Road cable disc brake calipers
  • This topic has 19 replies, 8 voices, and was last updated 11 years ago by KiwiMike.
  • #24703
    GingerNinja1989
    Hi all,
    Having just managed to snap(!) the pivot arm off my front caliper (Promax Render-R), I find myself in need of new brakes.
    The brakes would be going on a 2015 Cannondale Caadx Tiagra, so 160mm front and 140mm rear discs.
    I’m thinking something like Shimano CX-77 or am I better off going for something like TRP Hy-Rd?
    Cheers!
Viewing 4 replies - 16 through 19 (of 19 total)
  • #858255
    GingerNinja1989
    Apparently the Juin brakes
    Apparently the Juin brakes aren’t compatible with 140mm discs, although I can’t think of a reason why that might be!
    #858253
    rmacneil
    Juin Tech R1s get a good
    Juin Tech R1s get a good write up and look a bit neater than the TRPs. Also a bit cheaper.
    #858251
    GingerNinja1989
    Forgot about the Spyres –
    Forgot about the Spyres – cheers for the heads up.
    However, am I right in thinking that the Hy-Rds are worth the extra dosh?
    #858249
    2 Wheeled Idiot
    Hy-rd if you don’t mind the
    Hy-rd if you don’t mind the look (I think they’re kinda butt ugly). Then after that bid say the grp spyre as it pushes the pads from both sides instead I’d just one like the shimano and avid bb7 brakes.
