Compact or Semi
  • #23392
    Must be Mad
    About to replace worn out chain rings, chain and cassette, and have been thinking if I should change from a Compact (34/50) to a Semi-compact (36/52) cogs at the front.
    I currently run a 28-11 cassette with a 34/50
    My reason for looking at the bigger cogs is nothing to do with spinning out of the top gear – its that I am finding that I am spending more and more time in the ‘right hand side’ of the cassette.
    With a 36/52, I’m thinking that for my regular cadences, I should spend more time with the chain a bit more central in the cassette. For about 75% of my riding, the 36/52 seems like a step in the right direction.
    However the problem is the other 25%. I live in a hilly area (with a lot of steep slopes), and I do find myself in the 34(front)-28(back) gear quite a lot.
    On my current setup, this gives me a ratio of 1.21:1. Stepping up to a 36-28 would give me a ratio of 1.28:1
    Has anybody made this this change, and how noticeable did it feel when grinding up the climbs?
Viewing 12 replies - 16 through 27 (of 27 total)
  • #834351
    Coodsta
    I’ve been running 50/34 &
    I’ve been running 50/34 & 11-28 but found I was mostly in the big ring & the top half of the casette, with all sorts of cross chaining horror. I replaced the 50 ring with a 46 which brought me into the middle of the cassette & works nicely, I still have a 46/11 top gear which gives me 33 MPH at 100 rpm. I’d probably go to a 44 if I was doing it again.
    This is where I first came across the idea
    In praise of the smaller "big" ring
    45 Chainring – part 2 (of 45?)
    recently I’ve gone even further & replaced the 46/34 with a single narrow wide 38 chainring. Yes I ocassionally run out of gears down big hills & have to get out of the saddle on some climbs but everthing looks lovely & clean & runs silently
    i would qualify all this by saying that I ride fixed/singlespeed much of the time any way & only my road bike has gears, so I get a bit confused with 20 gears!
    sheldon Browns gear calculatror is great for working out what gears would work for you: http://sheldonbrown.com/gears/
    #834349
    Must be Mad
    Quote:I was surprised at the
    I was surprised at the difference the 2 extra teeth made.
    Thank you. I’m only looking for a small step at the moment – so feel sticking with current setup the way to go. But this was the sort of feedback I was looking for.
    [quote]remember, kids – there’s no such thing as ‘spinning out’. It’s just shorthand for ‘I don’t know how to pedal quickly’…[quote]
    I did say at the top my question was not about spinning out. But there is a physical limit for the max cadence you can peddle at
    #834347
    andyp
    #834345
    andyp
    #834343
    lolol
    #834341
    Must be Mad
    Thanks for the thoughts. I
    Thanks for the thoughts. I will probably stay with the compact for now.
    Whilst there are options for going for an even wider range cassette, I don’t really want to spread out my current range any further
    What I *really* need is n+1…
    #834339
    lolol
    I recently changed mine from
    I recently changed mine from a 36/50 to 36/52, because of the spinning out. I’m thinking of going back though, I find the jump between the inner and outer is annoyingly disparate compared, it feels like a much smoother transition with 36/50 and that I’m now changing between the rings more often. I reckon I can live with the odd spin out.
    #834337
    nopants
    I’ve just made the change
    I’ve just made the change from a compact to a 52/36. I’m definitely spending more time in the middle of the cassette now.
    A lot of my riding is also in a pretty hilly area, and I have no problems at all with the 52/36 an 11-28 (11 speed) on the back. I have moved from an 11-25 (10 speed) on the compact though. I do notice a couple of bigger jumps between rings on the flat.
    #834335
    sergius
    Turns out I can’t do maths,
    Turns out I can’t do maths, it’s about the same at the bottom end 39/32 as a 34/28.
    But I have a lot more at the top end – I do find myself spinning out a lot when descending .
    #834333
    sergius
    I’ve just ordered a new bike
    I’ve just ordered a new bike with a standard front 53/39 and a 11-32 rear. I’ll let you know how I get on with that compared to my current bike which is a compact front 50/34 and 11-28 rear.
    I figure I’ve got more to play with at both the top and bottom end with this setup, albeit with a slightly bigger jump between gears at certain points.
    #834331
    McVittees
    I run 36/50, the 14t gap
    I run 36/50, the 14t gap makes swapping between inner and outer ring much more pleasant. I’d say this is much more useful ‘mid compact’ than 36/52. Won’t help with that nasty 25% though…;)
    #834329
    bashthebox
    I’d suggest that the 25% of
    I’d suggest that the 25% of the riding where you need your 34/28 is the 25% of your riding where you really need it the most. The benefits of having 52 up front are tiny – How often are you spinning out for longer than a minute or two? But I can bet you’re spending a while grinding up those steep slopes in your granny gear, desperately pushing the shift lever across, hoping against hope there’s another cog to hop onto.
