathon Greenguards
    Schwalbe Marathon Plus
    Continental Gatorskins
    I understand the Schwalbe’s are a lot heavier and don’t roll as well however have excellent puncture protection.
    I previously used 35c Schwalbe Greenguards on an old hybrid bike and they were quite slow and heavy. Also cornering wasn’t as grippy and nippy due to the thick treads.
    I like the look of the gatorskins as they are light and I favour speed over puncture protection. My question is which tyres will have the most grip on wet roads?
    Open to other suggestions as well -If 32’s are too wide then i could use 28’s etc.
    I am assuming gatorskins will be equal to the dry performance of the current espoirs.
    Thanks
Viewing 6 replies - 31 through 36 (of 36 total)
  • #859869
    barbarus
    No punctures for me on
    No punctures for me on gaterskins.
    #859867
    HalfWheeler
    Specialized Armadillos. Wee
    Specialized Armadillos. Wee bit heavy but absolutely bomb proof, I managed to get over 3000 puncture free miles on one pair. In fact I only replaced them coz the tread had worn all the way down to the casing.
    #859865
    Jono M
    I’ve got 25 mm Gatorskins on
    I’ve got 25 mm Gatorskins on my racer and had the unfortunate experience racing in 40F rainy weather a couple times. Even when water was running over the roadway I didn’t feel a loss of traction. And no punctures so far.
    #859863
    Shades
    Marathon Plus. If there was
    Marathon Plus. If there was a nuclear war, they’d survive. Little bit ‘slippy’ in that deep winter greasy road period.
    #859861
    Batchy
    You can’t go wrong with
    You can’t go wrong with Gatorskins.
    #859859
    gmac101
    After 2 punctures on one
    After 2 punctures on one commute I replaced the espoirs on my Allez with specialized armadillos which have been puncture free for 2 years. I have also used the Marathon Plus’s but found them a bit sketchy in “greasy” conditions. I have also punctured them twice, both times it was flints that caused the problems, they got wedged in the tread and worked their way through the puncture belt, though I think the newer marathons have a less pronounced tread pattern which may have help prevent this type of problem.
