- This topic has 44 replies, 21 voices, and was last updated 11 years, 4 months ago by
Simon E.
July 8, 2015 at 10:05 am #24392
Lee170
I’ve just bought a new bike and have been out a few times on it, it’s ace so far.
I’m around 70kg and ride a 25c tyre, what pressures should I be running front and rear,
I am going out today to buy a gauge track pump as my current pump has no gauge. -
ibr17xvii
Batchy wrote:ibr17xvii
Batchy wrote:ibr17xvii wrote:OP, what track pump did you go for?Looking to get one with a gauge on myself.
I’ve just lashed out all of £5.99 for an Aldi track pump. To be honest I doubt whether there is anything out there that comes close to this item for value. It is a super pump with gauge and it is very solidly built considering the price. Check one out you will be amazed.Will do, cheers for that.
Batchy
I’ve just lashed out all of £5.99 for an Aldi track pump. To be honest I doubt whether there is anything out there that comes close to this item for value. It is a super pump with gauge and it is very solidly built considering the price. Check one out you will be amazed.Lee170
I did order a halfords track
I did order a halfords track pump half price £13. I know shop owners who love them, I haven’t picked it up yet though, I’ve seen a. Lovely lezyne track pump so maybe swayed!
fukawitribe
Sorry to butt in, but Evans have the Birzman Maha really rather cheap, e.g. the IV is about 24 quid
http://www.evanscycles.com/products/birzman/zacoo-maha-iv-track-pump-ec050466
They seem to get universally excellent reviews
http://road.cc/content/review/84544-birzman-zacoo-maha-iii
http://www.cyclingweekly.co.uk/reviews/pumps-puncture-repair/birzman-zacoo-maha-iii-track-pump-49-99
http://www.bikeradar.com/road/gear/article/best-floor-pumps-for-road-cyclists-33412/Even tempted to replace my Blackburn for the head alone…
ibr17xvii
kwi
Batchy wrote:Surely the
Batchy wrote:Surely the optimum pressure of any tyre is somewhere between those that the manufacturers state on the side wall.
The Max is also a bit conservative as it really depends on the rim, as that is an unknown to the manufacturer they tend to go low. And I think the minimum is more concerned with rolling off (Again, the rim has an influence.) rather than pinch flats.
fukawitribe
Batchy wrote:Surely the optimum pressure of any tyre is somewhere between those that the manufacturers state on the side wall.Well the obvious question is optimum for what under what conditions. I’ve yet to find a tyre whose quote minimum figures were not very heavily on the high side for my weight (~74kg) and the type of riding I do in the UK, YMMV clearly. I can’t imagine ever going even remotely as high as the maximum for anywhere outside of a track in this country.
Batchy
Surely the optimum pressure of any tyre is somewhere between those that the manufacturers state on the side wall. The heavier you are the more pressure is required up to the maximum figure. Usually the manufacturers regard around 80kg as being heavy so anyone around or above this should have tyres pumped up to maximum. Below minimum even for light riders will increase risk of snake bites.
fukawitribe
Simon E wrote:Start with 80
Simon E wrote:Start with 80 front and 90 rear.When you’ve ridden those pressures for a while experiment by reducing / increasing them by at least 10 psi and see how it rides.
This sounds like pretty good advice to me.
edster99
I’m 75 and normally run about
I’m 75 and normally run about 90-95 front / 95-100 rear, Vittoria Corsa Elites. Depends on the road quality I am expecting – if its good, I will add a bit more.
fukawitribe
FWIW – 75kg and 25mm tyres
FWIW – 75kg and 25mm tyres (Vittoria Open Pave) on 23mm (17mm internal) rims – usually about 80psi (front) / 85psi (rear).Podc
I’m a similar weight and run
I’m a similar weight and run 25c tyres at 70 front and 90 rear.gmac101
http://www.bikequarterly.com/
http://www.bikequarterly.com/images/TireDrop.pdfThis is a good place to start. Note that the load is per wheel not total
