another ‘first bike’ thread – any advice appreciated
  • This topic has 29 replies, 13 voices, and was last updated 12 years ago by caaad10.
  • #22714
    welshyoot
    So I guess you all know the drill – I assume you get loads of these threads so sorry to be a bore!
    However, this whole new bike malarkey is a bit of a minefield so any help you can give is definitely appreciated.
    A little background: I’m fairly fit generally and I’ve recently been doing a few cycles around the 30 mile mark (although with fairly challenging hills) with friends and family who are keen cyclists, on borrowed bikes. I have loved it mind. The bike I’ve mainly been using is fairly old and worn, slightly too small for me and I’m told the gears are not quite right and the bike itself is quite heavy. I did hire a trek madone for a day and that was a much better fit and feel. In any case, I’ve enjoyed the rides and I know that cycling is something I’ll take to quite keenly. I have a budget of up to £1200 and I’ve seen that lots of places are offering what seem to be good deals on last years bikes. One friend advised that if it’s something I think I’ll be doing regularly long term, to think about spending towards the higher end of my budget rather than get something more ‘entry level’ and then want to upgrade at a later stage (as he did himself).
    I’ve been having a look, but to be honest I’m not really sure what bikes are worthwhile for the money, I’ve come up with:
    Cannondale Supersix Evo 105 6 2014 at £1199;
    Bianchi C2C Impulso 105 2013 at £927
    Boardman team carbon at £999
    Merida Ride Carbon Comp 93 2014 at £899
    There’s also the NeilPryde Alize 105 2014 which is £1200 but I’m slightly put off because it seems like it may be too advanced for me. The saving on it seems quite good though which is why I considered it in the first place.
    Are any of these good ideas? I haven’t used any of them as these are all found from the internet. I know this is the best starting point but it could prove tricky – there’s an Evans near me so I could get the cannondale sent there to try it – although a review of it said it’s ‘an aggressive racing position’ which might mean it’s not that comfortable – I don’t know how much of a difference this actually makes. Alternatively the Merida is reviewed as being the opposite end of that scale and perhaps would force me to sit up too high.
    I’m sure I’m missing lots from my research but if anyone could give me some hints that would be great!
Viewing 14 replies - 16 through 29 (of 29 total)
  • #820481
    As said check the geometry –
    As said check the geometry – especially stack and reach – and then pick the one that feels right. Or in fact, I’d recommend picking the one that feels just on the ‘stretched’ side of right, because as you get into it your body will get used to the position (a bit).
    The Supersix 105 is an awesome bike for the money and I’d have no hesitation recommending a Cannondale; I’d also suggest test riding a CAAD10 105 (aluminium) as they are supposed to be awesome: no weight penalty and as comfortable as the supersix.
    #820479
    Daveyraveygravey
    I’m not sure that the
    I’m not sure that the differences in geometry between a race bike and a sportive/endurance bike are that great, or make one more rideable than another for most of us. You’re talking 10-20 mm, or half a degree here or there in a lot of cases. If you have back problems, or you have got a bike the wrong size, then that’s different.
    Having said that, I ride an ally bike from the 90’s when there wasn’t a choice, so what do I know!
    I like the look of that Cannondale too. I’m hoping to spend around £1200 – £1500 on a new bike at some point, and I’m fairly sure the Cannondale is the best value of the ones you can try. If I could I’d pop over to Koblenz and try a Canyon, but that is tricky to do, so it looks like a Cdale for me.
    OP, see if you can talk Evans or the other shops into letting you try a couple of bikes out on the road for 10 mins. Some of the bigger retailers let you try for 30 days and then you can change. A mate bought a Cannondale MTB, rode it off road a couple of times and wasn’t keen. Went back to Evans, and ok, he almost doubled his initial spend, but came out with a different bike he was much more happy with. That’s the key at the end of the day, the one you are happiest with is the best, regardless of frameset/geometry/groupset/value for money. If you haven’t been on it for a couple of days and you are itching to get out there, rather than thinking, Meh I’ll not bother to day, pick that one!
    #820477
    As I usually say on this
    As I usually say on this topic, buyers are spoilt for choice, all the groupsets work brilliantly, you’re splitting hairs between the spec levels at a given price band. Carbon vs alu is not night and day, the real-world difference is smaller than people would have you believe.
    Definitely would recommend you look around, get a feel for the bikes and each shop’s customer service.
    The best bike is the one that fits you correctly and you like it the most.
    #820475
    welshyoot
    Cheers again all, I’ve booked
    Cheers again all, I’ve booked a test ride with Evans for the supersix evo and they may have a couple of other bikes in my size at the same time so I can get a feel for different frames etc. There are a couple of other bike shops close by so if not with Evans I’ll pop into another one and follow your recommendations of taking their advice RE frame sizing. Hopefully not too long to wait!
    #820473
    Nixster
    Re Canyon and Rose – if I was
    Re Canyon and Rose – if I was in funds my choice of new bike would be Canyon, I agree. However I have gone through the experience of buying a bike I thought would fit then selling it because it didn’t.
    So I am now at the point that I am fairly confident that the Canyon I want would fit me based on experience of a real rather than virtual bike. The OP is on his first bike and therefore my suggestion was that he get some real world experience before going down the bought unseen route.
    Or being devil’s advocate, go for it blind, gives you an excuse to upgrade later if you’re unlucky with the fit. If you can afford it of course. B-)
    Frame materials – the Supersix Evo is a blindingly good frame (see review on here) so good carbon really is available in the budget given. Not so good it won’t stop your back hurting if it doesn’t fit you though…
    #820471
    parksey
    You’ll invariably get lots of
    You’ll invariably get lots of nods towards the various online options; Planet X, Ribble, Canyon, etc, and I don’t disagree that *some* of them offer decent value for money. However, for a first road bike purchase I’d recommend going to your LBS and taking their advice as to the geometry and frame sizing that will best suit you based on test-riding different bikes, rather than simply buying “blind” online and finding the bike isn’t right for you.
    None of the bikes you’ve mentioned are so obscure though as to not be available at your average bike shop, so you shouldn’t have too much difficulty in tracking them down for test rides, particularly if you’ve got a few different stores nearby.
    As has been mentioned already, don’t be swayed by a particular bike simply because it’s on a good sale price either, unless you know it is definitely the right bike for you. That Supersix price at Evans is extremely tempting, but I know it’s too aggressive a set up for me for instance. If they had the equivalent Synapse at that price though…
    As for the carbon v aluminium debate, there really is no answer, it’s all down to personal preference. Ultimately, a carbon frame on a bike that originally cost £1000 new is unlikely to be any “better” than a similarly-priced aluminium frame. As has also been mentioned above, you generally pick two from good frame, good components or good price. You *very* rarely get all three…
    Good luck with the search!
    #820469
    hsiaolc
    Looking at your budget there
    Looking at your budget there is only two brands I will recommend.
    Canyon
    Rose
    Next you need to find out if you want relaxed or racy geometry. Makes a big difference.
    Then choose your model based on that. Your friends is correct go for the max you can afford and will save you money in the long run.
    However, if you choose the wrong bike then you are not going to be better off.
    Since you can’t try Canyon or Rose you should try out several LBS on several geometries and see which one suites you best and then use that knowledge and choose the Canyon or the Rose.
    #820467
    giobox
    drmatthewhardy wrote:If your
    If your budget is £1200 I’d stick to alloy frames and get the best groupset and wheels you can.
    There are plenty of great alloy frames out there now. Canyon, Cannondale, Kinesis, Bowman, etc. See if you can try one out, that’s my other suggestion.
    If the original poster has found a Cannondale Supersix 105 in their budget of £1200, I’d argue they would be silly to consider any of Cannondale’s alloy options, or anyone else’s for that matter. With 105, he’s not exactly sacrificing spec to get a carbon frame either.
    In fact, this seems a remarkably simple choice – the Supersix is pretty awesome value at that price.
    #820465
    welshyoot
    Hmm, I did read this might be the way to go – although what if I want to upgrade in the future – wouldn’t it be better to get a carbon frame and then upgrade that at a later date?
    On another note I’m now wondering about the Planet X Pro Carbon Sram Race at £1100 or the Planet X Pro Carbon Shimano Ultegra 6800 at £1200 – someone said that you still get a good carbon frame as well as a good groupset with these bikes. Is that correct?
    #820463
    matthewn5
    #820461
    welshyoot
    Thanks all, this is really
    Thanks all, this is really useful advice and has already helped a lot with my thinking. I really liked the Madone but I’ve had trouble finding carbon frame within my price bracket. It’s also the only bike I’ve tried that fits me properly so I should really try something else as you’ve suggested. In terms of the fit – I’m not sure if the bars were too close, saddle etc – I have no real comparison yet so I’m going to pop into Evans shortly and sit on a couple down there and see how they feel. I appreciate this isn’t as good as riding one but I might be able to get some idea at least. Thanks all for your help so far!
    #820459
    Nixster
    4 of the bikes listed are
    4 of the bikes listed are carbon. None of them are bad bikes and personally I think the Cannondale is a bargain but I’m biased. How the bike fits will define your experience though, not what its made of.
    The Cannondale, Boardman and Neil Pryde Alize are all race oriented geometry with relatively low front ends and longer top tubes – I don’t know about the others but even Bianchi’s ‘endurance’ bikes have quite a ‘racy’ fit compared to some of their peers.
    You need a point of reference. If the Madone was one you’ve ridden, how did it feel in terms of fit? Balanced in the saddle? Bars close/not too close, able to reach down into the drops and stay there for a while reasonably comfortably – or not?
    Once you have that clear in your mind you can start to look at different models and compare their geometry reach and stack figures. More reach = bars further away, more stack = bars higher. Bear in mind that you will probably find it easier to get down to the drops over time but only by 2-3 cm. Then you will be able to draw up a shortlist based on how well it is likely to fit you rather than what’s on special offer.
    Then try them (you wouldn’t buy a car you hadn’t driven would you?) – and try a size down too, people often get a bike that’s too big as a first bike.
    Good luck!
    #820457
    OnTheRopes
    Hi
    You are right to be
    Hi
    You are right to be thinking of going for the higher end of your budget if you think you will be cycling long term. Usually better levels of equipment.
    The frames you list above all have a pretty much race geometry (not sure about the Merida) as is the Madone.
    I had a Madone 3.1 as a training bike and I could not fault it.
    I think you need to look at what kind of riding you think you will be doing, if it is purely for training rides for fitness then a race geometry will be fine, if you think you may be doing long touring rides then you may want to consider something more comfortable. You also need to consider if you will want to fit ‘proper’ mudguards
    I have always ridden race geometry bikes even for long distance and always managed OK, but I recently built a winter bike based on a Dolan Dual Carbon.
    I have to say t is the most comfortable ride i ave ever had, takes full mudguards and is certainly no slouch and could be raced quite adequately.
    It is at t top end of your budget but worth a look. Personaly I would get it with Shmano 105 groupset and nothing of a lower level
    http://www.dolan-bikes.com/dolan-dual-carbon-road-bike.html
    #820455
    Jeroen0110
    If you’ve ridden the Madone
    If you’ve ridden the Madone perhaps consider one of those – if you liked it?
    Which bike is fairly personal, but perhaps worth trying one or two in a shop and have a think about it…
    You’ve listed more “endurance” bikes above which are set up a little bit more comfy than the Madone which is a “race” road bike. Good groupset, good frame, good price, pick two really! Your friend is right about buying a better bike, so perhaps go for a better frame and if required replace the groupset as bits wear out – the frame will be difficult to change. Perhaps you can get carbon for the money if you look hard enough?
