- This topic has 20 replies, 16 voices, and was last updated 10 years, 12 months ago by
Woldsman.
August 14, 2015 at 6:04 pm #24619
orangesoul
Hi, need to re-wrap a set of bars…ideally with some tape that’s got a bit of padding as the current Fizik tape is pretty thin and uncomfortable. Wondering what tape people are using and recommend.
Thanks, Ed
Woldsman
Simon E wrote:Woldsman
Simon E wrote:Woldsman wrote:Oh, when I put on the Giant Connect gel tape I left the original skinny tape on the bars. Thought I might as well.Normally you’d strip it off completely and clean any residue off the bars so the new tape has a good surface to adhere to.
Yes, normally I would, and did on the bike with the Specialized Phat tape referred to upthread, but thought I’d give it a go on my Giant bike after severe pain in the heel of my right palm. I read something about riders on Paris–Roubaix going with two lots of bar tape.
However, I have yet to ride the Giant any significant distance since wrapping the bars. I’ll just have to see how I get on…
S13SFC
Lizard Skins. Lovely.
Woldsman
Oh, when I put on the Giant Connect gel tape I left the original skinny tape on the bars. Thought I might as well.Jack Osbourne snr
For padding, I can highly
For padding, I can highly recommend the Boardman gel tape from that place wot does Boardman… Much to my surprise!Needed some new tape in a hurry after an oily hand vs. White bar tape disaster and happened to be passing a branch of the shop wot does Boardman.
Ten pounds and includes screw in end plugs.
Only criticism is it gets a bit slippy when wet, but if you’re wearing gloves, you won’t even notice.
Jack Osbourne snr
Jack Osbourne snr
Jack Osbourne snr
Richbeck
Lizard skins every time!
Lizard skins every time!stenmeister
Nat Jas Moe wrote:Fizik
Nat Jas Moe wrote:Fizik performance bar tape £14+1 on this. It’s a thick tape and looks good.
Do you want to be a little
Do you want to be a little different? Have you thought of wrap instead of tape? Have a look at this link,http://www.nonusual.com/gropes
You can add additional padding such as Bontrager’s IsoZone Bar Padding underneath if you need to. Also, don’t underestimate the cushioning potential of a good pair of comfort-mitts.
mike the bike
peted76 wrote:Lizard Skins
peted76 wrote:Lizard Skins for me, it is expensive but the best texture I’ve got to grips with.
Three thicknesses available I use the middling one at 2.5mm.Me too. It may cost a little more – alright, a lot more – but you only buy it once.
peted76
bikebot
And if padding is the
And if padding is the concern, double wrap the section of bars where you need it.
fukawitribe
monkeytrousers wrote:Zipp CX.
monkeytrousers wrote:Zipp CX. Well padded and grippy. You’ll only find it in black and maybe red though. White has vanished off the face of the earth.Agree, lovely stuff. Funnily enough I still have a box lurking in a drawer.. in white 🙂 Also quite like the Bontrager stuff – easy to put on, very comfy and reasonably grippy.
