Di2 considerations and ponderings – yay or nay?
  • #23144
    bobster
    Looking to go Ultegra, and faced with the choice of mechanical or jumping to Di2.
    This would be on a year round use bike, not planning to race it, just get out and ride – but treating myself a bit too.
    So real world experiences of Di2 users appreciated, anyone that’s tried both and their thoughts would be greatly appreciated.
    All and any input welcomed to help with my decision making process.
Viewing 15 replies - 1 through 15 (of 21 total)
  • #830003
    Guernsey Donkey
    I agree with all of the above
    I agree with all of the above even though I have EPS.
    One thing I will highlight is the lack of chain rub. I spent an age at the weekend on a sportive grinding up a long drag into the wind when I spotted another rider with a faster candace but with an obviously smaller cassette than me. A glance down confirmed that I was in 50-29 rather than the 34-29 that I thought! Sometimes that chain rub is a useful hint 😉
    #830001
    tiddy
    I use Ultegra Di2 with both
    I use Ultegra Di2 with both 10 and 11 spd wheels, spacer fitted to 10 spd cassette.
    #829999
    Rob747
    if the bike was Di2, could
    if the bike was Di2, could you use 10 speed wheels / cassette?
    I’m aware a spacer is reqd for a 10 speed cassette but isnt the chain narrower too?
    #829997
    MrMajic
    I can answer that – once
    I can answer that – once correctly set up the chain won’t rub if you cross the two extremes of the gearing. You still shouldn’t do it though, as it means that the chain isn’t running straight which will load the rollers un-evenly. I’ve had Di2 for a year or so now and I would definitely buy it again. That said, I have mechanical on my winter bike – it seems like an unnecessary expense for a winter bike.
    #829995
    tjm160
    Thanks bobster, helpful
    Thanks bobster, helpful thread and info. Can I just ask whether there is any residual chain rub with the auto trimming or whether the age-old cross-over issue has been resolved completely with the advent of Di2?
    #829993
    bobster
    For anyone that stumbles
    For anyone that stumbles across this thread in the future.
    I went with the Di2 in the end, had it for about 6 weeks now, absolutely loving it, glad I went with it, so effortless in use, easy to check battery level and auto trimming is fantastic.
    #829991
    flippineck
    i to have two di2 10 speed
    i to have two di2 10 speed and 11 speed
    And 105 set up 10 speed compact 105 10 cassett triple
    Do prefer the di2 with the 10 cassette scram powerdome X and 901scram chain
    #829989
    72vintage
    Have ultegra di2 on one bike
    Have ultegra di2 on one bike and 105 5800 on the other. Love them both but di2 edges it for me. Shifting is so smooth and precise and I’ve had no issues mechanically or electronically in 2 years (cue meltdown). Hoods are a touch more comfortable too.
    #829987
    ianrobo
    if you have the cash for Di2
    if you have the cash for Di2 would be daft not to.
    When I witched from mech Campag to EPS then the difference is fantastic, I am sure the same applies to Shimano.
    #829985
    Tinternet_tim
    I have a number of friends
    I have a number of friends with ultegra Di2 and all love it, so if you make the jump I’m sure you’ll not be disappointed.
    Having said that, I’ve no interest in it as I’ve never had an issue with mechanical ultegra, it’s dead easy to maintain and cheaper to replace when things finally wear out or go wrong (commute big gets caked in muck!)
    #829983
    Tinternet_tim
    #829981
    kev-s
    i have ultegra di2 on my
    i have ultegra di2 on my workbike, 100 miles a week and used in all weathers and its been faultless
    if u can afford a little extra buy the diagnostic kit aswell, allows you to customise shifting etc.. also handy if you do get a fault
    dont worry about flatting the battery, just check the battery indicator before each ride, even if you forget the front mech will stop working first and you will get 50-70 miles from the rear mech (depending on how often u shift) then if u manage to fully flat the battery then the system will just stay in the selected gear so the bike can still be ridden
    #829979
    CXR94Di2
    You press and hold a lever
    You press and hold a lever then the head unit display a light, green is fully charged. If you were daft enough to go out with a very low battery then the first thing to stop working would be the front derailleur. Allow several hundred changes on the rear derailleur before it stopped working.
    #829977
    massivecompacthalo
    I’ve had it for about 3500kms
    I’ve had it for about 3500kms and I love it. Battery not an issue, it did 2000km on the first charge and it’s easy to check the charge level with the small control box. I check it every couple of rides just to make sure. For me it’s the precision and near silence that I love and the fact that you just prod gently on the buttons, so little effort. I have another bike with mechanical and I don’t enjoy it half as much.
    Typically ride between 100 and 250km a week in all weather.
    #829975
    bobster
    The battery is the bit that
    The battery is the bit that concerns, how do you know when to charge?
    Are the horror stories just people not monitoring their usage, and not looking after it properly?
